Home » Archived » BIRT » BIRT with Ruby on Rails(BIRT integration with Ruby on Rails)
BIRT with Ruby on Rails [message #1053735] Tue, 07 May 2013 08:33 Go to next message
Hi Everyone,
Has anyone integrated BIRT report/tool with any Ruby on Rails project?
I m not able to see any concrete information on the web.
Would be a great help if someone can suggest.
Thanks in advance.
Re: BIRT with Ruby on Rails [message #1053855 is a reply to message #1053735] Tue, 07 May 2013 17:32 Go to previous message
I've not worked with Ruby in Rails before, but I did integrate BIRT with Django. If you can call a Java class from Ruby on Rails you can write some Java code to generate the report and return it in html or another format that you'd like.
Previous Topic:Adding sort to Property Editor
Next Topic:Use cached birt reports in custom dashboard
Current Time: Fri Sep 26 00:30:58 EDT 2025
Powered by FUDForum. Page generated in 0.04298 seconds
