Home » Eclipse Projects » EclipseLink » ConversionException When Using Enum in Composite Primary Keys(ConversionException When Using Enum in Composite Primary Keys)
ConversionException When Using Enum in Composite Primary Keys [message #1063171] |
Wed, 12 June 2013 14:15 |
Aslam Ahmed Messages: 3 Registered: June 2013 |
Hello Everyone,
I am using enum plus long field as my composite primary key in a model. But when I use both of the fields in jpql for filter criteria (e.g. where modelId = ?1 and vendorType = ?2) it gives me a ConversionException. Appreciate if someone can clarify. Below are the details:
VendorView:
@MappedSuperclass
@IdClass(VendorPK.class)
public abstract class VendorView extends AbstractView {
private static final long serialVersionUID = 4952393420338697658L;
@Id
@Column(name="MODEL_XID")
protected Long modelId;
@Id
@Enumerated
@Column(name="VENDOR_TYPE")
protected VendorType vendorType;
@Column(name="CODE")
@ReportElement(name="Code",dataType=DataType.TEXT,filter=true,index=1,sort=true,zlist=true,width=75)
protected String code;
@Column(name="SHORT_NAME")
@ReportElement(name="Short Name",dataType=DataType.TEXT,filter=true,index=1,sort=true)
protected String shortName;
@Column(name="TITLE")
@ReportElement(name="Title",dataType=DataType.TEXT,filter=true,index=0,sort=true,zlist=true,width=200)
protected String title;
@Column(name="DESCRIPTION")
protected String description;
@Column(name="APPLY_CHARGES")
@ReportElement(name="Apply charges",dataType=DataType.BOOLEAN,filter=true,index=3,sort=true)
protected Boolean applyCharges;
@Column(name="ADDRESS1")
@ReportElement(name="Address",dataType=DataType.TEXT,filter=false,index=4,sort=false)
protected String address1;
@Column(name="ADDRESS2")
protected String address2;
@Column(name="PHONE1")
@ReportElement(name="Phone",dataType=DataType.TEXT,filter=false,index=5,sort=false)
protected String phone1;
@Column(name="PHONE2")
protected String phone2;
@Column(name="FAX")
@ReportElement(name="Fax",dataType=DataType.TEXT,filter=false,index=6,sort=false)
protected String fax;
public Long getModelId() {
return modelId;
public String getCode() {
return code;
public String getShortName() {
return shortName;
public String getTitle() {
return title;
public String getDescription() {
return description;
public Boolean isApplyCharges() {
return applyCharges;
public String getAddress1() {
return address1;
public String getAddress2() {
return address2;
public String getPhone1() {
return phone1;
public String getPhone2() {
return phone2;
public String getFax() {
return fax;
public VendorType getVendorType() {
return vendorType;
public int hashCode() {
final int prime = 31;
int result = 1;
result = prime * result + ((modelId == null) ? 0 : modelId.hashCode());
+ ((vendorType == null) ? 0 : vendorType.hashCode());
return result;
public boolean equals(Object obj) {
if (this == obj)
return true;
if (getClass() != obj.getClass())
return false;
VendorView other = (VendorView) obj;
if (modelId == null) {
if (other.modelId != null)
return false;
} else if (!modelId.equals(other.modelId))
return false;
if (vendorType == null) {
if (other.vendorType != null)
return false;
} else if (!vendorType.equals(other.vendorType))
return false;
return true;
VendorPk:
@Embeddable
public class VendorPK implements Serializable{
private static final long serialVersionUID = 2313226839954294852L;
@Enumerated
public VendorPK(){}
public VendorPK(Long modelId, VendorType vendorType){
this.modelId = modelId;
this.vendorType = vendorType;
return modelId;
public void setModelId(Long modelId) {
return vendorType;
public void setVendorType(VendorType vendorType) {
return (int)(Long.valueOf(modelId).hashCode()) + this.vendorType.hashCode();
if (obj == null) return false;
if (obj == this) return true;
if (!(obj instanceof VendorPK)) return false;
VendorPK pk = (VendorPK) obj;
return ((pk.modelId==this.modelId) && pk.vendorType.equals(this.vendorType));
AirlineView:
@Entity
@Table(name="GBOSSV_VENDOR")
@SecurityContext(value=Airline.class)
public class AirlineView extends VendorView {
private static final long serialVersionUID = 2969582818437459745L;
@Column(name="DIGIT_CODE")
@ReportElement(name="Digit Code",dataType=DataType.TEXT,width=50,filter=true,index=7,sort=true,zlist=true)
protected String digitCode;
@Column(name="CHARACTER_CODE")
@ReportElement(name="Character Code",dataType=DataType.TEXT,width=50,filter=true,index=8,sort=true,zlist=true)
protected String characterCode;
@Column(name="IS_IATA")
@ReportElement(name="Is IATA",dataType=DataType.BOOLEAN,filter=true,index=9,sort=true)
protected Boolean IATA;
public String getDigitCode() {
return digitCode;
public String getCharacterCode() {
return characterCode;
public Boolean getIATA() {
return IATA;
Jpql:
SELECT m FROM AirlineView m WHERE m.modelId =?1 and m.vendorType = ?2 ORDER BY m.vendorType,m.modelId ASC
StackTrace
