Re: e4 plug-in perspective creation [message #1063638 is a reply to message #1063296] |
Thu, 13 June 2013 10:55   |
Hi again,
I've started with a test plugin (and a feature accompanying it) and adding the org.eclipse.ui dependency avoids the application to be launched by giving below errors.
I've also attached the the sample plugin and feature which is currently broken the way it is. If I remove the mentioned dependency and the org.eclipse.ui.perspectives entry from the plugin.xml, application launches.
So;
1- Is there a way to fix this issue and make the OzTestPerspective activate the Perspective defined under the Application.e4xmi file?
2- Can I bypass implementing the IPerspectiveFactory and 'magically' point at the Perspective within e4xmi as the perspective contribution by this plugin, so the perspective looks identical to what I see when the application is launched on its own?
Errors;
!SESSION 2013-06-13 15:38:11.542 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_09
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_GB
Framework arguments: -product org.oz.test.plugin.product -clearPersistedState
Command-line arguments: -product org.oz.test.plugin.product -data /home/ocagdas/rcp/../runtime-org.oz.test.plugin.product -dev file:/home/ocagdas/rcp/.metadata/.plugins/org.eclipse.pde.core/org.oz.test.plugin.product/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog -clearPersistedState
!ENTRY org.eclipse.equinox.app 0 0 2013-06-13 15:38:13.085
!MESSAGE Product org.oz.test.plugin.product could not be found.
!ENTRY org.eclipse.osgi 2 0 2013-06-13 15:38:13.212
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-06-13 15:38:13.213
!MESSAGE Bundle reference:file:/home/ocagdas/codebase/sysmon_graph/org.oz.test.plugin/ was not resolved.
!SUBENTRY 2 org.oz.test.plugin 2 0 2013-06-13 15:38:13.213
!MESSAGE Missing required bundle org.eclipse.ui_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2013-06-13 15:38:13.215
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-06-13 15:38:13.216
!MESSAGE Bundle org.oz.test.plugin_1.0.0.qualifier [67] was not resolved.
!SUBENTRY 2 org.oz.test.plugin 2 0 2013-06-13 15:38:13.216
!ENTRY org.eclipse.osgi 2 0 2013-06-13 15:38:13.243
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-06-13 15:38:13.243
!SUBENTRY 2 org.oz.test.plugin 2 0 2013-06-13 15:38:13.244
!ENTRY org.eclipse.osgi 2 0 2013-06-13 15:38:13.246
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-06-13 15:38:13.246
!SUBENTRY 2 org.oz.test.plugin 2 0 2013-06-13 15:38:13.247
!ENTRY org.eclipse.osgi 4 0 2013-06-13 15:38:13.248
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
gogo: CommandNotFoundException: Command not found: gosh
org.apache.felix.gogo.runtime.CommandNotFoundException: Command not found: gosh
at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:466)
at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:395)
at org.apache.felix.gogo.runtime.Pipe.run(Pipe.java:108)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:183)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:120)
at org.apache.felix.gogo.runtime.CommandSessionImpl.execute(CommandSessionImpl.java:89)
at org.apache.felix.gogo.shell.Activator.run(Activator.java:75)
at java.lang.Thread.run(Thread.java:722)
An error has occurred. See the log file
/home/ocagdas/rcp/.metadata/.plugins/org.eclipse.pde.core/org.oz.test.plugin.product/1371134291805.log.
O.
[Updated on: Fri, 14 June 2013 04:39] by Moderator
Re: e4 plug-in perspective creation [message #1064118 is a reply to message #1063847] |
Mon, 17 June 2013 13:36  |
Ozgur, to 'add' a perspective the e4 way try this:
1) Find the MPerspectiveStack in your model (there has to be one if you want to use perspectives...)
2) Create a new MPersepective and format it as you desire (You might be able to get some help from the ModeledPageLayout API since all it does is create model elements from the various apis).
3) Add it to the MPerspectiveStack
4) Make it the Stack's selected element (should cause it to render...)
FUDForum. Page generated in 0.25436 seconds
