Jubula 2.0 to VNC on Linux [message #1059604] |
Mon, 20 May 2013 18:39 |
Brian Watt Messages: 20 Registered: February 2012 |
I am running Jubula 2.0.00148 on Linux RH 6.4 on a remote machine which I am viewing using VNC. Let's call this machine jubula. Jubula seems alive and well and I am able to manually control it through VNC without any problems. This machine is not the problem.
However I am having problems running a test case from the jubula machine to my AUT on Linux RHEL 6.2. Let's call this machine autlinux. Because the autlinux machine is remote I am using VNC to view its "display". The AUT is Eclipse, and jubula can start it up correctly. When it tries to run the first test step in the test case which selects 'File'/'Exit' the test fails. This is because it tries to select ***the VNC menu*** and not the AUT's menu.
Note: If I run that same test to my AUT on Windows XP SP 3 it runs successfully. Let's call this machine autwindows. In other words, the test case drives the AUT and the I see the mouse move, the File & Exit menus get selected, etc. all of which I am viewing on my local Windows display (not through VNC).
Is there any known problems using VNC on AUT machines? Or do you have any suggestions for running remote AUT machines such as Linux?
[Updated on: Mon, 20 May 2013 18:46] Report message to a moderator
FUDForum. Page generated in 0.03894 seconds
