Home » Modeling » GMF (Graphical Modeling Framework) » two diagram views on one model
two diagram views on one model [message #157190] Fri, 26 October 2007 05:58 Go to next message
Originally posted by: benholtz.gmx.de
Hello to all,
I have one MetaModel which contains all elements. At the end I will have one
editor which has one model file and two diagram files. In both diagram files
I want to see another view of the model. The model file contains all
elements of the two diagram files.
Now I have two gmftool, gmfmap and gmfgen files in one project. Both gmfgen
files generate the diagram code into the .diagram project. I think, they
have to be generated into different projects, because the plugin.xml is
always overwritten if I start one of the generation processes.
In the diagram files are some elements pointing to the same model element in
the model file.
Is there a workaround about this problem? Or a tutorial? I didn't find
anything belongs to this topic.
Benjamin Holtz
Re: two diagram views on one model [message #157208 is a reply to message #157190] Fri, 26 October 2007 06:15 Go to previous messageGo to next message
Hello Benjamin,
See http://wiki.eclipse.org/GMF_GenModel_Hints. You have to made all the
properties mentioned as "unique" in that document really unique in your .gmfgen
model.
Alex Shatalin
Re: two diagram views on one model [message #157215 is a reply to message #157208] Fri, 26 October 2007 07:30 Go to previous messageGo to next message
Ok, I maked the IDs unique. Now I can model two diagrams in the editor. But
each diagram has got his own model file. If I want to use the same model
file, the wizard says that this file already exists. What is wrong?
Benjamin
"Alex Shatalin" <vano@borland.com> wrote in message
news:3c3172e6198158c9e5e10c8dc08e@news.eclipse.org...
> Hello Benjamin,
> .gmfgen model.
> Alex Shatalin
Re: two diagram views on one model [message #157231 is a reply to message #157215] Fri, 26 October 2007 08:14 Go to previous messageGo to next message
Ho Benjamin,
You may also use the generated menu item "Initialize XYZ diagram file"
to create a diagram based on an existing model file.
Boris
> Benjamin
>> Hello Benjamin,
>> .gmfgen model.
>> Alex Shatalin
Re: two diagram views on one model [message #157239 is a reply to message #157231] Fri, 26 October 2007 09:11 Go to previous messageGo to next message
I think, all diagrams will have the same tools when they are initialized in
this case. But I want, that each instance has got his own tooling
definition.
I think I will let two model and two diagram files in the editor and will
reference the model files among each other.
Benjamin
"Boris Blajer" <boris.blajer@borland.com> wrote in message
news:ffslo5$ifr$1@build.eclipse.org...
> Ho Benjamin,
> You may also use the generated menu item "Initialize XYZ diagram file" to
> Best regards,
> Boris
Re: two diagram views on one model [message #157298 is a reply to message #157239] Fri, 26 October 2007 12:18 Go to previous message
Hi Benjamin,
If you create a XYZ diagram and then initialize ZYX diagram based on the
same file, you will get two completely different notational models
referencing the same underlying model. These two will have their own set
of tools, editparts and whatever else.
Boris
> definition.
> Benjamin
>> Ho Benjamin,
>> Best regards,
>> Boris
Previous Topic:How to capture the event mouseOver
Next Topic:Sharing Single Editing Domain in GMF
Current Time: Thu Nov 06 02:24:15 EST 2025
Powered by FUDForum. Page generated in 0.05037 seconds
