Home » Eclipse Projects » NatTable » Exception when using DefaultGlazedListsStaticFilterStrategy(addStaticFilter overrides final method)
Exception when using DefaultGlazedListsStaticFilterStrategy [message #1064518] Wed, 19 June 2013 11:33 Go to next message
I'm trying to use the DefaultGlazedListsStaticFilterStrategy to add a static filter as described here:
http://sourceforge.net/p/nattable/discussion/744992/thread/be012eb5
I use the method addStaticFilter(final Matcher<T> matcher) to add my filter.
In run time, I get the following exception:
java.lang.VerifyError: class org.eclipse.nebula.widgets.nattable.extension.glazedlists.filterrow.DefaultGlazedListsStaticFilterStrategy$1 overrides final method getMatcher.()Lca/odell/glazedlists/matchers/Matcher;
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:634)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:601)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:567)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:490)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(ClasspathManager.java:478)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:458)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at org.eclipse.nebula.widgets.nattable.extension.glazedlists.filterrow.DefaultGlazedListsStaticFilterStrategy.addStaticFilter(DefaultGlazedListsStaticFilterStrategy.java:62)
I checked the GlazedList code and AbstractMatcherEditor.getMatcher() is really defined as final.
I have the latest GL version 1.9.0 and NatTable version 0.9.0.
Is this a bug?
Arye
Re: Exception when using DefaultGlazedListsStaticFilterStrategy [message #1064544 is a reply to message #1064518] Wed, 19 June 2013 15:46 Go to previous message
The bug is that you use NatTable 0.9 together with GlazedLists 1.9 ... they are not compatible because of an API change in GlazedLists regarding Matcher.
You need to update to NatTable 1.0 to use GlazedLists 1.9 or downgrade to GlazedLists 1.8. I personally suggest to update to NatTable 1.0
Previous Topic:Context menu option for tree grid
Next Topic:Not all values displayed
Current Time: Thu Nov 06 12:55:00 EST 2025
Powered by FUDForum. Page generated in 0.48130 seconds