[org.eclipse.persistence.exceptions.ConversionException.couldNotBeConverted(ConversionException.java:71), org.eclipse.persistence.internal.helper.ConversionManager.convertObjectToInteger(ConversionManager.java:543), org.eclipse.persistence.internal.helper.ConversionManager.convertObject(ConversionManager.java:114), org.eclipse.persistence.internal.databaseaccess.DatasourcePlatform.convertObject(DatasourcePlatform.java:162), org.eclipse.persistence.internal.descriptors.ObjectBuilder.extractPrimaryKeyFromRow(ObjectBuilder.java:2545), org.eclipse.persistence.internal.descriptors.ObjectBuilder.extractPrimaryKeyFromExpression(ObjectBuilder.java:2392), org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.checkCacheForObject(ExpressionQueryMechanism.java:866), org.eclipse.persistence.queries.ReadObjectQuery.checkEarlyReturnLocal(ReadObjectQuery.java:243), org.eclipse.persistence.queries.ObjectLevelReadQuery.checkEarlyReturn(ObjectLevelReadQuery.java:838), org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:789), org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1109), org.eclipse.persistence.queries.ReadObjectQuery.execute(ReadObjectQuery.java:421), org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1197), org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2875), org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1602), org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1584), org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1549), org.eclipse.persistence.internal.jpa.QueryImpl.executeReadQuery(QueryImpl.java:231), org.eclipse.persistence.internal.jpa.QueryImpl.getResultList(QueryImpl.java:403), com.bnv.zinro.node.Dao.readList(Dao.java:162), sun.reflect.GeneratedMethodAccessor21.invoke(Unknown Source), sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25), java.lang.reflect.Method.invoke(Method.java:597), org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317), org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183), org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150), org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:110), org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172), org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204), $Proxy51.readList(Unknown Source), sun.reflect.GeneratedMethodAccessor21.invoke(Unknown Source), sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25), java.lang.reflect.Method.invoke(Method.java:597), org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317), org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183), org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150), org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:110), org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172), org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204), $Proxy52.readList(Unknown Source), com.bnv.zinro.node.TransactionalModelManager.getViewList(TransactionalModelManager.java:114), sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source), sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25), java.lang.reflect.Method.invoke(Method.java:597), org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317), org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183), org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150), org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:110), org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172), org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204), $Proxy53.getViewList(Unknown Source), sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source), sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25), java.lang.reflect.Method.invoke(Method.java:597), org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317), org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183), org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150), org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:110), org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172), org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204), $Proxy53.getViewList(Unknown Source), com.bnv.zinro.node.ModelManager.getViewList(ModelManager.java:141), com.bnv.zinro.node.RemoteManager.getViewList(RemoteManager.java:264), sun.reflect.GeneratedMethodAccessor25.invoke(Unknown Source), sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25), java.lang.reflect.Method.invoke(Method.java:597), sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:305), sun.rmi.transport.Transport$1.run(Transport.java:159), java.security.AccessController.doPrivileged(Native Method), sun.rmi.transport.Transport.serviceCall(Transport.java:155), sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535), sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790), sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649), java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886), java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908), java.lang.Thread.run(Thread.java:619)]
Re: ConversionException When Using Enum in Composite Primary Keys [message #1064398 is a reply to message #1064274] |
Wed, 19 June 2013 05:44 |
James Sutherland wrote on Tue, 18 June 2013 10:14Please include the error message.
Here it is.
[ZFME=FW_CO_100, ZMsg=Database Exception , addMsg=
Exception Description: The object [AIRLINE], of class [class com.bnv.zinro.catalyst.model.vendor.VendorType], could not be converted to [class java.lang.Integer].
, Ref=null, getMessage()=null, getCause()=null]
VendorType:
public enum VendorType {
AIRLINE("Airline"),
HOTEL("Hotel"),
TRANSPORT("Transport"),
VISA("Visa"),
GENERAL(IGbossConstants.GENERAL);
String title;
private VendorType(String title){
this.title = title;
public String getTitle(){
return title;
[Updated on: Wed, 19 June 2013 05:46] Report message to a moderator
Current Time: Fri Apr 26 18:28:39 GMT 2024
Powered by FUDForum. Page generated in 0.03008 seconds
