Home » Eclipse Projects » Rich Client Platform (RCP) » How to listen theme change event ??
How to listen theme change event ?? [message #1062190] Thu, 06 June 2013 09:09 Go to next message
Hi all,
I want's to listen the theme change event in my eclipse rcp application , i have done the following steps.
1. Created a rcp application (3.x)
2. created extension point "org.eclipse.e4.ui.css.swt.theme" and added two themes in it and set the respective css files for each theme.
3. Added a ViewerPreferencePage, which given the option to change theme.
Now, when i change theme , it work's fine and applied on all the swt controls which i have specified in css file, Actually i want's to listen the event when theme is changed ??,
I have done the following steps.
Register theme.
PlatformUI.getWorkbench().getThemeManager().addPropertyChangeListener(new ThemeChangeHandler());
"ThemeChangeHandler" is the class which implements the "org.eclipse.jface.util.IPropertyChangeListener".
But nothing happens when theme is changed and my listener doesn't fire,
Any help/clue/idea/hint will be appreciated Razz .
SDK
Re: How to listen theme change event ?? [message #1860519 is a reply to message #1062190] Fri, 11 August 2023 16:08 Go to previous messageGo to next message
I ran into a similar need. It seems to me what you did is very reasonable. I don't know why google points to this unanswered question as a first result. So ten years later, here is my approach.
I don't know if this is supported AI. I just listen for a preference store change.
	IPreferenceStore runtimeStore = new ScopedPreferenceStore(InstanceScope.INSTANCE, "org.eclipse.e4.ui.css.swt.theme");
	runtimeStore.addPropertyChangeListener(ev -> {
			if (ev.getProperty().equals("themeid")) {
Re: How to listen theme change event ?? [message #1860737 is a reply to message #1860519] Wed, 30 August 2023 13:17 Go to previous message
This seems to be a more official way:
		import org.eclipse.e4.ui.css.swt.theme.IThemeEngine;
		IEventBroker eb = PlatformUI.getWorkbench().getService(IEventBroker.class);
		eb.subscribe(IThemeEngine.Events.THEME_CHANGED, event -> {
[Updated on: Wed, 30 August 2023 13:18] by Moderator
Previous Topic:Occasional Exit hang/crash
Next Topic:ClassNotFoundException emf.ecore cannot find emf.common
Current Time: Wed Jul 16 14:35:17 EDT 2025
Powered by FUDForum. Page generated in 0.04637 seconds
