Home » Archived » BIRT » Null parameter(How to pass null parameter)
Null parameter [message #1062237] |
Thu, 06 June 2013 16:16 |
Hi Experts,
As per my requirement one parameter is optional, If there is no value in the parameter iam getting error. how to pass null parameter in report at run time.
RED
JP
Re: Null parameter [message #1063637 is a reply to message #1062555] |
Thu, 13 June 2013 14:54 |
Yes uncheck the check box, but it is throughing the error. I have changed the scenario and written script on dataSet also getting error. Attached is the report and below is the error. Please suggest me.
The following items have errors:
Script on Dataset
Table (id = 6):
+ There are errors evaluating script "queryText = "Select employeenumber,";
queryText = queryText + "lastname,";
queryText = queryText + "firstname,";
queryText = queryText + "extension,";
queryText = queryText + "email,";
queryText = queryText + "officecode,";
queryText = queryText + "reportsto,";
queryText = queryText + "jobtitle";
queryText = queryText + " from employees";
if (params["P_employeenumber"] && params["P_employeenumber"].value.length > 0) {
queryText = queryText + "where employeenumber >= " + params["P_employeenumber"].value;
else {
JP
Re: Null parameter [message #1064394 is a reply to message #1064171] |
Wed, 19 June 2013 05:21 |
Sorry. I was out of town at the end of last week. Can you expand the error by clicking on the '+' and post the entire stack in here? Thanks!
Michael
Developer Evangelist, Silanis
Re: Null parameter [message #1064480 is a reply to message #1064394] |
Wed, 19 June 2013 13:07 |
Thanks Williams,
There is nothing in the + sign. below is the message after clicking on the +.
Table (id = 6):
- There are errors evaluating script "queryText = "Select employeenumber,";
else {
JP
Re: Null parameter [message #1064533 is a reply to message #1064480] |
Wed, 19 June 2013 18:03 |
If you change your beforeOpen script to simply have this, it should work:
if (params["P_EMPLOYEENUMBER"].value != null && params["P_EMPLOYEENUMBER"].value != "") {
this.queryText = this.queryText + " where employeenumber >= " + params["P_EMPLOYEENUMBER"].value;
The issues in your script above was that the parameter is all uppercase and there is no space before "where". It probably also wouldn't have worked as you wanted with your conditions.
Hope this helps.
Michael
Re: Null parameter [message #1064915 is a reply to message #1064533] |
Fri, 21 June 2013 15:51 |
Williams,
Thanks for your suggestions and it's worked fine with sample report. When i implemented the same in my report it is throughing exceptions as follows.
if (params["P_SALESREP_ID"].value != null && params["P_SALESREP_ID"].value != "") {
this.queryText = this.queryText + " AND f.name = '" + params["P_SALESREP_ID"].value + "'";
Please don't hesitate to suggest me.
Table (id = 12):
- Cannot get the result set metadata.
SQL statement does not return a ResultSet object.
SQL error #1: ORA-00933: SQL command not properly ended
odaconsumer.CannotGetResultSetMetaData ( 1 time(s) )
detail : org.eclipse.birt.data.engine.core.DataException: Cannot get the result set metadata.SQL statement does not return a ResultSet object.SQL error #1: ORA-00933: SQL command not properly ended at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:379) at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getProjectedColumns(PreparedStatement.java:339) at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.declareCustomColumn(PreparedStatement.java:1079) at org.eclipse.birt.data.engine.executor.DataSourceQuery.addCustomFields(DataSourceQuery.java:388) at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepare(DataSourceQuery.java:256) at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:344) at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:212) at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:397) at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:147) at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:135) at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:127) at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:114) at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:208) at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1640) at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:62) at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:74) at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:35) at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layoutChildren(HTMLPageLM.java:123) at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:81) at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:80) at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:194) at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(Unknown Source) at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(Unknown Source) at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(Unknown Source) at org.eclipse.birt.report.service.actionhandler.BirtRunAndRenderActionHandler.__execute(Unknown Source) at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(Unknown Source) at org.eclipse.birt.report.presentation.aggregation.layout.EngineFragment.doService(Unknown Source) at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.service(Unknown Source) at org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(Unknown Source) at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGet(Unknown Source) at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doPost(Unknown Source) at javax.servlet.http.HttpServlet.service(HttpServlet.java:760) at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327) at javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:247) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:256) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:643) at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:480) at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:643) at org.apache.catalina.valves.CertificatesValve.invoke(CertificatesValve.java:246) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:641) at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:480) at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995) at org.apache.catalina.core.StandardContext.invoke(StandardContext.java:2422) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:180) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:643) at org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherValve.java:171) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:641) at org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(EclipseErrorReportValve.java:153) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:641) at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:480) at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:174) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:643) at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:480) at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995) at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:199) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:828) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:700) at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:584) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:683) at java.lang.Thread.run(Thread.java:662)Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.SQL error #1: ORA-00933: SQL command not properly ended ;
JP
Re: Null parameter [message #1065669 is a reply to message #1065317] |
Thu, 27 June 2013 05:44 |
Sorry for the delay. What does your query look like inside the dataSet editor? If you were to put a static value in place of the parameter in the above script, are you able to get the results?
