Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] NullPointer while generating ORM Annotated Model
[Texo] NullPointer while generating ORM Annotated Model [message #1061601] Mon, 03 June 2013 04:54 Go to next message
Hi Martin,
I tried to generate an ORM annotated model. I right-clicked o the ecore-file and selected the Generate-ORM-annotated-model-function. The the following error message is shown:
index.php/fa/15133/0/
The other generations (like code generation) work fine. I updated Texo this morning via the update site. My colleague who didn't update Texo can generate the annotations model.
Do you have an idea what could be wrong?
Best regards
Bastian
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061604 is a reply to message #1061601] Mon, 03 June 2013 04:55 Go to previous messageGo to next message
Not good at all, probably a mistake by me, can you somewhere find the stacktrace? Maybe in a log or in an error view?
gr. Martin
On 06/03/2013 10:54 AM, Bastian Wagenfeld wrote:
> Hi Martin,
> Best regards
> Bastian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061605 is a reply to message #1061604] Mon, 03 June 2013 05:08 Go to previous messageGo to next message
Sorry, forgot the stack trace Smile
!ENTRY org.eclipse.ui 4 0 2013-06-03 11:02:45.498
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.IllegalStateException: java.lang.reflect.InvocationTargetException
	at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:87)
	at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:601)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: java.lang.reflect.InvocationTargetException
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
	at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
	at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
	at org.eclipse.ui.internal.progress.ProgressManager$3.run(ProgressManager.java:960)
	at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:995)
	at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:970)
	at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1166)
	at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:80)
	... 29 more
Caused by: java.lang.IllegalStateException: java.lang.NullPointerException
	at org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:92)
	at org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromURI(GenerateAnnotationModel.java:101)
	at org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromUris(GenerateAnnotationModel.java:47)
	at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:128)
	at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:108)
	at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction$1.execute(BaseGenerateAction.java:76)
	at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
	at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: java.lang.NullPointerException
	at java.io.File.<init>(File.java:251)
	at org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:69)
	... 9 more
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061616 is a reply to message #1061605] Mon, 03 June 2013 05:57 Go to previous messageGo to next message
I am doing an new build right now, which hopefully solves this..
gr. Martin
On 06/03/2013 11:08 AM, Bastian Wagenfeld wrote:
> Sorry, forgot the stack trace :)
> !STACK 0
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> ... 29 more
> at
> at
> at
> at
> ... 9 more
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061632 is a reply to message #1061616] Mon, 03 June 2013 07:19 Go to previous messageGo to next message
I published a new build.
gr. Martin
> gr. Martin
>> !STACK 0
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> ... 29 more
>> at
>> at
>> at
>> at
>> ... 9 more
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061642 is a reply to message #1061632] Mon, 03 June 2013 07:43 Go to previous messageGo to next message
Hi Martin,
I'm sorry, but this had no effect. I just installed the new version, deleted all older plugins, restarted Eclipse, but still get the following message:
!ENTRY org.eclipse.ui 4 0 2013-06-03 13:40:25.680
!STACK 0
	at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:86)
	at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.run(BaseGenerateAction.java:79)
	... 29 more
Caused by: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.NullPointerException
	at org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromModelFile(GenerateAnnotationModel.java:106)
	at org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromModelFiles(GenerateAnnotationModel.java:48)
	at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:127)
	at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction.generate(BaseGenerateAction.java:107)
	at org.eclipse.emf.texo.eclipse.popup.actions.BaseGenerateAction$1.execute(BaseGenerateAction.java:75)
	at org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:98)
	at org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromModelFile(GenerateAnnotationModel.java:104)
	... 8 more
	at org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:70)
	... 9 more
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061670 is a reply to message #1061642] Mon, 03 June 2013 08:35 Go to previous messageGo to next message
Hi Bastian,
And I need to say sorry again :-(, I found that to, in the meantime I have done another build which should really solve
this, I published it 5 mins ago, this latest build hopefully helps...
gr. Martin
On 06/03/2013 01:43 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> !STACK 0
> ... 29 more
> at
> at
> at
> at
> ... 8 more
> at
> ... 9 more
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061675 is a reply to message #1061670] Mon, 03 June 2013 09:02 Go to previous messageGo to next message
Hi Martin,
I'm so sorry to say it again, but it doesn't work in this version.
