Re: Making validator work [message #1058532 is a reply to message #1058483] |
Tue, 14 May 2013 12:13 |
Ian McDevitt Messages: 70 Registered: December 2012 Location: Belfast |
Member |
Firstly your "whole grammar" has syntax errors so maybe you're not supplying exactly what you have?
this isn't actually a rule. It should be something like
Model: tasks += Task_grammar*
Also your names can't currently be filenames like explorer.exe
ID will not allow a dot in the name so I assume you're actually using a rule like taskname=TASKNAME and
in it.
After that you may be able to solve your original problem with the builtin uniqueness validation for 'names' by uncommenting it in your workflow file (.mwe2).
composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
This checks references called 'name' so you just need to use name=TASKNAME instead of taskname=TASKNAME
Don't forget to regenerate the language after such changes.
[Updated on: Tue, 14 May 2013 12:37] Report message to a moderator
FUDForum. Page generated in 0.05614 seconds
