Nullpointer Exception when clicking outside of table [message #1065712] |
Thu, 27 June 2013 08:47 |
Aljoscha Steffens Messages: 302 Registered: November 2012 |
I get a NullPointerException when I click outside of the table (in the darkgrey area).
Here is the simple version of the code:
dataProvider = new DataProvider();
final ViewportLayer layer = new ViewportLayer( new DataLayer(dataProvider) );
layer.setRegionName(GridRegion.BODY);
GridData gd = new GridData(SWT.FILL, SWT.FILL, true, true, 2, 1);
natTable = new NatTable(container, layer, false);
natTable.setLayoutData(gd);
natTable.addConfiguration(new DefaultEditBindings());
natTable.addConfiguration(new DefaultNatTableStyleConfiguration());
natTable.configure();
It appears to have sth to do with
and
If I delete either of those lines in the complete code, I don't get an error, but of course my table does not work as desired (I can't edit cells).
Here the errormessage:
!SESSION 2013-06-27 10:28:24.382 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product MEXA.product
Command-line arguments: -product MEXA.product -data E:\eclipse42\Workspace/../runtime-MEXA.product -dev file:E:/eclipse42/Workspace/.metadata/.plugins/org.eclipse.pde.core/MEXA.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-06-27 10:28:29.608
!MESSAGE Internal Error
!STACK 0
at org.eclipse.nebula.widgets.nattable.ui.matcher.BodyCellEditorMouseEventMatcher.matches(BodyCellEditorMouseEventMatcher.java:42)
at org.eclipse.nebula.widgets.nattable.ui.binding.UiBindingRegistry.getDragMode(UiBindingRegistry.java:57)
at org.eclipse.nebula.widgets.nattable.ui.mode.ConfigurableModeEventHandler.mouseDown(ConfigurableModeEventHandler.java:56)
at org.eclipse.nebula.widgets.nattable.ui.mode.ModeSupport.mouseDown(ModeSupport.java:95)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:192)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
at org.eclipse.nebula.widgets.nattable.ui.binding.UiBindingRegistry.getMouseEventAction(UiBindingRegistry.java:96)
at org.eclipse.nebula.widgets.nattable.ui.binding.UiBindingRegistry.getSingleClickAction(UiBindingRegistry.java:74)
at org.eclipse.nebula.widgets.nattable.ui.mode.ConfigurableModeEventHandler.mouseDown(ConfigurableModeEventHandler.java:54)
What can I do?
FUDForum. Page generated in 0.03521 seconds
