Re: E4 Command Parameter Object Type [message #1065148 is a reply to message #1064971] |
Mon, 24 June 2013 13:54 |
On 06/22/2013 04:57 AM, Markuz Surfing wrote:
> Is the argument of a command only support String? I have found some post
> on making commands with parameters but all of them are only using String
> as parameter. Is it possible to have an argument of any object type? If
> yes, how?
If you provide a converter, they you can have ParameterizedCommands that
have parameters of different types. The underlying restriction is the
parameters must be able to be converted from Object -> String -> Object.
The types are defined in the org.eclipse.ui.commands extension point,
and although they can be specified in Eclipse4 RCP apps, they can't be
defined yet from the model. See
org.eclipse.ui.internal.commands.CommandPersistence.readParameterTypesFromRegistry(IConfigurationElement[],
int, CommandManager) for an example of where they're defined while
running the 4.x Workbench. For how they're currently defined, see
org.eclipse.ui.commands [1]. It should be possible to define your own
commandParameterType programmatically once the CommandManager is available.
[1]
http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Freference%2Fextension-points%2Forg_eclipse_ui_commands.html&cp=2_1_1_134
Later,
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse.platform.doc.isv/guide/workbench.htm
Paul Webster
FUDForum. Page generated in 0.02459 seconds
