Home » Eclipse Projects » EclipseLink » Eclipse Data Partition Question
Eclipse Data Partition Question [message #1061781] Tue, 04 June 2013 03:21 Go to next message
Oliver Zhou is currently offline Oliver ZhouFriend
Member
I download the eclipselink data partition example and I can run it successfully. But I have a few questions about it.
1. In the Customer class, I see two partition policy annotation applied:
@ReplicationPartitioning(name="Replicate", connectionPools={"default","node2"})
@HashPartitioning(name="HashPartitionById",
	partitionColumn=@Column(name="ID"), connectionPools={"default","node2"})
I think these two policies looks like incompatible, and in practise, only HashPartitoning policy takes effect.
2. Suppose I would like to issue a query like this:
SELECT c FROM Customer c WHERE c.id < 10 ORDER BY c.id
The result are not globally sorted and only partial sorted by each partition.
Is there a way to use a merge sort algorithm to sort the merged result?
Best wishes,
Oliver
[Updated on: Tue, 04 June 2013 03:22]
Report message to a moderator
Re: Eclipse Data Partition Question [message #1061886 is a reply to message #1061781] Tue, 04 June 2013 14:10 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
1 - You are correct, the ReplicationPartitioning is not used by Customer. It is defined there so it can be used as the session default policy in the persistence.xml, this allows for DDL to be replicated for schema generation.
2 - Two sort across partitions you need to sort in Java. You can just use the Java Collections sort() function.
James : Wiki : Book : Blog : Twitter
Re: Eclipse Data Partition Question [message #1061941 is a reply to message #1061886] Wed, 05 June 2013 03:37 Go to previous message
Member
Okay, thanks
Previous Topic:EclipseLink 2.5 schema generation
Next Topic:DISTINCT and ORDER BY
Current Time: Fri Dec 08 10:24:10 GMT 2023
Powered by FUDForum. Page generated in 0.01869 seconds
