Home » Modeling » OCL » OCL closure works properly with Interactive OCL, not Interactive Xtext OCL
OCL closure works properly with Interactive OCL, not Interactive Xtext OCL [message #1062936] Tue, 11 June 2013 09:09 Go to next message
Hello everyone,
I encounter a strange problem with Interactive Xtext OCL editor. I attach here the UML model I used to evaluate a constraint using OCL closure operation. The OCL constraint is as follows:
self -> asSet() -> closure(v | v.class.oclAsType(Component).ownedAttribute
 -> select(p : Property | v <> p and v.class.oclAsType(Component).ownedConnector -> exists(end.partWithPort -> includes(p) and end.partWithPort -> includes(v)))
 -> asSet())
This constraint is evaluated at either 5 Properties (comp1, comp2, comp3, comp4, comp5) nested in the component MainComp (We can evaluate the mentioned constraint by simply clicking at one of 5 above properties and writing down the constraint in the Interactive Xtext OCL editor). To be clear, the constraint finds out the connected elements of self. It searches the properties in the containing components that share a common connector with self. Through the closure operation, it searches the connected properties, the connected properties of connected properties, ans so on...
The problem is:
1) Sometimes the Interactive Xtext OCL notifies "Evaluation failure". To get rid of this notification, I typed in another random constraint (e.g. self.name) and the editor works again normally.
2) Because 5 properties above are all connected to each other, the result for evaluating the constraint on each property should be all 5 properties. With Interactive OCL editor, I always get the wishing results. However, using Interactive Xtext OCL editor, for some properties among the 5, I only get 4 properties as result.
I'm sorry because I couldn't find another simpler example. I tried the one with parent->closure(children) but in this case both editors give the same results.
Any help would be appreciated.
Re: OCL closure works properly with Interactive OCL, not Interactive Xtext OCL [message #1062938 is a reply to message #1062936] Tue, 11 June 2013 09:22 Go to previous messageGo to next message
What version are you using.
The problem seems rather like
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401302 which was fixed in M6.
Ed Willink
On 11/06/2013 14:09, Capi Tali wrote:
> Hello everyone,
> -> asSet())
> The problem is:
> Best regards,
Re: OCL closure works properly with Interactive OCL, not Interactive Xtext OCL [message #1062939 is a reply to message #1062938] Tue, 11 June 2013 09:31 Go to previous messageGo to next message
It seems like what you detected in the bug, it stops getting deeper on the siblings of an already encountered node. I'm using Eclipse Juno with OCL Examples and Editors v.3.2.2.v20130130-1128. Should I get it updated?
Re: OCL closure works properly with Interactive OCL, not Interactive Xtext OCL [message #1062947 is a reply to message #1062939] Tue, 11 June 2013 10:03 Go to previous messageGo to next message
Kepler is officially released on June 26th, so you might just wait till
then.
However you should find that the Kepler milestones and release
candidates work on Juno so long as you update the dependencies too
(Xtext probably).
So if you're very brave just do Install New Software from
http://download.eclipse.org/releases/kepler and select Modeling OCL and
Xtext.
Ed Willink
> updated?
> Best regards,
Re: OCL closure works properly with Interactive OCL, not Interactive Xtext OCL [message #1062953 is a reply to message #1062947] Tue, 11 June 2013 10:13 Go to previous message
Thanks for your suggestions. I think I'll just ... wait then Wink.
Many thanks.
Previous Topic:Setting up OCLInEcore and standalone junit
Next Topic:How to pass a java variable to OCL statement?
Current Time: Wed Jul 02 14:08:31 EDT 2025
Powered by FUDForum. Page generated in 0.04744 seconds