I'll post the stack trace again, since at least the last line changed.
Maybe I could change anything in the ecore to make it work?
!ENTRY org.eclipse.ui 4 0 2013-06-03 14:55:39.549
!STACK 0
	... 29 more
	at org.eclipse.emf.texo.eclipse.popup.actions.GenerateAnnotationModel.generateFromModelFile(GenerateAnnotationModel.java:107)
	at org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:95)
	... 8 more
	at org.eclipse.emf.texo.annotations.AnnotationModelSuffixHandler.createAnnotationsModelURIWithSuffix(AnnotationModelSuffixHandler.java:48)
	at org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:71)
	... 9 more
Thanks for your fast reactions!
Bastian
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061677 is a reply to message #1061675] Mon, 03 June 2013 09:14 Go to previous messageGo to next message
Hi Martin,
it seems, I cannot generate ORM-files, too. I'll post the stack trace which looks different. Maybe this could help.
!ENTRY org.eclipse.ui 4 0 2013-06-03 15:13:17.143
!STACK 0
	... 29 more
	at org.eclipse.emf.texo.orm.annotator.ORMGenerator.generateFromModelFile(ORMGenerator.java:195)
	at org.eclipse.emf.texo.orm.annotator.ORMGenerator.generateFromModelFiles(ORMGenerator.java:177)
	at org.eclipse.emf.texo.orm.annotator.ORMGenerator.storeORM(ORMGenerator.java:221)
	at org.eclipse.emf.texo.orm.annotator.ORMGenerator.generateStoreORM(ORMGenerator.java:211)
	at org.eclipse.emf.texo.orm.annotator.ORMGenerator.generateFromModelFile(ORMGenerator.java:193)
	... 8 more
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061737 is a reply to message #1061677] Mon, 03 June 2013 12:37 Go to previous messageGo to next message
Hi Bastian,
With me it works fine, so it must be something specific to your dev project which I am missing.
Can you email me your dev project?
gr. Martin
On 06/03/2013 03:14 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> !STACK 0
> ... 29 more
> ... 8 more
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1061791 is a reply to message #1061737] Tue, 04 June 2013 01:24 Go to previous messageGo to next message
I just sent you a mail with my identifiable model.
Bastian
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1063916 is a reply to message #1061791] Sat, 15 June 2013 07:57 Go to previous messageGo to next message
just replace in class "org.eclipse.emf.texo.orm.annotator.ORMGenerator" in line 191 the "URI.createURI(modelFile.getLocation().toString()).trimSegments(1);" by "URI.createFileURI(...);" and it works.
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1067900 is a reply to message #1063916] Thu, 11 July 2013 03:54 Go to previous messageGo to next message
I am using Texo 0.1.0.v201306031205 (the last version) and I can not generate the ORM file. Maybe there is one more error?
I am attaching an example and the log file
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
	... 30 more
	... 8 more
	... 9 more
  • Attachment: test2.ecore
    (Size: 0.76KB, Downloaded 194 times)
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1068111 is a reply to message #1067900] Fri, 12 July 2013 05:05 Go to previous messageGo to next message
Hi Gabriele,
I published a new build which should print more information in the stack trace why this fails.
Can you retry it for me with the latest build?
gr. Martin
> ... 30 more
> ... 8 more
> ... 9 more
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1068135 is a reply to message #1068111] Fri, 12 July 2013 06:57 Go to previous messageGo to next message
Hi Martin,
I right-clicked the ecore-file and selected the Generate-ORM-annotated-model-function, but it doesn't work in this version.
