Home » Eclipse Projects » Virgo » WAB in plan not deployed
WAB in plan not deployed [message #1061860] Tue, 04 June 2013 08:08
I got several artifacts (bundles and configurations) in a plan which works so far very well. But when I add a WAB to the plan then the plan fails to deploy.
But when I deploy the plan without the WAB and deploy the WAB separately from repository/usr it works. What could be wrong?
All artifacts are in repository/usr.
<plan name="my.plan" version="1.0.7" scoped="false" atomic="true" provisioning="auto" ...>
  <artifact type="bundle" name="my.web.app" />
</plan>
From the log:
[2013-06-04 13:06:27.704] ERROR http-bio-8080-exec-86        org.eclipse.virgo.kernel.deployer.management.StandardDeployer     Exception filtered from JMX invocation org.eclipse.virgo.nano.deployer.api.core.DeploymentException: Web application failed to start
	at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:132)
	at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:271)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:319)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:316)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:252)
	at org.eclipse.virgo.nano.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:140)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1146)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:679)
Caused by: org.eclipse.gemini.web.core.WebApplicationStartFailedException: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/tiles' failed to start. Check the logs for more details.
	at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:137)
	at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:122)
	... 8 common frames omitted
Caused by: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/tiles' failed to start. Check the logs for more details.
	at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:133)
	at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:109)
	... 9 common frames omitted
Thanx in advance.
Mihael
Previous Topic:Use tc Server in Virgo?
Next Topic:Reading XML file from external location
Current Time: Thu Nov 06 09:09:46 EST 2025
Powered by FUDForum. Page generated in 0.03751 seconds
