Home » Eclipse Projects » Virgo » Creating test - doesn't reach to the point where tests are executed(Creating test - doesn't reach to the point where tests are executed)
icon9.gif  Creating test - doesn't reach to the point where tests are executed [message #1058219] Mon, 13 May 2013 05:15
Can anyone help in pointing me to the problem?
I am trying to create a unit test using Virgo test. I am successful in getting necessary JARs configured for the project and my test class also starts running.
The configuration I am using is attached to this post.
The test is pretty much empty -
@RunWith(DmKernelTestRunner.class)
public class VirgoTestCase {
@BeforeClass
public static void setUpBeforeClass() throws Exception {
@AfterClass
public static void tearDownAfterClass() throws Exception {
@Before
public void setUp() throws Exception {
@After
public void tearDown() throws Exception {
@Test
public void test() {
fail("Not yet implemented");
So ideally what I should see is - virgo modules start. setUp* etc get executed from the test and 'test()' method fails because I have explicitly failed that test with no logic in it.
BUT I see following log trace and no test / setUp* methods gets invoked. Sad
I can't figure out what have I done wrong.
[2013-05-13 14:38:52.825] kernel-dm-4 Exporter [&org.eclipse.gemini.blueprint.service.exporter.support.OsgiServiceFactoryBean#6] is being tracked for dependencies
[2013-05-13 14:38:52.826] kernel-dm-4 Returning cached instance of singleton bean 'eventLogger'
[2013-05-13 14:38:52.826] kernel-dm-4 Returning cached instance of singleton bean 'repositoryFactory'
[2013-05-13 14:38:52.826] kernel-dm-4 Returning cached instance of singleton bean 'hashGenerator'
[2013-05-13 14:38:52.826] kernel-dm-4 Returning cached instance of singleton bean 'org.eclipse.gemini.blueprint.service.importer.support.OsgiServiceProxyFactoryBean#0'
[2013-05-13 14:38:52.827] kernel-dm-4 Publishing service under classes [{org.eclipse.virgo.repository.Repository}]
[2013-05-13 14:38:52.827] kernel-dm-4 Registered dependency for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.osgi, config=osgibundle:/META-INF/spring/*.xml); eliminating Dependency on [(objectClass=org.eclipse.virgo.repository.Repository)] (from bean [&repository]), remaining [{}]
[2013-05-13 14:38:52.828] kernel-dm-4 > public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.828] kernel-dm-4 Sending event to topic 'org/osgi/service/blueprint/container/GRACE_PERIOD' with properties '{bundle.version=3.7.0.D-20130426092903, bundle=org.eclipse.virgo.kernel.osgi_3.7.0.D-20130426092903 [49], bundle.symbolicName=org.eclipse.virgo.kernel.osgi, type=6, timestamp=1368436132828, bundle.id=49}'
[2013-05-13 14:38:52.828] kernel-dm-4 > public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.829] kernel-dm-4 Service dependency '(objectClass=org.eclipse.virgo.repository.Repository) &repository' has been satisfied
[2013-05-13 14:38:52.829] kernel-dm-4 > public boolean org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.cancel()
[2013-05-13 14:38:52.829] kernel-dm-4 < public boolean org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.cancel()
[2013-05-13 14:38:52.829] kernel-dm-4 < public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.830] kernel-dm-4 > public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.830] kernel-dm-4 < public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.830] kernel-dm-4 > public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.830] kernel-dm-4 Handling event 'org.osgi.service.event.Event [topic=org/osgi/service/blueprint/container/GRACE_PERIOD]'
[2013-05-13 14:38:52.830] kernel-dm-4 < public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.831] kernel-dm-4 < public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.833] kernel-dm-4 > public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.833] kernel-dm-4 < public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.833] kernel-dm-4 All dependencies satisfied, not sending Blueprint GRACE event with emtpy dependencies from org.eclipse.gemini.blueprint.extender.event.BootstrappingDependenciesEvent[source=OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.osgi, config=osgibundle:/META-INF/spring/*.xml): startup date [Mon May 13 14:38:51 IST 2013]; root of context hierarchy]
[2013-05-13 14:38:52.834] kernel-dm-4 Deregistering service dependency dependencyDetector for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.osgi, config=osgibundle:/META-INF/spring/*.xml)
[2013-05-13 14:38:52.835] kernel-dm-4 No unsatisfied OSGi service dependencies; completing initialization for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.osgi, config=osgibundle:/META-INF/spring/*.xml)
[2013-05-13 14:38:52.835] kernel-dm-4 Starting stage two for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.osgi, config=osgibundle:/META-INF/spring/*.xml)
[2013-05-13 14:38:52.835] kernel-dm-4 Cancelled dependency watchdog...