The error occurs for any model
Exception:
	at com.nterpriseapps.ide.modelgenerator.internal.ORMAnnotatedModelGeneratorCustom.run(ORMAnnotatedModelGeneratorCustom.java:18)
	... 31 more
Caused by: java.lang.IllegalStateException: java.lang.IllegalStateException: Exception for modelFile: /com.nterpriseapps.mdl.test/mdl/test2.ecore epackage test epackage uri : platform:/resource/com.nterpriseapps.mdl.test/mdl/test2.ecore
Caused by: java.lang.IllegalStateException: Exception for modelFile: /com.nterpriseapps.mdl.test/mdl/test2.ecore epackage test epackage uri : platform:/resource/com.nterpriseapps.mdl.test/mdl/test2.ecore
	... 8 more
	... 9 more
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1068138 is a reply to message #1068135] Fri, 12 July 2013 07:37 Go to previous messageGo to next message
Hi Gabriele,
Yes the new build does not fix it, it prints some more information. Let me research further based on this new info.
gr. Martin
On 07/12/2013 12:57 PM, gabriele boldrin wrote:
> Hi Martin,
> I tried to generate an ORM annotated model. I right-clicked the ecore-file and selected the
> Exception:
> at
> ... 31 more
> at
> at
> at
> at
> ... 8 more
> at
> at
> ... 9 more
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1070569 is a reply to message #1061601] Thu, 18 July 2013 04:30 Go to previous messageGo to next message
Hi all,
just had the same issue.
I could resolve it quick-and-dirty with the following change in AnnotationModelGenerator:
line 70:
-       final URI fileUri = URI.createURI(modelFile.getParent().getLocation().toOSString());
-       final File file = new File(AnnotationModelSuffixHandler.createAnnotationsModelURIWithSuffix(fileUri, suffix)
-           .toFileString());
+      final URI fileUri = URI.createFileURI(modelFile.getLocation().toOSString());
+      final File file = new File(fileUri.toString()).getParentFile();
Roland
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1070671 is a reply to message #1070569] Thu, 18 July 2013 08:35 Go to previous messageGo to next message
Hi Roland,
Thanks for sharing (this one has bugged me for a while...), looking again at the code I think it should be changed. Can
you try/test the attached diff? Does it help?
Thanks again Roland!
gr. Martin
On 07/18/2013 10:30 AM, R. Oldenburg wrote:
> Hi all,
> line 70:
> - .toFileString());
> Roland
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1073658 is a reply to message #1070671] Thu, 25 July 2013 04:49 Go to previous messageGo to next message
Hi Martin,
Roland told me to test the attached diff and it seems like that there is no NPE anymore.
I can generate all of the possible models without problems.
grotjes/Regards Smile
Thorben
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1073766 is a reply to message #1073658] Thu, 25 July 2013 08:59 Go to previous messageGo to next message
Hi Thorben, great to hear, thanks for trying. The latest build/publication solves this problem.
gr. Martin
On 07/25/2013 01:56 PM, Thorben Ruthke wrote:
> Hi Martin,
> grotjes/Regards :)
> Thorben
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1074136 is a reply to message #1073658] Fri, 26 July 2013 03:17 Go to previous messageGo to next message
Hi Martin,
I tried the new release but the generation ORM file does not work.