Michael
Re: Null parameter [message #1065831 is a reply to message #1062237] |
Thu, 27 June 2013 16:25 |
My DataSet query as
SELECT DISTINCT b.segment1 Brand,b.segment2 Type,
( SUM (NVL(msi.list_price_per_unit,0))) cog,
( SUM (d.quantity_invoiced)) net_units,
( SUM (NVL(d.unit_selling_price,0))) tot_unit_price,
( SUM (NVL(c.exchange_rate,1))) totExc,
( SUM (d.quantity_invoiced)) tot_sold_qty,
( sum (nvl(d.extended_amount,0) * nvl(c.exchange_rate,1))) NetSales,
( SUM (DECODE(e.TYPE, 'CM', (nvl(d.extended_amount,0) * nvl(c.exchange_rate,1)), 0))) Returns,
( SUM (DECODE(e.TYPE, 'INV', (nvl(d.extended_amount,0) * nvl(c.exchange_rate,1)), 'DM', (nvl(d.extended_amount,0) * nvl(c.exchange_rate,1)),0))) gross_amount,
DECODE(b.segment1,
'M', DECODE(b.segment2, 'F', 'Modo Frames',
'C', 'Modo Clips',
'S', 'Modo Sun',
'H', 'Modo Cases',
'X', 'Modo Spareparts', 'Modo'),
'S', DECODE(b.segment2, 'F', 'Saki Frames',
'C', 'Saki Clips',
'S', 'Saki Sun',
'H', 'Saki Lens',
'X', 'Saki Others', 'Saki'),
'K', DECODE(b.segment2, 'F', 'Keo Frames',
'C', 'Keo Clips',
'S', 'Keo Sun',
'H', 'Keo Lens',
'X', 'Keo Others', 'Keo'),
'P', DECODE(b.segment2, 'F', 'M+ Frames',
'C', 'M+ Clips',
'K', 'M+ Frame & Clip',
'S', 'M+ Sun',
'H', 'M+ Lens',
'X', 'M+ Others', 'M+'),
'B', DECODE(b.segment2, 'F', 'Babyphat Frames',
'C', 'Babyphat Clips',
'S', 'Babyphat Sun', 'Babyphat'),
'H', DECODE(b.segment2, 'F', 'Phatfarm Frames',
'C', 'Phatfarm Clips',
'S', 'Phatfarm Sun', 'Modo'),
'D', DECODE(b.segment2, 'F', 'Dvf Frames',
'C', 'Dvf Clips',
'S', 'Dvf Sun', 'Dvf'),
'U', DECODE(b.segment2, 'F', 'Puma Frames',
'C', 'Puma Clips',
'S', 'Puma Sun', 'Puma'),
'TE', DECODE(b.segment2, 'F', 'Teko Frames',
'C', 'Teko Clips',
'S', 'Teko Sun', 'Teko'),
'C', DECODE(b.segment2, 'F', 'Kirkland Frames',
'S', 'Kirkland Sun', 'Kirkland'),
'E', DECODE(b.segment2, 'F', 'Etro Frames',
'S', 'Etro Sun', 'Etro'),
'F', DECODE(b.segment2, 'F', 'Fendi Frames',
'S', 'Fendi Sun', 'Fendi'),
'PL', DECODE(b.segment2, 'F', 'PHILLIP LIM FRAMES',
'S', 'PHILLIP LIM SUN', 'PHILLIP LIM'),
'ID', DECODE(b.segment2, 'F', 'ID Frames',
'S', 'ID Sun', 'ID'),
'SP', 'SPARES', 'Others') description
FROM mtl_item_categories a,
mtl_system_items_b msi,
mtl_categories b,
ra_customer_trx c,
ra_customers ar,
ra_customer_trx_lines d,
ra_cust_trx_types_all e,
ra_salesreps f
WHERE d.inventory_item_id = a.inventory_item_id(+)
AND msi.inventory_item_id = a.inventory_item_id
AND msi.organization_id = a.organization_id
AND a.category_id = b.category_id(+)
AND ar.customer_id = c.bill_to_customer_id
and c.customer_trx_id = d.customer_trx_id
AND msi.inventory_item_id = d.inventory_item_id
AND c.cust_trx_type_id = e.cust_trx_type_id
AND f.salesrep_id(+) = c.primary_salesrep_id
AND ar.primary_salesrep_id = c.primary_salesrep_id
AND d.line_type = 'LINE'
AND b.structure_id = 101
AND TRUNC(c.trx_date) >= ?