[2013-05-13 14:38:52.835] kernel-dm-4 > public void org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor.execute(java.lang.Runnable)
[2013-05-13 14:38:52.836] kernel-dm-4 > public java.lang.Thread org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor.1.newThread(java.lang.Runnable)
[2013-05-13 14:38:52.836] kernel-dm-4 < public java.lang.Thread org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor.1.newThread(java.lang.Runnable)
[2013-05-13 14:38:52.834] kernel-dm-1 Adding [systemEnvironment] PropertySource with lowest search precedence
[2013-05-13 14:38:52.836] kernel-dm-1 Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
[2013-05-13 14:38:52.837] kernel-dm-1 Invoking afterPropertiesSet() on bean with name 'importExpander'
[2013-05-13 14:38:52.837] kernel-dm-1 Finished creating instance of bean 'importExpander'
[2013-05-13 14:38:52.838] kernel-dm-1 Creating shared instance of singleton bean 'deploymentListeners'
[2013-05-13 14:38:52.838] kernel-dm-1 Creating instance of bean 'deploymentListeners'
[2013-05-13 14:38:52.838] kernel-dm-1 Eagerly caching bean 'deploymentListeners' to allow for resolving potential circular references
[2013-05-13 14:38:52.839] kernel-dm-1 Initializing new StandardEnvironment
[2013-05-13 14:38:52.839] kernel-dm-1 Adding [systemProperties] PropertySource with lowest search precedence
[2013-05-13 14:38:52.839] kernel-dm-1 Adding [systemEnvironment] PropertySource with lowest search precedence
[2013-05-13 14:38:52.839] kernel-dm-1 Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
[2013-05-13 14:38:52.840] kernel-dm-1 Initializing new StandardEnvironment
[2013-05-13 14:38:52.840] kernel-dm-1 Adding [systemProperties] PropertySource with lowest search precedence
[2013-05-13 14:38:52.840] kernel-dm-1 Adding [systemEnvironment] PropertySource with lowest search precedence
[2013-05-13 14:38:52.840] kernel-dm-1 Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
[2013-05-13 14:38:52.841] kernel-dm-1 Adding [systemEnvironment] PropertySource with lowest search precedence
[2013-05-13 14:38:52.841] kernel-dm-1 Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
[2013-05-13 14:38:52.841] kernel-dm-1 Initializing new StandardEnvironment
[2013-05-13 14:38:52.841] kernel-dm-1 Adding [systemProperties] PropertySource with lowest search precedence
[2013-05-13 14:38:52.842] kernel-dm-1 Initializing new StandardEnvironment
[2013-05-13 14:38:52.842] kernel-dm-1 Adding [systemProperties] PropertySource with lowest search precedence
[2013-05-13 14:38:52.842] kernel-dm-1 Adding [systemEnvironment] PropertySource with lowest search precedence
[2013-05-13 14:38:52.842] kernel-dm-1 Initialized StandardEnvironment with PropertySources [systemProperties,systemEnvironment]
[2013-05-13 14:38:52.843] kernel-dm-1 Invoking afterPropertiesSet() on bean with name 'deploymentListeners'
[2013-05-13 14:38:52.843] kernel-dm-1 Greedy proxying will NOT consider exposed classes
[2013-05-13 14:38:52.844] kernel-dm-1 Finished creating instance of bean 'deploymentListeners'
[2013-05-13 14:38:52.837] kernel-dm-4 < public void org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor.execute(java.lang.Runnable)
[2013-05-13 14:38:52.845] kernel-dm-1 OSGi service dependency for importer [&recoveryMonitor] is already satisfied
[2013-05-13 14:38:52.846] kernel-dm-1 OSGi service dependency for importer [&kernelConfig] is already satisfied
[2013-05-13 14:38:52.847] kernel-dm-1 Adding OSGi service dependency for importer [&packageAdminUtil] matching OSGi filter [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)]
[2013-05-13 14:38:52.847] kernel-dm-1 OSGi service dependency for importer [&scopeFactory] is already satisfied
[2013-05-13 14:38:52.848] kernel-dm-1 Adding OSGi service dependency for importer [&userBundleContext] matching OSGi filter [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))]
[2013-05-13 14:38:52.849] kernel-dm-1 OSGi service dependency for importer [&configAdmin] is already satisfied
[2013-05-13 14:38:52.850] kernel-dm-1 OSGi service dependency for importer [&eventLogger] is already satisfied
[2013-05-13 14:38:52.850] kernel-dm-1 OSGi service dependency for importer [&dumpGenerator] is already satisfied
[2013-05-13 14:38:52.851] kernel-dm-1 OSGi service dependency for importer [&packageAdmin] is already satisfied
[2013-05-13 14:38:52.852] kernel-dm-1 OSGi service dependency for importer [&repository] is already satisfied
[2013-05-13 14:38:52.853] kernel-dm-1 OSGi service dependency for importer [&shutdown] is already satisfied
[2013-05-13 14:38:52.855] kernel-dm-1 OSGi service dependency for importer [&tracingService] is already satisfied
