Home » Modeling » M2T (model-to-text transformation) » XML2SQLtext
XML2SQLtext [message #1060554] Sun, 26 May 2013 14:07 Go to next message
I have a problem when i generate my ATL file is:
query XML2Text = XML!Root.allInstances()->asSequence().first().toString2('').writeTo('./projetSQL/example5.sql');
helper context XML!Element def: toString2(indent : String) : String =
let na : Sequence(XML!Node) = self.children->select(e | not e.oclIsKindOf(XML!Attribute)) in
let a : Sequence(XML!Node) = self.children->select(e | e.oclIsKindOf(XML!Attribute)) in
'insert into ' + self.name +' values('+
a->iterate(e; acc : String = '"' |
acc + e.toString2()+'",'
if na->size() > 0
then ''
+ na->iterate(e; acc : String = '' |
acc +
if e.oclIsKindOf(XML!Text)
then ''
else '\r\n'
endif+
e.toString2()
else ''
endif;
helper context XML!Attribute def: toString2() : String =
self.value ;
helper context XML!Text def: toString2() : String =
self.value;
and my result is like this:
insert into m values()
insert into composant values("F","01","6894f6ab",)
but I do not want it to take into consideration the root and leaves me something like this:
insert into composant values('F','01','6894f6ab')
I didn't found how to do the apostrophe.
thank you,
Samar
Re: XML2SQLtext [message #1060555 is a reply to message #1060554] Sun, 26 May 2013 14:55 Go to previous message
OCL 2.3 introduced the standard Java escape sequences (with the
exception of octal) so you could try \'.
However ATL uses a non-standard OCL vagely based on OCL 2.0, so it may
not support it; however most likely ATL like many other OCL
implementations anticipated the obvious specification evolution.
Ed Willink
On 26/05/2013 19:07, samar sousou wrote:
> query XML2Text =
> if na->size() > 0
> then ''
> acc +
> then ''
> else '\r\n'
> endif+
> e.toString2()
> else ''
> endif;
> self.value ;
> self.value;
> thank you,
> Samar
Previous Topic:Create List in template
Next Topic:[Acceleo] Which Acceleo version do I need for UML 1.3
Current Time: Sat Oct 25 03:07:05 EDT 2025
Powered by FUDForum. Page generated in 0.03541 seconds