!ENTRY org.eclipse.ui 4 0 2013-07-26 08:52:05.943
!STACK 0
	... 30 more
Caused by: java.lang.IllegalStateException: java.lang.IllegalStateException: Exception for modelFile: /com.nterpriseapps.mdl.adbk.core/mdl/adbk.ecore epackage adbk epackage uri : platform:/resource/com.nterpriseapps.mdl.adbk.core/mdl/adbk.ecore
Caused by: java.lang.IllegalStateException: Exception for modelFile: /com.nterpriseapps.mdl.adbk.core/mdl/adbk.ecore epackage adbk epackage uri : platform:/resource/com.nterpriseapps.mdl.adbk.core/mdl/adbk.ecore
	at org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:93)
	... 8 more
	at org.eclipse.emf.texo.generator.AnnotationModelGenerator.createStoreAnnotationModel(AnnotationModelGenerator.java:68)
	... 9 more
Looking at the code, the problem should be here:
public void createStoreAnnotationModel(EPackage ePackage, String suffix, EPackage annotationEPackage, IFile modelFile) {
    try {
      final ResourceSet resourceSet = ePackage.eResource().getResourceSet();
      final URI fileUri = URI.createURI(modelFile.getLocation().toOSString());
      final File file = new File(AnnotationModelSuffixHandler.createAnnotationsModelURIWithSuffix(fileUri, suffix).toFileString());
      final Resource resource;
      if (file.exists()) {
        resource = resourceSet.getResource(fileUri, true);
      } else {
        resource = resourceSet.createResource(fileUri);
        final String encoding = ((XMLResource) ePackage.eResource()).getEncoding();
        ((XMLResource) resource).setEncoding(encoding);
I have corrected the code in this way:
public void createStoreAnnotationModel(EPackage ePackage,String suffix, EPackage annotationEPackage,IFile modelFile) {
// TODO Auto-generated method stub
try {
	final org.eclipse.emf.common.util.URI fileUri = org.eclipse.emf.common.util.URI.createFileURI(modelFile.getLocation().toOSString()); //change
	final org.eclipse.emf.common.util.URI fileOrmUri = AnnotationModelSuffixHandler.createAnnotationsModelURIWithSuffix(fileUri,suffix);//change
	final File file = new File(fileOrmUri.toFileString());//change
	} else {
		resource = resourceSet.createResource(fileOrmUri);//change
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1074392 is a reply to message #1074136] Fri, 26 July 2013 12:35 Go to previous messageGo to next message
Hi Gabriele, Thorben,
I published a new build which should hopefully solve this problem...
Can you retry?
gr. Martin
On 07/26/2013 09:17 AM, gabriele boldrin wrote:
> Hi Martin,
> !STACK 0
> ... 30 more
> at
> at
> at
> at
> ... 8 more
> at
> at
> ... 9 more
> try {
> } else {
> @Override
> try {
> } else {
The Netherlands
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1075257 is a reply to message #1074392] Mon, 29 July 2013 02:05 Go to previous messageGo to next message
Hi Martin,
I tried to generate the eclipselink-orm this morning after installing the newest version and deleting the old jars:
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:826)
	at org.eclipse.jface.window.Window.open(Window.java:802)
	at org.eclipse.ui.internal.views.log.EventDetailsDialog.open(EventDetailsDialog.java:180)
	at org.eclipse.ui.internal.views.log.EventDetailsDialogAction.run(EventDetailsDialogAction.java:98)
	at org.eclipse.ui.internal.views.log.LogView$15.doubleClick(LogView.java:536)
	at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:845)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:843)
	at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1477)
	at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1246)
	at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:249)
	at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:246)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:307)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:331)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	... 48 more
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2345)
	... 8 more
Changing line 191 from
to
URI.createFileURI(modelFile.getLocation().toString()).trimSegments(1);
works for me and Texo creates annotated models as well as orms Smile
Best regards
Bastian
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1075373 is a reply to message #1075257] Mon, 29 July 2013 06:13 Go to previous messageGo to next message
Hi Martin,
you just uploaded a new version, right?! So in this version everything's working fine Smile
Thank you a lot!
Bastian
Re: [Texo] NullPointer while generating ORM Annotated Model [message #1075382 is a reply to message #1075373] Mon, 29 July 2013 06:32 Go to previous message
:-) Yes I was about to ping you on this version, I made the last change you proposed.
Thanks for your patience in this, good to hear that it works now :-)
gr. Martin
On 07/29/2013 12:13 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> you just uploaded a new version, right?! So in this version everything's working fine :)
> Thank you a lot!
> Bastian
The Netherlands
Previous Topic:EMF customizing element delete command
Next Topic:Remote cdo server
Current Time: Sat Sep 20 22:19:44 EDT 2025
Powered by FUDForum. Page generated in 0.07352 seconds
