Home » Modeling » M2T (model-to-text transformation) » [Acceleo] "Launch Acceleo Application" fails
[Acceleo] "Launch Acceleo Application" fails [message #1060080] |
Thu, 23 May 2013 01:41 |
Rain B Messages: 1 Registered: May 2013 |
Junior Member |
This is not a lazyweb post. I have been trying to solve this since the weekend, and have exhausted my google fu and jiggery-pokery powers. Before I file a bug, I'm hoping someone here has a solution or explanation for me.
This is reproducible for me on a fresh install with nothing added except Acceleo and UML2 Extender SDK. I am listing every single last thing that I did below, because I want it to be crystal clear that this occurs on a virgin install, with no weird or non-standard plugins or other foolishness, with files that are generated by Eclipse and untouched by me.
The salient error part is coloured red so you can pick it out of the wall of text. Never let it be said that I did not provide enough information.
Step-by-step:
Untar eclipse-jee-juno-SR2-linux-gtk.tar.gz
Launch Eclipse
Set new (to be created by IDE) workspace in dialog
Go to Help->Install New Software...
Type in "acceleo" in filter box, select "-All Available Sites-", continue through to installation and restart of IDE
Install UML2 Extender SDK, restart IDE
Open Perspective->Acceleo
File->New->Acceleo Project
Configure project, using JavaSE-1.7 execution environment, metamodel = http://www.eclipse.org/uml2/4.0.0/UML, module name = generate, type = Class, "Generate File" and "Main Template" ticked
Open generate.mtl, it has the following contents:
[comment encoding = UTF-8 /]
[module generate('http://www.eclipse.org/uml2/4.0.0/UML')]
[template public generateElement(aClass : Class)]
[comment @main/]
[file (aClass.name, false, 'UTF-8')]
[/file]
[/template]
(NOTE: I get the exact same failure even if I bother to fill in some barebones data and am absolutely certain that it is syntactically correct, so I'm just going to stop you right there if you were going to say "hey, why don't you try editing that IDE-generated file?". It is also entirely possible that I may have thought it might be a good idea to try all of this using the IDE-provided "UML to Java" example. It is certainly a fact that the same failure occurs when I do that. I have been at this for days.)
Right-click on generate.mtl in Package Explorer, Run As->Launch Acceleo Application
Set model and target in the Run Configuration dialog, click Apply, click Run
Sweet! A dialog box entitled, helpfully, "Problem Occurred":
'Launching Generate' has encountered a problem.
An internal error occurred during: "Launching Generate".
Yes, there's a Details button, but below you can see the log entry generated, which is actually the details (the Details button just gives you a summary... speaking of syntax errors).
END step-by-step
Nothing I do will get me past this stage. As mentioned, I've generated Example projects and ended up at the same place - only the names have changed.
And now, lots of lovely relevant technical information.
From "About Eclipse":
Eclipse Java EE IDE for Web Developers.
Version: Juno Service Release 2
Build id: 20130225-0426
Output of File->Export...->Installed Software Items to File
These are the only items that I have installed. Everything else in plugins was in the tin when I opened it, and as you know that isn't listed when you export.
Package: org.eclipse.acceleo.source.feature.group
Version: 3.3.3.201303130933
Package: org.eclipse.acceleo.runtime.source.feature.group
Package: org.eclipse.acceleo.feature.group
Name: Acceleo Documentation
Package: org.eclipse.acceleo.doc.feature.group
Package: org.eclipse.acceleo.examples.feature.group
Package: org.eclipse.acceleo.runtime.feature.group
Package: org.eclipse.acceleo.sdk.feature.group
Name: Acceleo UI capability definitions
Package: org.eclipse.acceleo.ui.capabilities.feature.group
Name: Eclipse IDE for Java EE Developers
Package: epp.package.jee
Version: 1.5.2.20130211-1820
Name: UML2 Extender SDK
Package: org.eclipse.uml2.sdk.feature.group
Version: 4.0.2.v20130114-0902
Logged error (unfortunately I don't know how to make the IDE cough up any more of the stack trace... anyone?):
eclipse.buildId=M20130204-1200
java.version=1.7.0_21
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.jee.product
Error
Wed May 22 15:49:33 PDT 2013
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.xml.sax.SAXParseExceptionpublicId: file:/home/rain/testing/jee-workspace/org.eclipse.acceleo.module.sample/src/org/eclipse/acceleo/module/sample/main/ generate.mtl; systemId: file:/home/rain/testing/jee-workspace/org.eclipse.acceleo.module.sample/src/org/eclipse/acceleo/module/sample/main/generate.mtl; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:361)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.initialize(AbstractAcceleoGenerator.java:457)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoLaunchOperation.run(AcceleoLaunchOperation.java:124)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginLaunchingStrategy. launch(AcceleoPluginLaunchingStrategy.java:259)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginLaunchingStrategy. launch(AcceleoPluginLaunchingStrategy.java:161)
at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchDelegate.launch(AcceleoLaunchDelegate.java:51)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:855)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:704)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1047)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1251)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: org.xml.sax.SAXParseExceptionpublicId: file:/home/rain/testing/jee-workspace/org.eclipse.acceleo.module. sample/src/org/eclipse/acceleo/module/sample/main/generate.mtl; systemId: file:/home/rain/testing/jee-workspace/org. eclipse.acceleo.module.sample/src/org/eclipse/acceleo/module/sample/main/generate.mtl; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:198)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:441)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:368)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1388)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:998)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:607)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl. scanDocument(XMLDocumentFragmentScannerImpl.java:489)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:835)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:764)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1210)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:568)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:302)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1284)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 14 more
One thing that I find a little odd is that the IDE reports buildID as "20130225-0426", but the error log says "M20130204-1200". But, as I have hopefully made abundantly clear, this is all right out of the tin, and that's what came out.
And just hold on there before you hit reply.
"lineNumber: 1; columnNumber: 1; Content is not allowed in prolog"
Yes, I saw that. Yes, I have exhaustively researched it. The general consensus is that it has to do with an unwanted BOM. But guess what? Not this time.
First, I opened up the file in vim, checked that the fileencoding was utf-8, and for good measure set nobomb before saving and closing. That didn't help, so I opened it in a hex editor. No BOM. The file is plain UTF-8 just like the IDE says it is.
So, that's not the problem.
Re: [Acceleo] "Launch Acceleo Application" fails [message #1060245 is a reply to message #1060080] |
Thu, 23 May 2013 16:39 |
Ed Willink Messages: 7655 Registered: July 2009 |
Launch As Acceleo Application never works for me, so I always use the
Java option.
HTH
Ed Willink
> explanation for me.
> untouched by me.
> information.
> Step-by-step:
> Launch Eclipse
> [comment @main/]
> [/file]
> [/template]
> Acceleo Application
> click Run
> END step-by-step
> changed.
> java.vendor=Oracle Corporation
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 14 more
> Not this time.
Re: [Acceleo] "Launch Acceleo Application" fails [message #1062641 is a reply to message #1060080] |
Mon, 10 June 2013 08:48 |
From your stack trace it seems that you are trying to load mtl files (uncompiled Acceleo modules) in a resource set. It will never work, only emtl files (compiled Acceleo modules) can work. So a couple questions:
* did you change anything in the Java launcher generated by Acceleo?
* if you open the project, do you have a "bin" folder? do you have emtl files inside? (if you don't, your project has not been compiled, it will never work)
* do you have the action "Project -> Build automatically" checked? What happens if your force the compilation of the project?
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
Current Time: Fri Apr 26 01:30:47 GMT 2024
Powered by FUDForum. Page generated in 0.02942 seconds
