| Spanning Columns Across Pages [message #1057776] |
Wed, 08 May 2013 12:39  |
I have a Data Set which contains 20-30 different columns. I would like to have columns 1-10 on page 1, columns 11-20 on page 2, and columns 21-30 on page 3. If there are too many rows for one page, the three pages should repeat (so columns 1-10 would be on pages 1 and 4, columns 11-20 on pages 2 and 5, columns 21-30 on pages 3 and 6).
Is this possible in BIRT? If so, how?
Thanks!
| Re: Spanning Columns Across Pages [message #1057893 is a reply to message #1057776] |
Thu, 09 May 2013 11:16  |
If you select your table so that the row and column tabs show, then select the 10th column, go to the page break section of the property editor, and set the page break after to always. Then, do the same for the 20th column, you should get this result. Let me know.
FUDForum. Page generated in 0.03245 seconds