[2013-05-13 14:38:52.856] kernel-dm-1 OSGi service dependency for importer [&workArea] is already satisfied
[2013-05-13 14:38:52.856] kernel-dm-1 Adding OSGi service dependency for importer [&osgiFramework] matching OSGi filter [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)]
[2013-05-13 14:38:52.857] kernel-dm-1 Adding OSGi service dependency for importer [&quasiFrameworkFactory] matching OSGi filter [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)]
[2013-05-13 14:38:52.857] kernel-dm-1 OSGi service dependency for importer [&eventAdmin] is already satisfied
[2013-05-13 14:38:52.858] kernel-dm-1 OSGi service dependency for importer [&bundleStarter] is already satisfied
[2013-05-13 14:38:52.858] kernel-dm-1 Adding OSGi service dependency for importer [&importExpander] matching OSGi filter [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)]
[2013-05-13 14:38:52.858] kernel-dm-1 OSGi service dependency for importer [artifactBridges#org.eclipse.gemini.blueprint.service.importer.support.OsgiServiceCollectionProxyFactoryBean#0] is already satisfied
[2013-05-13 14:38:52.859] kernel-dm-1 19 OSGi service dependencies, 5 unsatisfied (for beans [&quasiFrameworkFactory, &packageAdminUtil, &osgiFramework, &userBundleContext, &importExpander]) in OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml)
[2013-05-13 14:38:52.859] kernel-dm-1 OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml) is waiting for unsatisfied dependencies [[&quasiFrameworkFactory, &packageAdminUtil, &osgiFramework, &userBundleContext, &importExpander]]
[2013-05-13 14:38:52.859] kernel-dm-1 Registering service dependency dependencyDetector for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml)
[2013-05-13 14:38:52.859] kernel-dm-1 OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml) has registered service dependency dependencyDetector with filter: (|(objectClass=org.eclipse.virgo.nano.deployer.api.RecoveryMonitor)(objectClass=org.eclipse.virgo.nano.core.KernelConfig)(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)(objectClass=org.eclipse.virgo.nano.shim.scope.ScopeFactory)(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))(objectClass=org.osgi.service.cm.ConfigurationAdmin)(objectClass=org.eclipse.virgo.medic.eventlog.EventLogger)(objectClass=org.eclipse.virgo.medic.dump.DumpGenerator)(objectClass=org.osgi.service.packageadmin.PackageAdmin)(objectClass=org.eclipse.virgo.repository.Repository)(objectClass=org.eclipse.virgo.nano.core.Shutdown)(objectClass=org.eclipse.virgo.nano.shim.serviceability.TracingService)(objectClass=org.eclipse.virgo.kernel.services.work.WorkArea)(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)(objectClass=org.osgi.service.event.EventAdmin)(objectClass=org.eclipse.virgo.nano.core.BundleStarter)(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)(objectClass=org.eclipse.virgo.repository.ArtifactBridge))
[2013-05-13 14:38:52.859] kernel-dm-1 > public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.859] kernel-dm-1 Sending event to topic 'org/osgi/service/blueprint/container/WAITING' with properties '{bundle.id=46, bundle.symbolicName=org.eclipse.virgo.kernel.deployer, mandatory=[Z@49aa95c, timestamp=1368436132859, dependencies=[Ljava.lang.String;@45e4d960, type=7, bean.name=[Ljava.lang.String;@337b5179, bundle=org.eclipse.virgo.kernel.deployer_3.7.0.D-20130426092903 [46], bundle.version=3.7.0.D-20130426092903}'
[2013-05-13 14:38:52.860] kernel-dm-1 > public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.860] kernel-dm-1 > public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createExponentialTicker(long, long, long, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.860] kernel-dm-1 > public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createTicker(org.eclipse.virgo.nano.core.internal.blueprint.Ticker.HeartBeatPolicy, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.860] kernel-dm-1 < public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createTicker(org.eclipse.virgo.nano.core.internal.blueprint.Ticker.HeartBeatPolicy, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.860] kernel-dm-1 < public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createExponentialTicker(long, long, long, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.860] kernel-dm-1 < public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.860] kernel-dm-1 > public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.860] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.860] kernel-dm-1 > public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.861] kernel-dm-1 Handling event 'org.osgi.service.event.Event [topic=org/osgi/service/blueprint/container/WAITING]'
