Home » Modeling » EMF » Automatic population of transient attributes
Automatic population of transient attributes [message #1059559] |
Mon, 20 May 2013 09:01  |
Hi all,
I've got a problem in that our model objects are identified purely by their human-readable name. This becomes a problem in our forms-based editor when someone renames an object and its name becomes (perhaps just temporarily) the same as one of the other objects - and now any other links that point to that object are ambiguous. Continuing to rename the object then means that all of the links get 'dragged' along, so that none point to the other object any more - and the model has become wrecked.
A way I thought of to stop this problem would be to have transient UUIDs auto-generated for the objects and transient UUID references to those objects created as the model was loaded from the workspace into memory. Then, the createSetCommand(...) method overrides in my ItemProviders would be able to search by UUID instead of by string identifiers, and (within an editor session) consistency would be maintained.
I'm trying to work out, though - where should I put the code to do the population of UUIDs and the resultant UUID references? I could do it in the editor's code, I suppose... but is there anywhere in EMF's generated classes I could override for better results?
Re: Automatic population of transient attributes [message #1059562 is a reply to message #1059559] |
Mon, 20 May 2013 09:12   |
Ben,
Comments below.
On 20/05/2013 3:01 PM, Ben Cox wrote:
> Hi all,
Is that because there are unresolved proxies using that name as an ID?
That sounds like an issue involving unresolved proxies. Perhaps it's
just a matter of ensuring that all proxies are resolved before you begin
renaming things, e.g., calling EcoreUtil.resoveAll on the resource or
resource set...
> memory.
What's the nature of these "references". Are EMF proxies involved?
Are you doing some type of "manual" searching?
I think I'd like to understand better the nature of the problem before
helping make a particular solution work... In general it seems better
to ensure you have direct references to the objects, so that might be as
simple as ensure that all proxies have been resolved so that changes to
the "ID" don't result in subsequent proxy resolves being misdirected...
Re: Automatic population of transient attributes [message #1059572 is a reply to message #1059562] |
Mon, 20 May 2013 10:14   |
Hi Ed,
comments inline.
>> Hi all,
Would that it used EMF's references already! No, it doesn't have unresolved proxies because the model doesn't use references (as far as EMF knows about them) at the moment. The model is one that has been generated from a pre-existing XSD, and doesn't have EMF-style references - hence, in a previous thread, I asked about how to make side-effects occur when one value gets changed, and you pointed me to the createSetCommand method that I could override in the ItemProviders (which is working well, apart from in this case - thanks!). Attempting to retro-fit EMF to the XSD in general works well, but it does have some problems, like this.
>resource set...
I think probably not, in my case. I'd probably better give a simplified example:
<objectType1 name="hello" />
<objectType1 name="helloThere" />
<objectType2 name="apple" objectType1="hello" />
<objectType2 name="banana" objectType1="hello" />
<objectType2 name="cherry" objectType1="helloThere" />
<objectType2 name="date" objectType1="helloThere" />
Here, instances of objectType1 have a name. Instances of objectType2 have a reference (not a real EMF reference, just a string) to an objectType1.
Now, suppose your editor has a Text that allows you to alter an objectType1's name, and you want to alter "helloThere" to "help". You do this by backspacing. With each modification, the ObjectType1ItemProvider#createSetCommand searches for any objectType2s with a matching objectType1 attribute and creates a CompoundCommand that also modifies them. "helloThere" -> "helloTher" -> "helloThe" -> "helloTh" -> "helloT" -> "hello"... and here's where it goes wrong. When you do the next backspace, ALL of the objectType2s will be modified to point to the objectType1 "hell", because, at that particular point, they ALL pointed to something named "hello". Suddenly, objectType2s point to one of your objectType1s, and none to the other objectType1. While it's not valid, in our model, to have two objectType1s with the same name (we have a constraint to avoid this), it does temporarily happen while editing.
>> memory.
Yes, absolutely. Fun. :-S
Hopefully that's clarified the matter a bit - as you can see, it's a bit horrible! I think we need to ensure we have references that EMF understands in order to get it working and to better identify objects even when they temporarily point to something with the same name. However, this information must not be persisted, in order to maintain compatibility of XML.
Re: Automatic population of transient attributes [message #1059585 is a reply to message #1059572] |
Mon, 20 May 2013 11:30   |
Ben,
Comments below.
On 20/05/2013 4:14 PM, Ben Cox wrote:
> Hi Ed,
> comments inline.
>>> Hi all,
>>> ambiguous.
>> begin renaming things, e.g., calling EcoreUtil.resoveAll on the
>> resource or resource set...
> simplified example:
I see. So name isn't of type ID in the schema with objectType1 of type
IDREF...
> objectType1.
I suppose you're doing this with data binding...
I see.
>>> into memory.
>> before helping make a particular solution work... In general it seems
>> better to ensure you have direct references to the objects, so that
>> might be as simple as ensure that all proxies have been resolved so
>> that changes to the "ID" don't result in subsequent proxy resolves
I see. Where/how are you planning to store the UUIDs and the
references to them? Why not add a transient reference (unfortunately
you can't do that via annotations in the schema) and populate those
references right after loading, i.e., essentially resolving all the
names once in the beginning? You might specialize the logic for
retrieving the value of the objectType1 attribute so it's computed from
the transient reference's name feature...
Current Time: Sat Jul 26 08:37:29 EDT 2025
Powered by FUDForum. Page generated in 0.04354 seconds
