| Spring annotation config [message #1062579] |
Sun, 09 June 2013 07:36  |
Hi All,
I have a very simple bundle that has a small spring configuration. I build the bundle using maven and the maven-bundle-plugin. When using XML for spring configuration this works fine: I have a minimal set of import packages and virgo can resolve them easily and start up the bundle.
Now I want to move to annotation configuration. I use a tag in the XML file and have a and a . This works great when I load the configuration in a unit test. When I start the bundle in Virgo, however, I get an exception:
Quote:Start failed for bundle 'xxx'. java.lang.IllegalStateException: Cannot load configuration class: x.x.xConfiguration
at org.springframework.context.annotation.ConfigurationClassPostProcessor.enhanceConfigurationClasses(ConfigurationClassPostProcessor.java:366)
at org.springframework.context.annotation.ConfigurationClassPostProcessor.postProcessBeanFactory(ConfigurationClassPostProcessor.java:242)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.invokeBeanFactoryPostProcessors(AbstractDelegatedExecutionApplicationContext.java:444)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.invokeBeanFactoryPostProcessors(AbstractDelegatedExecutionApplicationContext.java:431)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.invokeBeanFactoryPostProcessors(AbstractDelegatedExecutionApplicationContext.java:362)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$3.run(AbstractDelegatedExecutionApplicationContext.java:254)
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.startRefresh(AbstractDelegatedExecutionApplicationContext.java:220)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.stageOne(DependencyWaiterApplicationContextExecutor.java:224)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.refresh(DependencyWaiterApplicationContextExecutor.java:177)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.refresh(AbstractDelegatedExecutionApplicationContext.java:157)
at org.eclipse.gemini.blueprint.extender.internal.activator.LifecycleManager$1.run(LifecycleManager.java:211)
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at java.lang.Thread.run(Thread.java:680)
Caused by: java.lang.NoClassDefFoundError: org/springframework/cglib/core/ReflectUtils
at x.x.xConfiguration$$EnhancerByCGLIB$$124808e1_2.CGLIB$STATICHOOK2(<generated>)
at x.x.xConfiguration$$EnhancerByCGLIB$$124808e1_2.<clinit>(<generated>)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:249)
at org.springframework.cglib.core.ReflectUtils.defineClass(ReflectUtils.java:386)
at org.springframework.cglib.core.AbstractClassGenerator.create(AbstractClassGenerator.java:219)
at org.springframework.cglib.proxy.Enhancer.createHelper(Enhancer.java:377)
at org.springframework.cglib.proxy.Enhancer.createClass(Enhancer.java:317)
at org.springframework.context.annotation.ConfigurationClassEnhancer.createClass(ConfigurationClassEnhancer.java:118)
at org.springframework.context.annotation.ConfigurationClassEnhancer.enhance(ConfigurationClassEnhancer.java:92)
at org.springframework.context.annotation.ConfigurationClassPostProcessor.enhanceConfigurationClasses(ConfigurationClassPostProcessor.java:356)
... 15 common frames omitted
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: org.springframework.cglib.core.ReflectUtils in KernelBundleClassLoader: [bundle=xxx]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:139)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
... 26 common frames omitted
Caused by: java.lang.ClassNotFoundException: org.springframework.cglib.core.ReflectUtils
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:135)
Now, as I understand this exception, it means that to load the Configuration class spring needs some CGLib classes and it cannot load these classes from the bundle class loader. This is because there are no package, bundle or library import statements for those classes. I think I can resolve this by adding a library import for the spring library or maybe a package import for the spring-core bundle, but this seems like functionality that Virgo might support out of the box: If it can load the XML variant, why not the annotation variant?
Any better options for how to resolve this? Will there be better support for spring annotation config in the near future?
Thanks!
-Maarten Winkels
| Re: Spring annotation config [message #1062601 is a reply to message #1062595] |
Sun, 09 June 2013 16:04  |
You may have cglib packages in Virgo (as part of spring or standalone) but unless your bundle imports them, they will not be available in your classpath.
The general procedure how to create a bundle is start with the minimal configuration for maven-bundle-plugin (which will create imports for what it can scan) and then deploy the bundle. For any ClassNotFoundException exception that comes after that, define extra imports in the <instructions> part of your maven-bundle-plugin configuration.
It would be nice if something could find out all the imports that would be needed at runtime for a bundle but unfortunately this does not exist, and the overhead of doing this manually is the price we have to pay for OSGi modularity. And this is not something Virgo should do as it is an OSGi container following a spec, so what you get when deploying your bundle in Virgo should be the same as when deploying it in another container.
FUDForum. Page generated in 0.04312 seconds
