Home » Eclipse Projects » Eclipse 4 » Eclipse Kepler constantly freezes
Eclipse Kepler constantly freezes [message #1064863] |
Fri, 21 June 2013 13:05 |
Matt Saint Messages: 4 Registered: June 2013 |
Hi everyone. I have another thread around here somewhere regarding missing project files. I have solved that issue, but am now having trouble with the IDE itself. I have all of my projects, which include many .java and .jsp files, but every time I try to open up Eclipse, it freezes and does not respond for ~20 minutes, if at all. I am using Eclipse Kepler at work, so this issue is causing me to lose a lot of work time. Here are the contents of the error log:
Quote:!SESSION 2013-06-21 08:45:02.673 -----------------------------------------------
eclipse.buildId=4.3.0.I20130516-2200
java.version=1.7.0_21
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.dsl.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.dsl.product
!ENTRY org.eclipse.core.resources 2 10035 2013-06-21 08:45:05.179
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.jface 2 0 2013-06-21 08:45:11.308
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2013-06-21 08:45:11.308
!MESSAGE A conflict occurred for ALT+SHIFT+D R:
Binding(ALT+SHIFT+D R,
ParameterizedCommand(Command(org.eclipse.rap.ui.launch.RAPLaunchShortcut.debug,Debug RAP Application,
Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Debug command category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@24ff4207,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.wst.server.launchShortcut.debug,Debug on Server,
Debug the current selection on a server,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@7247ec8a,
,,true),null),
!MESSAGE A conflict occurred for ALT+SHIFT+X R:
Binding(ALT+SHIFT+X R,
ParameterizedCommand(Command(org.eclipse.rap.ui.launch.RAPLaunchShortcut.run,Run RAP Application,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@4ffa92a3,
,,true),null),
ParameterizedCommand(Command(org.eclipse.wst.server.launchShortcut.run,Run on Server,
Run the current selection on a server,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@4bb1345a,
,,true),null),
!MESSAGE A conflict occurred for ALT+SHIFT+Q E:
Binding(ALT+SHIFT+Q E,
ParameterizedCommand(Command(org.eclipse.php.ui.explorer,PHP Script Explorer,
Shows the Script Explorer,
Category(org.eclipse.ui.category.views,Views,Commands for opening views,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@5ee42788,
,,true),null),
ParameterizedCommand(Command(org.eclipse.ui.views.showView,Show View,
Shows a particular view,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@54df8263,
[Lorg.eclipse.e4.ui.internal.workbench.Parameter;@1de95d1d,,true),[Lorg.eclipse.core.commands.Parameterization;@43e02a42),
!ENTRY org.eclipse.jst.jsp.core 4 4 2013-06-21 08:45:13.575
!MESSAGE A workspace crash was detected. The previous session did not exit normally. Not using saved taglib indexes.
!ENTRY org.eclipse.egit.ui 2 0 2013-06-21 08:46:06.806
!MESSAGE Warning: EGit couldn't detect the installation path "gitPrefix" of native Git. Hence EGit can't respect system level
Git settings which might be configured in ${gitPrefix}/etc/gitconfig under the native Git installation directory.
The most important of these settings is core.autocrlf. Git for Windows by default sets this parameter to true in
this system level configuration. The Git installation location can be configured on the
Team > Git > Configuration preference page's 'System Settings' tab.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
I'm wondering what the !MESSAGE Warning: means, and/or how to fix it. This is the most recent session, I have tried closing and opening several times. It seems it's impossible to exit the program normally, it freezes up and turns white any time I try to click on anything. The only way to exit is to kill it from the task manager. I think Juno had a similar problem.
I'm using Windows 7 by the way.
Any help would be appreciated!
Current Time: Sun Sep 22 16:55:19 GMT 2024
Powered by FUDForum. Page generated in 0.03860 seconds
