Dumb Plugins and Instances ... [message #156822] |
Fri, 14 November 2003 14:32 |
David Whitehurst Messages: 76 Registered: July 2009 |
Member |
I created a dumb plugin called Host just like an example using IListener and
callbacks. I have an Editor plugin action that I used the
Platform.getPlugin method to obtain the Host and then the action run()
method would call the proxy method on the Host plugin. When debugged, the
Host is null. Am I supposed to write code to instance the dumb plugin since
it has no GUI? The dumb plugin does have a constructor like ...
public Host(IPluginDescriptor descriptor) {
super(descriptor);
instance(this);
Why does the Editor's action run() method return NULL when the menu action
is called?
Here's the run method(IAction action) {
Host host = (Host) Platform.getPlugin(HOST_PLUGIN);
host.update("Hello there");
David
David L. Whitehurst
aka. PiratePete
http://www.piratepetesoftware.com
dlwhitehurst@comcast.net
FUDForum. Page generated in 0.03321 seconds