AND TRUNC(c.trx_date) <= ?
AND a.organization_id = ?
GROUP BY b.category_id, b.segment1, b.segment2
ORDER BY b.segment1
and i have written script on DataSet at beforeOpen
if (params["P_CUSTOMER_NUMBER"].value != null && params["P_CUSTOMER_NUMBER"].value != "")
{ this.queryText = this.queryText + " AND ar.customer_number = '" + params["P_CUSTOMER_NUMBER"].value + "'";}
It is failed...
Hence i have changed the script as
queryText = " SELECT DISTINCT b.segment1 Brand,b.segment2 Type,";
queryText = queryText + " ( SUM (NVL(msi.list_price_per_unit,0))) cog,";
queryText = queryText + " ( SUM (d.quantity_invoiced)) net_units,";
queryText = queryText + " ( SUM (NVL(d.unit_selling_price,0))) tot_unit_price,";
queryText = queryText + " ( SUM (NVL(c.exchange_rate,1))) totExc,";
queryText = queryText + " ( SUM (d.quantity_invoiced)) tot_sold_qty,";
queryText = queryText + " ( sum (nvl(d.extended_amount,0) * nvl(c.exchange_rate,1))) NetSales,";
queryText = queryText + " ( SUM (DECODE(e.TYPE, 'CM', (nvl(d.extended_amount,0) * nvl(c.exchange_rate,1)), 0))) Returns,";
queryText = queryText + " ( SUM (DECODE(e.TYPE, 'INV', (nvl(d.extended_amount,0) * nvl(c.exchange_rate,1)), 'DM', (nvl(d.extended_amount,0) * nvl(c.exchange_rate,1)),0))) gross_amount,";
queryText = queryText + " DECODE(b.segment1,";
queryText = queryText + " 'M', DECODE(b.segment2, 'F', 'Modo Frames',";
queryText = queryText + " 'C', 'Modo Clips',";
queryText = queryText + " 'S', 'Modo Sun',";
queryText = queryText + " 'H', 'Modo Cases',";
queryText = queryText + " 'X', 'Modo Spareparts', 'Modo'),";
queryText = queryText + " 'S', DECODE(b.segment2, 'F', 'Saki Frames',";
queryText = queryText + " 'C', 'Saki Clips',";
queryText = queryText + " 'S', 'Saki Sun',";
queryText = queryText + " 'H', 'Saki Lens',";
queryText = queryText + " 'X', 'Saki Others', 'Saki'),";
queryText = queryText + " 'K', DECODE(b.segment2, 'F', 'Keo Frames',";
queryText = queryText + " 'C', 'Keo Clips',";
queryText = queryText + " 'S', 'Keo Sun',";
queryText = queryText + " 'H', 'Keo Lens',";
queryText = queryText + " 'X', 'Keo Others', 'Keo'),";
queryText = queryText + " 'P', DECODE(b.segment2, 'F', 'M+ Frames',";
queryText = queryText + " 'C', 'M+ Clips',";
queryText = queryText + " 'K', 'M+ Frame & Clip',";
queryText = queryText + " 'S', 'M+ Sun',";
queryText = queryText + " 'H', 'M+ Lens',";
queryText = queryText + " 'X', 'M+ Others', 'M+'),";
queryText = queryText + " 'B', DECODE(b.segment2, 'F', 'Babyphat Frames',";
queryText = queryText + " 'C', 'Babyphat Clips',";
queryText = queryText + " 'S', 'Babyphat Sun', 'Babyphat'),";
queryText = queryText + " 'H', DECODE(b.segment2, 'F', 'Phatfarm Frames',";
queryText = queryText + " 'C', 'Phatfarm Clips',";
queryText = queryText + " 'S', 'Phatfarm Sun', 'Modo'),";
queryText = queryText + " 'D', DECODE(b.segment2, 'F', 'Dvf Frames',";
queryText = queryText + " 'C', 'Dvf Clips',";
queryText = queryText + " 'S', 'Dvf Sun', 'Dvf'),";
queryText = queryText + " 'U', DECODE(b.segment2, 'F', 'Puma Frames',";
queryText = queryText + " 'C', 'Puma Clips',";
queryText = queryText + " 'S', 'Puma Sun', 'Puma'),";
queryText = queryText + " 'TE', DECODE(b.segment2, 'F', 'Teko Frames',";
queryText = queryText + " 'C', 'Teko Clips',";
queryText = queryText + " 'S', 'Teko Sun', 'Teko'),";
queryText = queryText + " 'C', DECODE(b.segment2, 'F', 'Kirkland Frames',";
queryText = queryText + " 'S', 'Kirkland Sun', 'Kirkland'),";
