remote debugging in eclipse cdt from linux server using cygwin [message #1057823] |
Thu, 09 May 2013 05:01 |
nagaraj sherigar Messages: 5 Registered: May 2013 |
My current configuration is that I code, compile and debug C/C++ applications on a Linux server. The problem I am facing is that many users use the same server, making it very difficult to directly access the server. My plan is use Eclipse CDT in my local Windows CP to code. This part works fine. I'm coding in Eclipse, then compiling on the Linux server itself. Now I want to debug in Eclipse. I use gdbserver for this purpose. I get the control from my remote system to Eclipse but it shows this error:
warning: A handler for the OS ABI "GNU/Linux" is not built into this configuration of GDB. Attempting to continue with the default i386 settings.
...And nothing happens. Is there any way I can debug in Eclipse from gdbserver on a remote Linux machine? I am using Cygwin on Windows XP.
FUDForum. Page generated in 0.03625 seconds
