| Creating war using ANT [message #1053491] |
Mon, 06 May 2013 05:06 |
The following are the output in building the project in command prompt.
D:\Gopakumar\PBL ScoreCard>ant
Buildfile: build.xml
prepare:
cleartomcat:
clear-remote:
[delete] Deleting directory D:\Gopakumar\PBL ScoreCard Remote API\build\class
path
incremental-remote:
[echo] BUILDING REMOTE API
[mkdir] Created dir: D:\Gopakumar\PBL ScoreCard Remote API\build\classpath
[javac] Compiling 52 source files to D:\Gopakumar\PBL ScoreCard Remote API\b
uild\classpath
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
clean-remote:
clear-pc:
[delete] Deleting directory D:\Gopakumar\PBL ScoreCard Performance Chart Appl
et\build\classpath
et\dist
incremental-pc:
[echo] BUILDING PERFORMANCE CHART APPLET
[mkdir] Created dir: D:\Gopakumar\PBL ScoreCard Performance Chart Applet\bui
ld\classpath
[copy] Copying 57 files to D:\Gopakumar\PBL ScoreCard Performance Chart App
let\build\classpath
[javac] Compiling 37 source files to D:\Gopakumar\PBL ScoreCard Performance
Chart Applet\build\classpath
[copy] Copying 35 files to D:\Gopakumar\PBL ScoreCard Performance Chart App
let\build\classpath
[unzip] Expanding: D:\Gopakumar\PBL ScoreCard Performance Chart Applet\lib\h
essian-3.0.13.jar into D:\Gopakumar\PBL ScoreCard Performance Chart Applet\build
\classpath
[unzip] Expanding: D:\Gopakumar\PBL ScoreCard Performance Chart Applet\lib\c
omposite-1.0.jar into D:\Gopakumar\PBL ScoreCard Performance Chart Applet\build\
classpath
[unzip] Expanding: D:\Gopakumar\PBL ScoreCard Performance Chart Applet\lib\m
orph-1.0.jar into D:\Gopakumar\PBL ScoreCard Performance Chart Applet\build\clas
spath
ommons-logging-api.jar into D:\Gopakumar\PBL ScoreCard Performance Chart Applet\
build\classpath
[unzip] Expanding: D:\Gopakumar\PBL ScoreCard Performance Chart Applet\lib\j
graph.jar into D:\Gopakumar\PBL ScoreCard Performance Chart Applet\build\classpa
th
[mkdir] Created dir: D:\Gopakumar\PBL ScoreCard Performance Chart Applet\dis
t
[jar] Building jar: D:\Gopakumar\PBL ScoreCard Performance Chart Applet\di
st\performancechartedit.jar
[signjar] Signing JAR: D:\Gopakumar\PBL ScoreCard Performance Chart Applet\dis
t\performancechartedit.jar to D:\Gopakumar\PBL ScoreCard Performance Chart Apple
t\dist\performancechartedit.jar as csi
[signjar] jarsigner error: java.lang.RuntimeException: keystore load: C:\Users
\bimal\.keystore (The system cannot find the file specified)
[signjar] Enter Passphrase for keystore:
BUILD FAILED
D:\Gopakumar\PBL ScoreCard\build.xml:556: The following error occurred while exe
cuting this line:
D:\Gopakumar\PBL ScoreCard\build.xml:147: jarsigner returned: 1
Actually the keystore file is created at location D:\PBL ScoreCard where the build.xml file resides. But system looks for the .keystore file in C:\Users\Bimal\.keystore. So how do I change the path for the keystore file in build.xml? or is there any other solutions?
FUDForum. Page generated in 0.08121 seconds
