How to Debug RCP application [message #1064456] |
Wed, 19 June 2013 07:38  |
I have a few eclipse bundles, which build with Ant. I want to build my bundles with Maven. For this I use maven-bundle-plugin. Then I want to debug my bundles. I add all maven projects with packaging bundle to Eclipse workspace through Existing Maven Project. The build are successfully finished. After this i click Debug Configurations -> Osgi Framework. In tab Bundles i see all my workspace projects. I click Add required bundles and then click Debug.
Equinox OSGI console show me few errors:
osgi> !SESSION 2013-06-19 15:30:59.006 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_23
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ru_RU
Command-line arguments: -dev file:D:/Svn/AntToMaven/.metadata/.plugins/org.eclipse.pde.core/Debug/dev.properties -os win32 -ws win32 -arch x86 -consoleLog -console -clean
!ENTRY org.eclipse.debug.ui 4 0 2013-06-19 15:31:01.413
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.debug.internal.ui.DebugUIPlugin.start() of bundle org.eclipse.debug.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:561)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:546)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:459)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:440)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
Caused by: java.lang.IllegalStateException: Workbench has not been created yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
at org.eclipse.debug.internal.ui.contextlaunching.LaunchingResourceManager.startup(LaunchingResourceManager.java:542)
at org.eclipse.debug.internal.ui.DebugUIPlugin.getLaunchingResourceManager(DebugUIPlugin.java:301)
at org.eclipse.debug.internal.ui.DebugUIPlugin.start(DebugUIPlugin.java:502)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
... 11 more
Root exception:
!ENTRY org.eclipse.help.ui 4 0 2013-06-19 15:31:01.694
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.help.ui.internal.HelpUIPlugin.start() of bundle org.eclipse.help.ui.
at org.eclipse.help.ui.internal.HelpUIPlugin.start(HelpUIPlugin.java:108)
... 11 more
Root exception:
!ENTRY ru.diasoft.fa.platform.report.metamodel.ds 4 0 2013-06-19 15:31:10.256
!MESSAGE org.eclipse.wst.common.componentcore.internal.impl.ComponentcoreFactoryImpl
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.wst.common.componentcore.internal.impl.ComponentcoreFactoryImpl
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:506)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
at ru.diasoft.fa.platform.report.metamodel.ds.dto.pkg.MyEpackageRegistry.getEFactory(MyEpackageRegistry.java:52)
at org.eclipse.wst.common.componentcore.internal.impl.ComponentcoreFactoryImpl.init(ComponentcoreFactoryImpl.java:43)
at org.eclipse.wst.common.componentcore.internal.ComponentcoreFactory.<clinit>(ComponentcoreFactory.java:27)
at org.eclipse.wst.common.componentcore.internal.StructureEdit.<clinit>(StructureEdit.java:91)
at org.eclipse.wst.common.componentcore.internal.impl.WTPModulesResourceFactory.<clinit>(WTPModulesResourceFactory.java:33)
at org.eclipse.wst.common.componentcore.internal.impl.WTPModulesInit.initResourceFactories(WTPModulesInit.java:52)
at org.eclipse.wst.common.componentcore.internal.impl.WTPModulesInit.init(WTPModulesInit.java:42)
at org.eclipse.wst.common.componentcore.internal.impl.WTPModulesInit.init(WTPModulesInit.java:34)
at org.eclipse.wst.common.componentcore.internal.ModulecorePlugin.start(ModulecorePlugin.java:66)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:417)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:265)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:106)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:453)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:466)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2389)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.newInstance0(Class.java:326)
at java.lang.Class.newInstance(Class.java:308)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:151)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:751)
!ENTRY org.eclipse.debug.ui 4 0 2013-06-19 15:31:12.693
!MESSAGE
!STACK 0
at org.eclipse.osgi.framework.internal.core.StartLevelManager.setBundleSL(StartLevelManager.java:695)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:437)
... 8 more
Root exception:
!ENTRY org.eclipse.help.ui 4 0 2013-06-19 15:31:12.740
!MESSAGE
!STACK 0
... 8 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2013-06-19 15:31:12.896
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
An error has occurred. See the log file
C:\Program Files\eclipseHeliosSR1win32+SubEclipse+Maven\eclipseHeliosSR1win32\workspace\.metadata\.log.
Please, help me to resolve this problem.
FUDForum. Page generated in 0.04173 seconds
