Strange problems with missing SuperPOM [message #1061158] |
Thu, 30 May 2013 09:45 |
Fabrizio Giudici Messages: 21 Registered: May 2013 Location: Italy |
Hi there.
Even though I've not written here or in the mailing list for months, possibly years, I've been using Hudson for a lot of time and no major troubles. I use it in my software factory and it supports quite a number of jobs (several dozens). I use it with Maven and the relevant configuration for understanding the problem I'm submitting to your attention is explained below:
1. I have my own Nexus instance running on a server (let's call it services/nexus). It works as a proxy towards Central Repo and other public repos, and includes a local hosted repo for a bunch of artifacts that are not published elsewhere (I call it the 3rd party repo).
2. Another Nexus runs on the same server where Hudson runs (let's call it hudson/nexus). It is used as a local cache of artifacts, for speeding up Nexus jobs (some of them always start with a clean local repo), as well as a local snapshot repository that, being on the same host, works faster - it is used when a job completes and triggers another dependent job which is supposed to consume some snapshots produced by the former. For years, the configuration of hudson/nexus was a copy of services/nexus, plus a proxy for the 3rd party repo. With this configuration, no major problems in the past. I've recently changed it so it's simplified: now hudson/nexus is just a proxy towards services/nexus, plus the local snapshot repo.
It happens that most jobs are fine, while a few deterministically fail because they can't resolve the SuperPOM:
Started by user fabrizio.giudici
$ hg clone --rev default --noupdate ssh://hg@bitbucket.org/tidalwave/capecanaveral-src <hudson.tidalwave.it/hudson/job/CapeCanaveral_Compile_and_Test_and_Deploy_Local_Snapshot/ws/>
adding changesets
adding manifests
adding file changes
added 61 changesets with 577 changes to 316 files
[workspace] $ hg update --rev default
103 files updated, 0 files merged, 0 files removed, 0 files unresolved
[workspace] $ hg log --rev . --template {node}
[workspace] $ hg log --rev . --template {rev}
[workspace] $ hg log --rev 803a4c7658056131f748ed8202afc804953d4c98
[workspace] $ hg log --template "<changeset node='{node}' author='{author|xmlescape}' rev='{rev}' date='{date}'><msg>{desc|xmlescape}</msg><added>{file_adds|stringify|xmlescape}</added><deleted>{file_dels|stringify|xmlescape}</deleted><files>{files|stringify|xmlescape}</files><parents>{parents}</parents></changeset>\n" --rev default:0 --follow --prune 803a4c7658056131f748ed8202afc804953d4c98 --encoding UTF-8 --encodingmode replace
Found mavenVersion 3.0.4 from file jar:file:/home/tomcat/Workspaces/Hudson/tools/Maven_3.0.4/lib/maven-core-3.0.4.jar!/META-INF/maven/org.apache.maven/maven-core/pom.properties
Deleting old artifacts from #45
Parsing POMs
ERROR: Failed to parse POMs
org.apache.maven.project.ProjectBuildingException: Some problems were encountered while processing the POMs:
[FATAL] Non-resolvable parent POM: Could not find artifact it.tidalwave.superpom:superpom:pom:2.10 and 'parent.relativePath' points at wrong local POM @ line 6, column 13
at org.apache.maven.project.DefaultProjectBuilder.build(DefaultProjectBuilder.java:325)
at hudson.maven.MavenEmbedder.buildProjects(MavenEmbedder.java:360)
at hudson.maven.MavenEmbedder.readProjects(MavenEmbedder.java:330)
at hudson.maven.MavenModuleSetBuild$PomParser.invoke(MavenModuleSetBuild.java:1197)
at hudson.maven.MavenModuleSetBuild$PomParser.invoke(MavenModuleSetBuild.java:1040)
at hudson.FilePath.act(FilePath.java:791)
at hudson.FilePath.act(FilePath.java:773)
at hudson.maven.MavenModuleSetBuild$RunnerImpl.parsePoms(MavenModuleSetBuild.java:733)
at hudson.maven.MavenModuleSetBuild$RunnerImpl.doRun(MavenModuleSetBuild.java:541)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:434)
at hudson.model.Run.run(Run.java:1390)
at hudson.maven.MavenModuleSetBuild.run(MavenModuleSetBuild.java:414)
at hudson.model.ResourceController.execute(ResourceController.java:82)
at hudson.model.Executor.run(Executor.java:137)
[WARNINGS] Skipping publisher since build result is FAILURE
Archiving artifacts
Description set:
TestNG Reports Processing: START
Looking for TestNG results report in workspace using pattern: **/target/**/testng-results.xml
Did not find any matching files.
Build does not meet criteria for workspace archiving - result is not at least UNSTABLE.
The heading of the involved Master POM is:
<project xmlns="maven.apache.org/POM/4.0.0" xmlns:xsi="www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="maven.apache.org/POM/4.0.0 maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<parent>
<groupId>it.tidalwave.superpom</groupId>
<artifactId>superpom</artifactId>
<version>2.10</version>
</parent>
Needless to say that it.tidalwave.superpom:superpom:pom:2.10 has been published to Central Repo, it is available even at hudson/nexus and in fact is used by most of the other jobs running fine on the same Hudson instance. All the configurations of those jobs are *identical* since they are automatically generated starting from a template, only changing things such as the SCM URL, the name of the job, the JDK and such. They all use hudson/nexus as a repo mirror for anything.
