Home » Archived » BIRT » BIRT ignores alias when generating column binding names for joint data sets
BIRT ignores alias when generating column binding names for joint data sets [message #1058893] Wed, 15 May 2013 10:59 Go to next message
I run into this problem and do not know if I do something wrong
or if this behaviour is a feature.
1. OK:
Data Set A and Data Set B define aliases for all their columns.
2. OK:
Joint Data Set join both A and B.
BIRT correctly defines its aliases as a direct copy from the aliases above.
3. OK:
When binding Data Set A or B to a table,
BIRT correctly sets column binding name = alias
4. WRONG:
When binding Joint Data Set to a table,
BIRT sets column binding name = Data Set Name::Column Name.
But in my opinion, BIRT should set it to column alias defined in the data set -
no matter if it is a joint data set or a simple data set.
I am running BIRT
Version: 4.2.2.v201210101433-8F8j7cFT0z0-TtIsTlT0z-a
Build id: v20130206-1509
I tried to set up templates for tables which will bind to joint data sets
which will improve our productivity - if it just works.
Can somebody give me a hint if there is a solution?
Thanks in advance,
Silvester
Re: BIRT ignores alias when generating column binding names for joint data sets [message #1059138 is a reply to message #1058893] Thu, 16 May 2013 20:21 Go to previous messageGo to next message
Please log a bug for this in the bugzilla. Thanks!
Re: BIRT ignores alias when generating column binding names for joint data sets [message #1059159 is a reply to message #1059138] Fri, 17 May 2013 00:44 Go to previous messageGo to next message
See bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=408300
Re: BIRT ignores alias when generating column binding names for joint data sets [message #1059161 is a reply to message #1059159] Fri, 17 May 2013 00:57 Go to previous message
Thanks for the update!
Previous Topic:BiRT with big dataset->viewing the report during creating the report document
Next Topic:How to calculate elapsed time?
Current Time: Sun Nov 09 17:19:38 EST 2025
Powered by FUDForum. Page generated in 0.02784 seconds