[2013-05-13 14:38:52.861] kernel-dm-1 < public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.861] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.861] kernel-dm-1 > public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.861] kernel-dm-1 Sending event to topic 'org/osgi/service/blueprint/container/WAITING' with properties '{bundle.id=46, bundle.symbolicName=org.eclipse.virgo.kernel.deployer, mandatory=[Z@6521f956, timestamp=1368436132861, dependencies=[Ljava.lang.String;@1978b0f9, type=7, bean.name=[Ljava.lang.String;@42aab87f, bundle=org.eclipse.virgo.kernel.deployer_3.7.0.D-20130426092903 [46], bundle.version=3.7.0.D-20130426092903}'
[2013-05-13 14:38:52.862] kernel-dm-1 > public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.862] kernel-dm-1 > public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createExponentialTicker(long, long, long, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.862] kernel-dm-1 > public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createTicker(org.eclipse.virgo.nano.core.internal.blueprint.Ticker.HeartBeatPolicy, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.862] kernel-dm-1 < public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createTicker(org.eclipse.virgo.nano.core.internal.blueprint.Ticker.HeartBeatPolicy, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.862] kernel-dm-1 < public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createExponentialTicker(long, long, long, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.862] kernel-dm-1 < public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.862] kernel-dm-1 > public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.862] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.862] kernel-dm-1 > public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.863] kernel-dm-1 Handling event 'org.osgi.service.event.Event [topic=org/osgi/service/blueprint/container/WAITING]'
[2013-05-13 14:38:52.863] kernel-dm-1 < public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.863] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.863] kernel-dm-1 > public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.863] kernel-dm-1 Sending event to topic 'org/osgi/service/blueprint/container/WAITING' with properties '{bundle.id=46, bundle.symbolicName=org.eclipse.virgo.kernel.deployer, mandatory=[Z@5636bc0a, timestamp=1368436132863, dependencies=[Ljava.lang.String;@237360be, type=7, bean.name=[Ljava.lang.String;@6bd46c20, bundle=org.eclipse.virgo.kernel.deployer_3.7.0.D-20130426092903 [46], bundle.version=3.7.0.D-20130426092903}'
[2013-05-13 14:38:52.863] kernel-dm-1 > public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.863] kernel-dm-1 > public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createExponentialTicker(long, long, long, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.863] kernel-dm-1 > public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createTicker(org.eclipse.virgo.nano.core.internal.blueprint.Ticker.HeartBeatPolicy, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.864] kernel-dm-1 < public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createTicker(org.eclipse.virgo.nano.core.internal.blueprint.Ticker.HeartBeatPolicy, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.864] kernel-dm-1 < public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createExponentialTicker(long, long, long, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.864] kernel-dm-1 < public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.864] kernel-dm-1 > public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.864] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.864] kernel-dm-1 > public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.864] kernel-dm-1 Handling event 'org.osgi.service.event.Event [topic=org/osgi/service/blueprint/container/WAITING]'
[2013-05-13 14:38:52.864] kernel-dm-1 < public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.864] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.865] kernel-dm-1 > public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.865] kernel-dm-1 Sending event to topic 'org/osgi/service/blueprint/container/WAITING' with properties '{bundle.id=46, bundle.symbolicName=org.eclipse.virgo.kernel.deployer, mandatory=[Z@4706e02e, timestamp=1368436132865, dependencies=[Ljava.lang.String;@14681070, type=7, bean.name=[Ljava.lang.String;@3c0f3387, bundle=org.eclipse.virgo.kernel.deployer_3.7.0.D-20130426092903 [46], bundle.version=3.7.0.D-20130426092903}'
