Home » Newcomers » Newcomers » [HELP] how to Configure ARToolkit in eclipse on ubuntu 12.04(configure ARToolkit in eclipse)
icon4.gif  [HELP] how to Configure ARToolkit in eclipse on ubuntu 12.04 [message #1053362] Sat, 04 May 2013 09:24 Go to next message
Hello;
I have been trying to run a code that performs basic augmented reality based on ARToolkit, and although the code was compiled on terminal it gives errors
Invoking: GCC C Linker
gcc -L/usr/local/lib -o"TryAR" ./main.o -lglut -lGLU
./main.o: In function `main':
/home/user/TryAR/Debug/../main.c:51: undefined reference to `arVideoCapStart'
/home/user/TryAR/Debug/../main.c:52: undefined reference to `argMainLoop'
./main.o: In function `keyEvent':
/home/user/TryAR/Debug/../main.c:60: undefined reference to `arUtilTimer'
./main.o: In function `mainLoop':
/home/user/TryAR/Debug/../main.c:75: undefined reference to `arVideoGetImage'
/home/user/TryAR/Debug/../main.c:76: undefined reference to `arUtilSleep'
/home/user/TryAR/Debug/../main.c:79: undefined reference to `arUtilTimerReset'
/home/user/TryAR/Debug/../main.c:82: undefined reference to `argDrawMode2D'
/home/user/TryAR/Debug/../main.c:83: undefined reference to `argDispImage'
/home/user/TryAR/Debug/../main.c:86: undefined reference to `arDetectMarker'
/home/user/TryAR/Debug/../main.c:91: undefined reference to `arVideoCapNext'
/home/user/TryAR/Debug/../main.c:102: undefined reference to `argSwapBuffers'
/home/user/TryAR/Debug/../main.c:107: undefined reference to `arGetTransMat'
/home/user/TryAR/Debug/../main.c:111: undefined reference to `argSwapBuffers'
./main.o: In function `init':
/home/user/TryAR/Debug/../main.c:119: undefined reference to `arVideoOpen'
/home/user/TryAR/Debug/../main.c:121: undefined reference to `arVideoInqSize'
/home/user/TryAR/Debug/../main.c:125: undefined reference to `arParamLoad'
/home/user/TryAR/Debug/../main.c:129: undefined reference to `arParamChangeSize'
/home/user/TryAR/Debug/../main.c:130: undefined reference to `arInitCparam'
/home/user/TryAR/Debug/../main.c:132: undefined reference to `arParamDisp'
/home/user/TryAR/Debug/../main.c:134: undefined reference to `arLoadPatt'
/home/user/TryAR/Debug/../main.c:140: undefined reference to `argInit'
./main.o: In function `cleanup':
/home/user/TryAR/Debug/../main.c:146: undefined reference to `arVideoCapStop'
/home/user/TryAR/Debug/../main.c:147: undefined reference to `arVideoClose'
/home/user/TryAR/Debug/../main.c:148: undefined reference to `argCleanup'
./main.o: In function `draw':
/home/user/TryAR/Debug/../main.c:161: undefined reference to `argDrawMode3D'
/home/user/TryAR/Debug/../main.c:162: undefined reference to `argDraw3dCamera'
/home/user/TryAR/Debug/../main.c:169: undefined reference to `argConvGlpara'
collect2: ld returned 1 exit status
make: *** [TryAR] Error 1
This code can be found in the simlpeTest.c in the source code.
Re: [HELP] how to Configure ARToolkit in eclipse on ubuntu 12.04 [message #1053653 is a reply to message #1053362] Tue, 07 May 2013 03:33 Go to previous message
This is a forum for Eclipse. You should probably find one specific to the ARToolkit, or compiling with it on Ubuntu, if you're going to indicate issues with compiling against it on the command line. If you are seeing problems working with the C/C++ Development Tools in Eclipse, then you might want to try http://eclipse.org/forums/eclipse.tools.cdt .
Previous Topic:Adding Sort to Property Editor
Next Topic:*SOLVED* Yellow confirmation box on ALL shortcuts
Current Time: Thu Nov 06 21:16:34 EST 2025
Powered by FUDForum. Page generated in 0.08488 seconds
