| PartSashContainer inside Part [message #1061426] |
Fri, 31 May 2013 10:48  |
I have a Part which resides under the PartSashContainer -> PartStack hierarchy. I need to put another PartSashContainer within this part so then I can put two other Parts in it and display them both at the same time (PartSashContainer -> PartStack -> PartSashContainer -> (Part x 2)). Is there a way of doing this by using the e4xmi? As each part has its own popup menu and those have complex 'visible-when' rules, I'd like to do it by using the e4xmi instead of the WindowBuilder if possible.
Thanks in advance,
O.
[Updated on: Wed, 06 November 2013 04:48] by Moderator
FUDForum. Page generated in 0.04326 seconds
