Using properties file pairs in testing [message #1060868] |
Tue, 28 May 2013 14:42  |
I need to test an rcp wizard using Jubula. I need some help to write Jubula test cases in the following 2 scenarios:
1- How to create a test case that matches a checkbox value against the initial value read from a properties file.
2- How to check whether one GUI component value matches another one's value, say a textarea, match against the value of "input text" field?
Thank you!
Re: Using properties file pairs in testing [message #1061123 is a reply to message #1060868] |
Thu, 30 May 2013 03:15  |
For the second step, I'd recommend doing the cheat sheets in Jubula. They give you an overview of how to create a basic test, and that is one of the steps involved.
For the first step, I'm not 100% sure how values from properties files can be dynamically read in. If you're using Excel, that is a possibility. You could also use an execute external action action to read the value / save it into a variable. Just some thoughts.
HTH,
Alex
FUDForum. Page generated in 0.03247 seconds