[2013-05-13 14:38:52.865] kernel-dm-1 > public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.865] kernel-dm-1 > public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createExponentialTicker(long, long, long, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.865] kernel-dm-1 > public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createTicker(org.eclipse.virgo.nano.core.internal.blueprint.Ticker.HeartBeatPolicy, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.866] kernel-dm-1 < public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createTicker(org.eclipse.virgo.nano.core.internal.blueprint.Ticker.HeartBeatPolicy, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.866] kernel-dm-1 < public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createExponentialTicker(long, long, long, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.866] kernel-dm-1 < public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.866] kernel-dm-1 > public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.866] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.866] kernel-dm-1 > public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.866] kernel-dm-1 Handling event 'org.osgi.service.event.Event [topic=org/osgi/service/blueprint/container/WAITING]'
[2013-05-13 14:38:52.866] kernel-dm-1 < public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.866] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.867] kernel-dm-1 > public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.867] kernel-dm-1 Sending event to topic 'org/osgi/service/blueprint/container/WAITING' with properties '{bundle.id=46, bundle.symbolicName=org.eclipse.virgo.kernel.deployer, mandatory=[Z@a0002df, timestamp=1368436132867, dependencies=[Ljava.lang.String;@6bc839a, type=7, bean.name=[Ljava.lang.String;@4263f6ea, bundle=org.eclipse.virgo.kernel.deployer_3.7.0.D-20130426092903 [46], bundle.version=3.7.0.D-20130426092903}'
[2013-05-13 14:38:52.867] kernel-dm-1 > public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.867] kernel-dm-1 > public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createExponentialTicker(long, long, long, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.867] kernel-dm-1 > public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createTicker(org.eclipse.virgo.nano.core.internal.blueprint.Ticker.HeartBeatPolicy, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.847] kernel-dm-5 > public void org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor.2.run()
[2013-05-13 14:38:52.848] iLogServiceListener@7168afdd Bundle org.eclipse.virgo.kernel.services_3.7.0.D-20130426092903, Service 87, ServiceEvent REGISTERED
[2013-05-13 14:38:52.868] kernel-dm-1 < public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createTicker(org.eclipse.virgo.nano.core.internal.blueprint.Ticker.HeartBeatPolicy, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.870] kernel-dm-5 Completing refresh for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.osgi, config=osgibundle:/META-INF/spring/*.xml)
[2013-05-13 14:38:52.872] kernel-dm-5 Creating a single service proxy ...
[2013-05-13 14:38:52.873] kernel-dm-5 Creating JDK dynamic proxy: target source is EmptyTargetSource: no target class, static
[2013-05-13 14:38:52.870] kernel-dm-1 < public static org.eclipse.virgo.nano.core.internal.blueprint.Ticker org.eclipse.virgo.nano.core.internal.blueprint.StandardTicker.createExponentialTicker(long, long, long, java.util.concurrent.Callable, java.util.concurrent.ScheduledExecutorService)
[2013-05-13 14:38:52.885] kernel-dm-1 < public void org.eclipse.virgo.nano.core.internal.blueprint.ApplicationContextDependencyMonitor.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.885] kernel-dm-1 > public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.885] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.internal.DeployerFailureListener.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.885] kernel-dm-1 > public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.885] kernel-dm-1 Handling event 'org.osgi.service.event.Event [topic=org/osgi/service/blueprint/container/WAITING]'
[2013-05-13 14:38:52.885] kernel-dm-1 < public void org.eclipse.virgo.nano.core.internal.BundleStartTracker.handleEvent(org.osgi.service.event.Event)
[2013-05-13 14:38:52.885] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.886] kernel-dm-1 > public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.886] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.internal.BlueprintEventPostingOsgiBundleApplicationContextListener.onOsgiApplicationEvent(org.eclipse.gemini.blueprint.context.event.OsgiBundleApplicationContextEvent)