queryText = queryText + " 'E', DECODE(b.segment2, 'F', 'Etro Frames',";
queryText = queryText + " 'S', 'Etro Sun', 'Etro'),";
queryText = queryText + " 'F', DECODE(b.segment2, 'F', 'Fendi Frames',";
queryText = queryText + " 'S', 'Fendi Sun', 'Fendi'),";
queryText = queryText + " 'PL', DECODE(b.segment2, 'F', 'PHILLIP LIM FRAMES',";
queryText = queryText + " 'S', 'PHILLIP LIM SUN', 'PHILLIP LIM'),";
queryText = queryText + " 'ID', DECODE(b.segment2, 'F', 'ID Frames',";
queryText = queryText + " 'S', 'ID Sun', 'ID'),";
queryText = queryText + " 'SP', 'SPARES', 'Others') description ";
queryText = queryText + " FROM mtl_item_categories a,";
queryText = queryText + " mtl_system_items_b msi,";
queryText = queryText + " mtl_categories b,";
queryText = queryText + " ra_customer_trx c,";
queryText = queryText + " ra_customers ar,";
queryText = queryText + " ra_customer_trx_lines d,";
queryText = queryText + " ra_cust_trx_types_all e,";
queryText = queryText + " ra_salesreps f";
queryText = queryText + " WHERE d.inventory_item_id = a.inventory_item_id(+)";
queryText = queryText + " AND msi.inventory_item_id = a.inventory_item_id";
queryText = queryText + " AND msi.organization_id = a.organization_id";
queryText = queryText + " AND a.category_id = b.category_id(+)";
queryText = queryText + " AND ar.customer_id = c.bill_to_customer_id";
queryText = queryText + " and c.customer_trx_id = d.customer_trx_id";
queryText = queryText + " AND msi.inventory_item_id = d.inventory_item_id";
queryText = queryText + " AND c.cust_trx_type_id = e.cust_trx_type_id";
queryText = queryText + " AND f.salesrep_id(+) = c.primary_salesrep_id";
queryText = queryText + " AND ar.primary_salesrep_id = c.primary_salesrep_id";
queryText = queryText + " AND d.line_type = 'LINE'";
queryText = queryText + " AND b.structure_id = 101";
queryText = queryText + " AND TRUNC(c.trx_date) >= ?";
queryText = queryText + " AND TRUNC(c.trx_date) <= ?";
queryText = queryText + " AND a.organization_id = ?";
queryText = queryText + "GROUP BY b.category_id, b.segment1, b.segment2";
queryText = queryText + "ORDER BY b.segment1";
java.lang.System.out.println(queryText);
It is also failing and getting the message as
Table (id = 12):
JP
Re: Null parameter [message #1066177 is a reply to message #1065831] |
Mon, 01 July 2013 12:27 |
When i pass static values to the DataSet it is giving error message as
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.1.1.v20060922-1058
Error Code:data.engine.BirtException
Error Message:A BIRT exception occurred: Error evaluating Javascript expression. Script engine error: TypeError: Cannot read property "length" from undefined (DataSet[Sales].__bm_beforeOpen#87)
Script source: DataSet[Sales].__bm_beforeOpen, line: 1, text:
__bm_beforeOpen(). See next exception for more information.
__bm_beforeOpen()
JP
Re: Null parameter [message #1067059 is a reply to message #1066850] |
Fri, 05 July 2013 15:45 |
Sorry for the delay. I was tied up with things for the BIRT Exchange upgrade.
The error you're getting with the script might be because you're not putting a space in the beginning of what you're adding to the queryText. Try changing:
to
queryText = queryText + " GROUP BY b.category_id, b.segment1, b.segment2";
queryText = queryText + " ORDER BY b.segment1";
Michael
Current Time: Fri Apr 26 18:06:20 GMT 2024
Powered by FUDForum. Page generated in 0.04381 seconds
