Home » Language IDEs » C / C++ IDE (CDT) » 8051/c programming error(port name show Semantic Error)
8051/c programming error [message #1063942] Sun, 16 June 2013 07:30 Go to next message
hello,
I am new in eclipse user. I try to run the simple 8051 program in eclipse. For this purpose I Download Eclipse IDE for C/C++ Developers,Download SDCC,Downloading Eclipse Plugin for SDCC. follow all the procedure as given in this link below
http://www.embeddedcraft.org/free8051.html
but when I build the code then it show error
'P1_0' could not be resolved 1.c/ proj1 line 20 Semantic Error[/font][/size]
How I can remove this error? and how to check step by step execution in eclipse?
Please help me.............
Thank you
swapneel
Re: 8051/c programming error [message #1069458 is a reply to message #1063942] Mon, 15 July 2013 19:22 Go to previous message
try to set the debug session, those means right click -> debbug as -> debbug configurations.
if you are already set the debug configuration use the Icons in "step in" step out" or F6, F7 to debug step by step
I never use eclipse to program the 8051, but i hope this lines help you
Previous Topic:Win 7, eclipse Kepler, MinGW
Next Topic:Help changing GCC version used by Eclipse.
Current Time: Tue Oct 28 13:24:56 EDT 2025
Powered by FUDForum. Page generated in 0.67721 seconds
