Re: Error 7009 [message #1064708 is a reply to message #1064601] |
Thu, 20 June 2013 15:27 |
I have the same problem!
In fact, I have created a project with a test suite with a specific path to my AUT.
Now I need to change the path to another location (where Hudson build my AUT, to execute my test each day on the new build). When I try to execute my test suite on my AUT in the new path I have the error "An error occurred. Reason : 7009 Test Execution Error" and when I check the details I have the following description : "The component name "8ab6b08d1a4d08f3011a4d09a496002a" in Test Case "ub_mbr_selectEntry_byTextpath" in Test Step "select menu entry by textpath" can not be resolved.
Please make sure that all of your reused Projects are currently available in the database and not marked as missing in the Test Case Browser."
Have you any idea to solve the problem?
Thank you for any help!
Elise Ruelle
ALL4TEC
Re: Error 7009 [message #1065077 is a reply to message #1060734] |
Mon, 24 June 2013 09:09 |
I find the solution for me. i don't know if it could help you but may be...
In my case, the problem was the version of the plugin for Jubula. When the plugin for Jubula is added during the build the version was not the good one. It's a version of 2011...when I change the version it has no problem.
Thank you
Elise Ruelle
ALL4TEC
Re: Error 7009 [message #1066358 is a reply to message #1066352] |
Tue, 02 July 2013 10:19 |
If you haven't done already you might try the new version released last week. We fixed a bug in the start/restart/connect code which might have lead to dropped executions when using testjobs.
- Achim
Re: Error 7009 [message #1176036 is a reply to message #1065307] |
Fri, 08 November 2013 04:50 |
I am also getting the same bug with Jubula 2.2.
I have around 30 test suite in my test job. And I am working with 2 aut agent.
OS-windows 7 64 bit sp1,
In middle of test i am switching between two aut using alt_shift_tab
But some times Error 7009:could connect to aut come at 1st testsuite it shelf and some time it is coming on the verge of end.This is really embarrassing error i am getting very often while executing my testjob. Please have a look at the log files.
Frequency of bug -Every time
This is the log-
2013-11-07 12:01:11.435 from rc_rcp:[Connection.ReaderThread:Socket[addr=NXL28248.xxx.xxx.com/165.114.45.118,port=49713,localport=49714]] ERROR o.eclipse.jubula.rc.common.AUTServer - connecting to NXL28248.*******:49831 failed()
From client:-2013-11-07 12:01:00.423 [Worker-1] ERROR o.e.j.c.c.c.AUTConnection - Connection to AUT could not be established.
2013-11-07 12:01:00.460 [Worker-1] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error occurred: Could not connect to AUT: AUT_TRANSMITTER
Here AUTTransmitter is my AUT name
[Updated on: Fri, 15 May 2015 04:17] Report message to a moderator
FUDForum. Page generated in 0.04169 seconds
