Home » Language IDEs » C / C++ IDE (CDT) » multiple definitions of main issue( How to make Eclipse handle multiple definitions of main?)
multiple definitions of main issue [message #1059440] Sat, 18 May 2013 10:03 Go to next message
Eclipse is giving me the error " multiple definitions of main".
when I make my own makefile or use cmake, I do not get these errors. I have a test project where I create multiple source files each with it's own main() function. The goal is to have the compiler create a separate and distinct binary executable for each of these. my make files have no problems doing this, how do I get Eclipse to do it? Or is Eclipse inferior in this regard?
Re: multiple definitions of main issue [message #1059467 is a reply to message #1059440] Sun, 19 May 2013 05:44 Go to previous messageGo to next message
You cannot create an Eclipse "managed build" executable project with
multiple main functions. You could use a central main function that,
depending e.g. on command line arguments, runs the real separate main
functions.
Whether that is inferior is up to you, but as far as I know the C++
standard (3.6.1) requires exactly 1 main function per program (although
it is implementation defined for a freestanding environment). And an
Eclipse "managed build" executable project is for 1 executable ;-).
Joost
Re: multiple definitions of main issue [message #1059476 is a reply to message #1059440] Sun, 19 May 2013 07:53 Go to previous messageGo to next message
You can create a BuildConfiguration for each main function. There you can define which main.cpp to include and which executable you want to create.
http://help.eclipse.org/juno/topic/org.eclipse.cdt.doc.user/reference/cdt_u_prop_all.htm
Re: multiple definitions of main issue [message #1059506 is a reply to message #1059476] Mon, 20 May 2013 02:29 Go to previous messageGo to next message
> create.
Could you elaborate on that a bit as I cannot see how this is actually
done? I suspect that you mean that I could use macro-like stuff to
define the correct main, but that still means that I can use only 1 main
per build and hence 1 program and not several main's an therefore
several programs.
Personally, I would like to be able to do exactly what the OP wants, but
I have to use Makefiles to do so.
Joost
Re: multiple definitions of main issue [message #1748151 is a reply to message #1059506] Sat, 19 November 2016 02:38 Go to previous message
You can always write down you own Makefile and use it instead of the automaticaly generated one:
http://stackoverflow.com/a/8107675/967564
Previous Topic:Latest Eclipse
Next Topic: Why Launching failed?
Current Time: Sat Oct 25 16:06:36 EDT 2025
Powered by FUDForum. Page generated in 0.03296 seconds