[2013-05-13 14:38:52.888] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.osgi.service.packageadmin.PackageAdmin)] (from bean [&packageAdmin]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.888] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.osgi.service.event.EventAdmin)] (from bean [&eventAdmin]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.888] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.osgi.service.cm.ConfigurationAdmin)] (from bean [&configAdmin]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.889] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.medic.eventlog.EventLogger)] (from bean [&eventLogger]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.889] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.medic.dump.DumpGenerator)] (from bean [&dumpGenerator]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.889] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.nano.core.Shutdown)] (from bean [&shutdown]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.889] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.nano.core.BundleStarter)] (from bean [&bundleStarter]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.890] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.nano.shim.scope.ScopeFactory)] (from bean [&scopeFactory]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.890] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.nano.shim.serviceability.TracingService)] (from bean [&tracingService]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.891] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.nano.core.KernelConfig)] (from bean [&kernelConfig]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.891] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.nano.deployer.api.RecoveryMonitor)] (from bean [&recoveryMonitor]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.891] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.kernel.services.work.WorkArea)] (from bean [&workArea]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.892] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.repository.ArtifactBridge)] (from bean [artifactBridges#org.eclipse.gemini.blueprint.service.importer.support.OsgiServiceCollectionProxyFactoryBean#0]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.893] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.repository.ArtifactBridge)] (from bean [artifactBridges#org.eclipse.gemini.blueprint.service.importer.support.OsgiServiceCollectionProxyFactoryBean#0]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.893] kernel-dm-1 Increasing the number of matching services for OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml); Dependency on [(objectClass=org.eclipse.virgo.repository.Repository)] (from bean [&repository]), remaining [{Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory)] (from bean [&quasiFrameworkFactory])=&quasiFrameworkFactory, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil)] (from bean [&packageAdminUtil])=&packageAdminUtil, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.OsgiFramework)] (from bean [&osgiFramework])=&osgiFramework, Dependency on [(&(objectClass=org.osgi.framework.BundleContext)(org.eclipse.virgo.kernel.regionContext=true))] (from bean [&userBundleContext])=&userBundleContext, Dependency on [(objectClass=org.eclipse.virgo.kernel.osgi.framework.ImportExpander)] (from bean [&importExpander])=&importExpander}]
[2013-05-13 14:38:52.893] kernel-dm-1 Asynch wait-for-dependencies started...
[2013-05-13 14:38:52.894] kernel-dm-1 < public void org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor.2.run()
[2013-05-13 14:38:52.896] kernel-dm-5 Creating a single service proxy ...
[2013-05-13 14:38:52.897] kernel-dm-5 Creating JDK dynamic proxy: target source is EmptyTargetSource: no target class, static
[2013-05-13 14:38:52.899] kernel-dm-5 Creating a single service proxy ...
[2013-05-13 14:38:52.900] kernel-dm-5 Creating JDK dynamic proxy: target source is EmptyTargetSource: no target class, static
[2013-05-13 14:38:52.905] kernel-dm-5 Creating a single service proxy ...
[2013-05-13 14:38:52.906] kernel-dm-5 Creating JDK dynamic proxy: target source is EmptyTargetSource: no target class, static
[2013-05-13 14:38:52.907] kernel-dm-4 <UF0010E> User region configuration unavailable.
[2013-05-13 14:38:52.911] kernel-dm-5 Creating a single service proxy ...
[2013-05-13 14:38:52.911] kernel-dm-5 Creating JDK dynamic proxy: target source is EmptyTargetSource: no target class, static
[2013-05-13 14:38:52.914] kernel-dm-5 Creating a single service proxy ...
[2013-05-13 14:38:52.914] kernel-dm-5 Creating JDK dynamic proxy: target source is EmptyTargetSource: no target class, static
[2013-05-13 14:38:52.918] kernel-dm-5 Creating a single service proxy ...
