Home » Archived » Lua Development Tools » running Lua Remote Application - Permission denied
running Lua Remote Application - Permission denied [message #1062903] Tue, 11 June 2013 06:34 Go to next message
Hello Guys,
i try to run a script via Remote, but I get following Error Message:
sh: 1: cannot create /sys/class/gpio/export: Permission denied
> os.execute("echo GPIO4 > /sys/class/gpio/export")
> os.execute("echo out > /sys/class/gpio/gpio4/direction")
> os.execute("echo 1 > /sys/class/gpio/gpio4/value")
> os.execute("echo 0 > /sys/class/gpio/gpio4/value")
works fine in ssh Terminal when I start the interpreter with "sudo lua"
Question:
How to run a remote script as superuser to access GPIO?
Sorry, of course you should know ... I'm using a Raspberry Pi
Kind Regards
Re: running Lua Remote Application - Permission denied [message #1062904 is a reply to message #1062903] Tue, 11 June 2013 06:46 Go to previous messageGo to next message
Hello Marc,
As you noticed you should be a superuser indeed for manipulating the GPIO. Therefore, instead of connecting to your remote system using pi/raspberry as I am pretty sure you are doing, you should rather create a root user and then configure your remote system in Eclipse to use this login.
Enabling the root user is pretty simple, see http://www.instructables.com/id/Control-Stuff-with-your-Raspberry-Pi-GPIO/step2/Root-account/
Also, maybe doing something as the following should work, maybe?
> os.execute("sudo echo GPIO4 > /sys/class/gpio/export")
On a side note, have you looked at Mihini? We are working on providing a nice GPIO API in it (see this branch) but that still requires super-privileges.
[Updated on: Tue, 11 June 2013 06:46] by Moderator
Re: running Lua Remote Application - Permission denied [message #1062909 is a reply to message #1062904] Tue, 11 June 2013 07:11 Go to previous messageGo to next message
Hello Benjamin,
of course I looked at Mihini Wink.
But I found a statement at sierrawireless .. eclipsecon2013-m2m-tutorial .. slides .. (I'm not allowed to post a link)
-> Local communication protocols
-> Many more to come! (e.g. GPIO)
So I thought GPIO is a future thing.
In addition I need for local use on my RasPi I2C and Modbus-ethernet (SPI nice to have)
Thank you for taking the time ...
Re: running Lua Remote Application - Permission denied [message #1062916 is a reply to message #1062909] Tue, 11 June 2013 07:48 Go to previous messageGo to next message
Hello Benjamin,
the tutorial from the link you posted is working.
Now I can run my lua script remote with GPIO access.
Great
Thank you
Re: running Lua Remote Application - Permission denied [message #1063063 is a reply to message #1062916] Wed, 12 June 2013 00:45 Go to previous message
Awesome! Smile
I would highly encourage you to give feedback to the Mihini people on the project mailing list https://dev.eclipse.org/mailman/listinfo/mihini-dev
I2C would be a nice addition and I believe there is a bug tracking that already in Mihini's bug tracker.
Regarding Modbus ethernet, this should be available already ; have you had problems with the API? See http://www.eclipse.org/mihini/api-documentation/modbustcp.html
Cheers!
Benjamin.
Previous Topic:Windows Koneki and Corona first steps setup
Next Topic:Does code assistance only work if you have the lua module associated with the documents
Current Time: Thu Sep 25 07:38:08 EDT 2025
Powered by FUDForum. Page generated in 0.06127 seconds