I've been trying to understand this problem for some days, but now I think I need help. If you need more details about the configuration of the job, it is available at the URL below and the configuration page should be available in read-only mode to everybody.
hudson (dot) tidalwave (dot) it/hudson/job/CapeCanaveral_Compile_and_Test_and_Deploy_Local_Snapshot/
I'm not filing a bug yet since I can't tell whether it's a problem of mine, or a real Hudson bug.
Thanks.
Fabrizio Giudici - Java Architect @ Tidalwave s.a.s.
"We make Java work. Everywhere."
Re: Strange problems with missing SuperPOM [message #1061227 is a reply to message #1061220] |
Thu, 30 May 2013 15:34 |
Thanks for the suggestion. I tried it, but it only changed a detail in the error message:
17:29:00 Parsing POMs
17:29:00 ERROR: Failed to parse POMs
17:29:00 org.apache.maven.project.ProjectBuildingException: Some problems were encountered while processing the POMs:
17:29:00 [FATAL] Non-resolvable parent POM: Could not find artifact it.tidalwave.superpom:superpom:pom:2.10 and 'parent.relativePath' points at no local POM @ line 6, column 13
17:29:00
17:29:00 at org.apache.maven.project.DefaultProjectBuilder.build(DefaultProjectBuilder.java:325)
17:29:00 at hudson.maven.MavenEmbedder.buildProjects(MavenEmbedder.java:360)
17:29:00 at hudson.maven.MavenEmbedder.readProjects(MavenEmbedder.java:330)
17:29:00 at hudson.maven.MavenModuleSetBuild$PomParser.invoke(MavenModuleSetBuild.java:1197)
17:29:00 at hudson.maven.MavenModuleSetBuild$PomParser.invoke(MavenModuleSetBuild.java:1040)
17:29:00 at hudson.FilePath.act(FilePath.java:791)
17:29:00 at hudson.FilePath.act(FilePath.java:773)
17:29:00 at hudson.maven.MavenModuleSetBuild$RunnerImpl.parsePoms(MavenModuleSetBuild.java:733)
17:29:00 at hudson.maven.MavenModuleSetBuild$RunnerImpl.doRun(MavenModuleSetBuild.java:541)
17:29:00 at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:434)
17:29:00 at hudson.model.Run.run(Run.java:1390)
17:29:00 at hudson.maven.MavenModuleSetBuild.run(MavenModuleSetBuild.java:414)
17:29:00 at hudson.model.ResourceController.execute(ResourceController.java:82)
17:29:00 at hudson.model.Executor.run(Executor.java:137)
17:29:00 [WARNINGS] Skipping publisher since build result is FAILURE
I'll apply the change to all my projects, in any case, since I think it's formally more correct. But doesn't solve my current problem. Is there any place where I can see in a log file the details about POM resolving?
Thanks.
[Updated on: Thu, 30 May 2013 15:35] Report message to a moderator
Re: Strange problems with missing SuperPOM [message #1061308 is a reply to message #1061291] |
Fri, 31 May 2013 06:46 |
-X is the first thing I tried - but it doesn't work here. I mean, I get the error before any typical output with -X is produced. When the thing works, I see that there are some POM download logs *before* this section appears:
18:40:18 <===[HUDSON REMOTING CAPACITY]===>channel started
18:40:20 Executing Maven: -B -f /home/tomcat/Workspaces/Hudson/jobs/CapeCanaveral_Compile_and_Test_and_Deploy_Local_Snapshot/workspace/pom.xml -Dmaven.repo.local=/home/tomcat/Workspaces/Hudson/jobs/CapeCanaveral_Compile_and_Test_and_Deploy_Local_Snapshot/workspace/.repository -X -B -fae clean install clirr:check -Pgenerate-revision-id -DtestReportsDirectory=target/surefire-reports/plain -Dtestset.cached.folder=/tmp/TestCacheFolder -DtestFailureIgnore=true
18:40:21 Apache Maven 3.0.4 (r1232337; 2012-01-17 09:44:56+0100)
18:40:21 [INFO] Maven home: /home/tomcat/Workspaces/Hudson/tools/Maven_3.0.4
18:40:21 Java version: 1.6.0_24, vendor: Sun Microsystems Inc.
18:40:21 Scanning for projects...Java home: /home/tomcat/Workspaces/Hudson/tools/JDK_1.6.0_24/jre
18:40:21 Default locale: en_US, platform encoding: UTF-8
which means that when the error occurs because the superpom is not found, it happens before Maven is actually started, with the -X option. Is it something related to the Maven embedded customization by Hudson? This is independent of "Resolve Dependencies during Pom parsing" - normally I check this option, but the behaviour doesn't change with this option disabled.
[Updated on: Fri, 31 May 2013 06:47] Report message to a moderator
Re: Strange problems with missing SuperPOM [message #1062152 is a reply to message #1061936] |
Thu, 06 June 2013 09:27 |
"One more thing, I guess you build super-pom and it is in your local repo right not in the Nexus correct?"
It's not correct. The super-pom in this case is in a separated project and already deployed. Usually it's even a RELEASE, but in this moment I'm doing some large refactoring, so it's a SNAPSHOT itself. But, as I said, previously deployed. At the moment I'm not using slaves, only a single instance.
FUDForum. Page generated in 0.04184 seconds
