How in the world do you generate a papyrus model from an existing uml? [message #1064556] |
Wed, 19 June 2013 21:04 |
John Donma Messages: 7 Registered: June 2013 |
I can not find any way to link my empty papyrus project with an uml diagram from a java project. Any help please?
And i get this nice error when i open model explorer view:
org.eclipse.papyrus.core.services.ServiceNotFoundException: Can't get the current Eclipse Active Editor. No ServiceRegistry found.
at org.eclipse.papyrus.core.utils.ServiceUtilsForActionHandlers.getServiceRegistry(ServiceUtilsForActionHandlers.java:68)
at org.eclipse.papyrus.core.utils.ServiceUtilsForActionHandlers.getTransactionalEditingDomain(ServiceUtilsForActionHandlers.java:88)
at org.eclipse.papyrus.diagram.common.handlers.GraphicalCommandHandler.getEditingDomain(GraphicalCommandHandler.java:143)
at org.eclipse.papyrus.diagram.common.handlers.UnloadHandler.getCommand(UnloadHandler.java:50)
at org.eclipse.papyrus.diagram.common.handlers.GraphicalCommandHandler.isEnabled(GraphicalCommandHandler.java:108)
at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:320)
at org.eclipse.core.commands.Command.isEnabled(Command.java:833)
at org.eclipse.core.commands.Command.setHandler(Command.java:965)
at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:457)
at org.eclipse.ui.internal.handlers.HandlerAuthority.deactivateHandler(HandlerAuthority.java:312)
at org.eclipse.ui.internal.handlers.HandlerService.deactivateHandler(HandlerService.java:148)
at org.eclipse.ui.internal.handlers.HandlerService.deactivateHandlers(HandlerService.java:157)
at org.eclipse.ui.internal.handlers.HandlerPersistence.clearActivations(HandlerPersistence.java:104)
at org.eclipse.ui.internal.handlers.HandlerPersistence.dispose(HandlerPersistence.java:125)
at org.eclipse.ui.internal.handlers.HandlerService.dispose(HandlerService.java:163)
at org.eclipse.ui.internal.services.ServiceLocator.dispose(ServiceLocator.java:142)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3057)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1123)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:1040)
at org.eclipse.ui.internal.Workbench$25.run(Workbench.java:1284)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1282)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1254)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:727)
at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:715)
at org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindow.java:867)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:865)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window.java:741)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:687)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:98)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations.java:308)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.java:1677)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4530)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2061)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2526)
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:498)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2531)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
LE: I am using eclipse 3.7.2
[Updated on: Wed, 19 June 2013 22:00] Report message to a moderator
Re: How in the world do you generate a papyrus model from an existing uml? [message #1064745 is a reply to message #1064556] |
Thu, 20 June 2013 18:50 |
I selected the .uml file the followed your instructions. I then selected class diagram and i pressed finish, but it did not do anything. I then chose next and ended up on the choose root element screen. There i tried selecting and clicking and double clicking everything but i just can't get past that last step. What exactly am i supposed to select on the root element screen ( it's cryptic for me). As i said i tried everything to get past that screen.
LE Some extra details: The papyrus model file appears though. As i said i can't get past the select root element screen. And if i close it by pressing cancel or close, when i open the papyrus model file i get a premature end of file
[Updated on: Thu, 20 June 2013 18:54] Report message to a moderator
Re: How in the world do you generate a papyrus model from an existing uml? [message #1066149 is a reply to message #1066058] |
Mon, 01 July 2013 09:35 |
Hi John,
In the last selection window, you can select the element that will be the context of the new diagram. This step is not mandatory, as the step with the diagram creation.
You say that you had some crash during installation, can you detail this ? If there are some problems during installation, this could explain why Papyrus is not working...
Papyrus 0.10.0 is now available with the new Kepler release (accessible from Eclipse Kepler site).
For the documentation, this procedure is not indicated, but it is expected to work.
Finally, could you clean your error log, reproduce the steps you have done, and then send your error log? This could help us debug your problem.
HTH,
Remi
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.04408 seconds
