Re: teneo dynamic emf example [message #1053094 is a reply to message #1052944] |
Thu, 02 May 2013 12:11 |
Hi Thomas,
Afaics you should create a teneo datastore and as the epackage pass in the ecore model as well as the ecore extension
model epackage.
But I am not sure that it is correct to persist the ecore model itself as ecore is also present as
'a-model-with-generated-code', see the last sentence in the first paragraph here:
http://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Association_Mapping#Storing_references_to_Ecore_Model_Elements
gr. Martin
On 05/01/2013 04:12 PM, Thomas Steinbach wrote:
> my question is based on two articles. The first is the http://wiki.eclipse.org/Teneo/Hibernate/Dynamic_EMF_Tutorial.
> In the http://www.ibm.com/developerworks/library/os-eclipse-emfmetamodel/ by IBM, the ecore-model is extended so you can
> model not only the signature of an EOperation but also its body with statements, variables, etc.
> Of course this extensions can't be saved yet, for example the new EOperationImpl-element. What do you have to do in
> order to get a new added ecore-element persisted as in the teneo dynamic emf example?
> With best regards,
> Thomas
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.03133 seconds
