| [CDO] OracleAdapter and ORA-00904 [message #1053617] |
Mon, 06 May 2013 17:19  |
We are trying to get CDO running on Oracle 11g
But struggling with this error!
jvm 1 | WrapperListener_start_runner [org.eclipse.net4j.spi.db.DBAdapter] CREATE TABLE cdo_lobs (id VARCHAR2(64), size NUMBER, bdata BLOB, cdata CLOB)
jvm 1 | WrapperListener_start_runner [org.eclipse.net4j.spi.db.DBAdapter] -- ORA-00904: : ugyldig identifikator
jvm 1 |
jvm 1 | WrapperListener_start_runner [org.eclipse.net4j.spi.db.DBAdapter] SELECT id, size, bdata, cdata FROM cdo_lobs
jvm 1 | WrapperManager Error: Error in WrapperListener.start callback. org.eclipse.net4j.db.DBException: Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
jvm 1 | WrapperManager Error: org.eclipse.net4j.db.DBException: Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
jvm 1 | WrapperManager Error: at org.eclipse.net4j.spi.db.DBAdapter.validateTable(DBAdapter.java:447)
I'm using the code from emf-cdo-S20130319-1538 build
Is there some way to make Oracle less sensitive ?
Or is there still some problemes with the OracleAdpater ?
Børre Nordbakken
Brønnøysundregistrene
| Re: [CDO] OracleAdapter and ORA-00904 [message #1053762 is a reply to message #1053617] |
Tue, 07 May 2013 09:57  |
I see you posted this on the EMF newsgroup too; that's the better place
and you can expect to see a response there.
> identifikator
> jvm 1 |
> FROM cdo_lobs
> Best regards,
> Børre Nordbakken
FUDForum. Page generated in 0.08336 seconds
