| Virgo does not start up on Windows 2008 64 bit Virtual machine- Timeout exception thrown [message #1060459] |
Fri, 24 May 2013 15:20 |
I am running into an issue where virgo does not start up on a windows 2008 64 bit virtual machine, I am seeing the following error in the logs (have the full logs in the attachment). I have a value of 1200 in the timeout in wrapper.conf:
wrapper.startup.timeout=1200
There is a value of 600 in org.eclipse.virgo.kernel.properties:
deployer.timeout= 600
After deleting the work, serviceability folders and starting again, virgo starts up fine. But it does not start up the first time after restart of the Virtual machine, appreciate any ideas on what is causing the issue?
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.virgo.kernel.userregion.internal.Activator.start() of bundle org.eclipse.virgo.kernel.userregion.
[2013-05-22 14:13:41.844] ERROR WrapperSimpleAppMain System.err at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleConte... Caused by: java.util.concurrent.TimeoutException: org.eclipse.virgo.repository.Repository
[2013-05-22 14:13:41.847] ERROR WrapperSimpleAppMain System.err at org.eclipse.virgo.kernel.userregion.internal.Activator.getPotentiallyDelayedService(Activator.java:352)
[2013-05-22 14:13:41.847] ERROR WrapperSimpleAppMain System.err at org.eclipse.virgo.kernel.userregion.internal.Activator.start(Activator.java:101)
[2013-05-22 14:13:41.848] ERROR WrapperSimpleAppMain System.err at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
[2013-05-22 14:13:41.848] ERROR WrapperSimpleAppMain System.err at java.security.AccessController.doPrivileged(Native Method)
[2013-05-22 14:13:41.849] ERROR WrapperSimpleAppMain System.err at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
[2013-05-22 14:13:41.849] ERROR WrapperSimpleAppMain System.err ... 23 more
Attachment: log_64_2.log
(Size: 106.67KB, Downloaded 215 times)
FUDForum. Page generated in 0.08488 seconds
