Auto resize Column/Row Width/Height empties table [message #1065178] |
Mon, 24 June 2013 15:26 |
Alexander Becher Messages: 7 Registered: July 2009 |
I've found a problem with automatic column/row resizing by double clicking or context menu.
It's reproducible for instance in the FreezableGridExample or even the "Default NatTable" example. If you scroll to the right and then auto resize a column so that the column width decreases, the whole table is emptied and only the grid lines are visible.
The same behavior applies to auto row resize if you scroll down to the end end then auto resize a row that decreases it's height.
Can you help me with that problem?
Cheers
Alex
[Updated on: Mon, 24 June 2013 15:27] Report message to a moderator
FUDForum. Page generated in 0.03185 seconds