[2013-05-13 14:38:52.918] kernel-dm-5 Creating JDK dynamic proxy: target source is EmptyTargetSource: no target class, static
[2013-05-13 14:38:52.922] kernel-dm-5 Unable to locate MessageSource with name 'messageSource': using default [org.springframework.context.support.DelegatingMessageSource@20e5f01b]
[2013-05-13 14:38:52.922] kernel-dm-5 Unable to locate ApplicationEventMulticaster with name 'applicationEventMulticaster': using default [org.springframework.context.event.SimpleApplicationEventMulticaster@57f68d7c]
[2013-05-13 14:38:52.923] kernel-dm-5 Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@38be9340: defining beans [kernelConfig,org.springframework.context.support.PropertySourcesPlaceholderConfigurer#0,eventLogger,shutdown,packageAdmin,repository,eventAdmin,configAdmin,eventLoggerFactory,org.eclipse.gemini.blueprint.service.exporter.support.OsgiServiceFactoryBean#0,globalRegion]; root of factory hierarchy
[2013-05-13 14:38:52.923] kernel-dm-5 Returning cached instance of singleton bean 'kernelConfig'
[2013-05-13 14:38:52.923] kernel-dm-5 Returning cached instance of singleton bean 'org.springframework.context.support.PropertySourcesPlaceholderConfigurer#0'
[2013-05-13 14:38:52.923] kernel-dm-5 Returning cached instance of singleton bean 'eventLogger'
[2013-05-13 14:38:52.923] kernel-dm-5 Adding OSGi mandatoryListeners for services matching [(objectClass=org.eclipse.virgo.medic.eventlog.EventLogger)]
[2013-05-13 14:38:52.924] kernel-dm-5 Service reference [{org.eclipse.virgo.medic.eventlog.EventLogger}={service.id=51}] bound to proxy
[2013-05-13 14:38:52.925] kernel-dm-5 Service reference [{org.eclipse.virgo.medic.eventlog.EventLogger}={service.id=51}] bound to proxy
[2013-05-13 14:38:52.925] kernel-dm-5 Returning cached instance of singleton bean 'shutdown'
[2013-05-13 14:38:52.925] kernel-dm-5 Adding OSGi mandatoryListeners for services matching [(objectClass=org.eclipse.virgo.nano.core.Shutdown)]
[2013-05-13 14:38:52.926] kernel-dm-5 Service reference [{org.eclipse.virgo.nano.core.Shutdown}={service.id=62}] bound to proxy
[2013-05-13 14:38:52.926] kernel-dm-5 Returning cached instance of singleton bean 'packageAdmin'
[2013-05-13 14:38:52.927] kernel-dm-5 Adding OSGi mandatoryListeners for services matching [(objectClass=org.osgi.service.packageadmin.PackageAdmin)]
[2013-05-13 14:38:52.927] kernel-dm-5 Service reference [{org.osgi.service.packageadmin.PackageAdmin}={service.ranking=2147483647, service.pid=0.org.eclipse.osgi.framework.internal.core.PackageAdminImpl, service.vendor=Eclipse.org - Equinox, service.id=1}] bound to proxy
[2013-05-13 14:38:52.928] kernel-dm-5 Service reference [{org.osgi.service.packageadmin.PackageAdmin}={service.ranking=2147483647, service.pid=0.org.eclipse.osgi.framework.internal.core.PackageAdminImpl, service.vendor=Eclipse.org - Equinox, service.id=1}] bound to proxy
[2013-05-13 14:38:52.928] kernel-dm-5 Returning cached instance of singleton bean 'repository'
[2013-05-13 14:38:52.928] kernel-dm-5 Adding OSGi mandatoryListeners for services matching [(objectClass=org.eclipse.virgo.repository.Repository)]
[2013-05-13 14:38:52.929] kernel-dm-5 Service reference [{org.eclipse.virgo.repository.Repository}={org.eclipse.gemini.blueprint.bean.name=repository, org.springframework.osgi.bean.name=repository, osgi.service.blueprint.compname=repository, Bundle-SymbolicName=org.eclipse.virgo.kernel.services, Bundle-Version=3.7.0.D-20130426092903, service.id=87}] bound to proxy
[2013-05-13 14:38:52.929] kernel-dm-5 Returning cached instance of singleton bean 'eventAdmin'
[2013-05-13 14:38:52.929] kernel-dm-5 Adding OSGi mandatoryListeners for services matching [(objectClass=org.osgi.service.event.EventAdmin)]
[2013-05-13 14:38:52.930] kernel-dm-5 Service reference [{org.osgi.service.event.EventAdmin}={component.name=org.eclipse.equinox.event, component.id=0, service.id=37}] bound to proxy
[2013-05-13 14:38:52.930] kernel-dm-5 Returning cached instance of singleton bean 'configAdmin'
[2013-05-1
Previous Topic:Making bundles in Nexus available to virgo instance
Next Topic:Redeploy / ClassLoader problem
Current Time: Thu Nov 06 07:48:28 EST 2025
Powered by FUDForum. Page generated in 0.02995 seconds
