Home » Modeling » Compare » [EMFCompare] Diff: Deleted attribute from a class
[EMFCompare] Diff: Deleted attribute from a class [message #1053623] Mon, 06 May 2013 22:31 Go to next message
Aleksandar Toshovski is currently offline Aleksandar ToshovskiFriend
Member
I'm comparing two ecore files. When I delete an EAttribute, then I retrieve two differences. I don't understand the second Diff. Why there is a eType change? I was expecting only the first one.
  <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt"/>
REFERENCE: org.eclipse.emf.ecore.impl.EReferenceImpl@546c585a (name: eStructuralFeatures) (ordered: true, unique: true, lowerBound: 0, upperBound: -1) (changeable: true, volatile: false, transient: false, defaultValueLiteral: null, unsettable: false, derived: false) (containment: true, resolveProxies: false)
VALUE: org.eclipse.emf.ecore.impl.EAttributeImpl@76a9b9c (name: name) (ordered: true, unique: true, lowerBound: 0, upperBound: 1) (changeable: true, volatile: false, transient: false, defaultValueLiteral: null, unsettable: false, derived: false) (iD: false)
KIND: DELETE
SOURCE: LEFT
REFERENCE: org.eclipse.emf.ecore.impl.EReferenceImpl@c5a67c9 (name: eType) (ordered: true, unique: true, lowerBound: 0, upperBound: 1) (changeable: true, volatile: true, transient: false, defaultValueLiteral: null, unsettable: true, derived: false) (containment: false, resolveProxies: true)
VALUE: org.eclipse.emf.ecore.impl.EDataTypeImpl@2c09505f (eProxyURI: http://www.eclipse.org/emf/2002/Ecore#//EInt)
KIND: CHANGE
SOURCE: LEFT
Re: [EMFCompare] Diff: Deleted attribute from a class [message #1053725 is a reply to message #1053623] Tue, 07 May 2013 11:56 Go to previous message
Cedric Brun is currently offline Cedric BrunFriend
The eType difference is a sub-difference of the first one. By deleting the EAttribute, you also suppress the fact that eType of this reference targets an EObject. This is needed so that merge will always be consistent. If you are not interested in those you can easily filter them, see org.eclipse.emf.compare.rcp.ui.internal.structuremergeviewer.filters.impl.SubDiffElementsFilter for reference.
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
Previous Topic:[EMF Compare] Retrieve original value of AttributeChange
Next Topic:Changes in UML Model
Current Time: Fri Apr 26 18:54:52 GMT 2024
Powered by FUDForum. Page generated in 0.03057 seconds
