Repository of Eclipse tests [message #1058132] |
Sun, 12 May 2013 10:36 |
Brian Watt Messages: 20 Registered: February 2012 |
Junior Member |
In the spirit of reuse, is there a place where I can download existing Jubula tests to startup and shutdown Eclipse? I am an Eclipse for Parallel Applications developer and want to test some new parallel capability using Jubula, but to get started I need to launch Eclipse and get it started past the Welcome page. Because this is such a common occurrence I assumed that there would be a repository of Jubula tests for various Eclipse capabilities, such as startup, creating a project, building, running, etc. however in my searching I haven't found any tests. If there is a repository of exported tests can you provide a pointer to it. Thanks.
[Updated on: Sun, 12 May 2013 10:39] Report message to a moderator
Re: Repository of Eclipse tests [message #1058323 is a reply to message #1058167] |
Mon, 13 May 2013 14:50 |
Jubula is of course tested with Jubula
We have been planning to move these tests to the Eclipse git repository for some time now. But there is always something more important ...
Oliver (who maintains the tests) will follow up tomorrow.
Re: Repository of Eclipse tests [message #1059428 is a reply to message #1059364] |
Sat, 18 May 2013 09:42 |
Just try to switch to the current version of the unbound modules (concrete and swt). Open the project properties dialog (int the Test menu), select "Used Projects" and exchange the versions referenced with an installed version (use the button with the arrows pointing in different directions).
Depending on the state of the project you might run into the problem of deprecated modules which were actually removed lately (after a few years of warning). If this is the case please read the release notes for help on fixing this.
- Achim
FUDForum. Page generated in 0.04771 seconds
