Home » Modeling » Epsilon » Epsilon Validation Language(Problem with writing Constraint in EVL)
Epsilon Validation Language [message #1052916] |
Wed, 01 May 2013 10:40 |
Joshua Nwokeji Messages: 94 Registered: January 2013 |
Member |
Dear All!
Attn: (Antonio, and Dimitris)
Let me start by saying that the Epsilon projects(Epsilon Forum, EuGENiA, Epsilon Book, and other materials) have been very useful to me to my research, thanks very much to the Epsilon Team, you guys did a great job.
I have got my graphical editor working fine, courtesy of Eugenia, and helps from Antonio, and Dimitris. The next step in my project is to define and implement a set of constraints for my graphical tool. I have gone through some examples in the epsilon book (Chapter 4), and the example with filesystem validation available online. However, my ecore model seems to be complicated that I dont know how to start writing the constraints using EVL. I have texually defined those constraints, but the challenge is writing them in EVL.
Please I need help on how to use EVL to define constraints for graphical tool. If need be I will be willing to share my project with you including the ecore Model-Model.
Joshua
Re: Epsilon Validation Language [message #1053815 is a reply to message #1052976] |
Tue, 07 May 2013 16:52 |
Member |
Dear Antonio,
I have corrected the mistakes, so sorry about that (I have not really used EOL before, apart from today). However it didn't work out, and the EVL is still showing the error sign. There is something I forgot to tell you about the graphical editor I implemented with Eugenia:
"Refinement" does not go directly from a "Goal" to a Leaf goal (Requirement, Expectation, DomainInvariant and DomainHypothesis), rather it first go through either the "Or" Node (represented with a Small hollow ellipse-please see the Figure attached) or the "And" Node (represented in the Figure as a small solid black ellipse).
Also in the EOL file, I think that "self.isLeaf" may not be applicable since the Meta-Model I used in Implementing the Editor does not contain "Leaf" Goal, instead Leaf Goals are defined as-Requirement, Expectation, DomainInvariant and DomainHypothesis.
Re: Epsilon Validation Language [message #1055823 is a reply to message #1053815] |
Wed, 08 May 2013 11:04 |
Member |
Dear Antonio,
Thanks a lot for your help yesterday, my knowledge and understanding of EVL has increased.
However, I still have little challenge with Completeness Check 1. Currently I have imported the *.EOL file into my Evl file, but my challenge is to include a constraint that will specify that Goals go through the "AND\Or" nodes (using Refinement) before they get to leaf goals (Expectation, Requirement, DomainHypothesis, and DomainInvariant)-Please See Figure 1. In the Meta-Model I used to generate the graphical editor, all Nodes inherit from one super class called Nodes, Please see attached as EuGENiaModel.
After writing the EVL and EOL codes (Please see below), the validation works, but it does not recognize that Goals and SubGoals have been refined to leaf goals (please see Figure 1), I guess this is because I have not included the AND/OR nodes in the codes for the (EVL, and EOL) constraints, and I am finding this very challenging, Please I need your help. I will be willing to share the project on dropbox folder if you wish.
Joshua
completekaos.EOL
operation Goal isLeaf() {
return self.isKindOf(Expectation)
or self.isKindOf(Requirement)
or self.isKindOf(DomainHypothesis)
or self.isKindOf(DomainInvariant);
operation Goal isRefinedIntoLeaf() {
if (self.isLeaf()) return true;
else return Refinement.all.exists(r | r.froma = self and
r.toa.isRefinedIntoLeaf());
completekaos.evl
import "completekaos.eol;"
context Goal {
constraint RefinedIntoLeaf {
guard : not self.isLeaf()
check : self.isRefinedIntoLeaf()
message : "Goal " + self.name + " must be refined into a leaf goal"
Re: Epsilon Validation Language [message #1055921 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
MB5!.1PT*&@H````-24A$4@```8T```&)"`(```#Y5/B0```7-FE#0U!)0T,@
M4')O9FEL90``6(6U60DT5=_W/_>-GN?A>>9Y'I-YSCQER#Q$,CW3,\_S4*8R
MI$@((2222(,A)#0A&4*C#"FBH@D1_ZOZ?K^__[3^Z[_6_[_7.O=^UC[[[#/L
M??8Y^UX`V);=@H/]$?0`!`2&AUH9ZO`>='#DQ;X"$$```N`";&[DL&!M"PM3
M\-_2]PE8&J8QR5U=_[W<?TE$#\\P,@"0!8S=/<+(`3"^#@!"AQP<&@X`<AWF
M#T>%!\,8]0#&C*'P`&'\<A=[_\8KN]C]%T:C?LG86.G"F!4`*AHWMU!O``B"
M,)\WDNP-ZR'H`8!A"/2@!`)`.@AC#;*/FP<`;$6PS)Z`@*!=W`=C4?=_T>/]
M[W2Z_ZW3S<W[;_Q[+K^(2H\2%NSO%O._7([_F0+\(_[J@P$N-('^9KNV88;+
M@H>;G@G\YH3+=K#_+YO!,A"[9Z"M]1^\)]#=S/P/UO`*-;#ZW1:R"`[7V<7P
M_""OX'`+FS_\Q%@?7;/=?F"<[QFF_Y>>"E\WXUV;T<*X.33"RA;&\!I`W6&1
MUOHPACT*>A/K8V/_1^:KAZ?>'SX"X44Q,/J#&2CA1KM],<*8WR_(Q.IW7PA%
M8`+\@2>(`*'P,Q!(`E.@"_3^/"6!%W"#:R+ANC#@!][".`!N$02W"8(Q[Q\Y
MW?_$,?C5SAMN]^\U\@(R+!?Q=Y]_<?_10`$>\/LOOMN?NMW1A;E0DO_IX5_U
M_6HI72^]*+WU5SU*&"6+4D#IH-11&B@5P(MB1K$#290\2AFEC=)$J<%U*O`H
MW_P:Y9\Q[NH/:/:*+`J*4;7S^3,'][]G8/=+FO)?SNC/V(>66Y;_'B$(]XP.
MWW4@W:#@F%"*MT\XKS:\<SWW\!H%DO?NX965EI'[/_?;_T_:C5F_T1>K7[$(
M8G[\#R^@$0!E"LQT_H?G?@J`=DEX[]?_PQ,N@/>Q+P`#@N2(T,C?O-UP`M"`
M&M#!'LH&N($`$(77618H`C6@!?2!,3`'-L`!.,.K[0/[8"B(`O'@*$@'6>`4
M.`.*03FH`K6@`32#%M`![H![8``,@W'P`DR#>;`$5L!WL`E!$!8B0"2(#>*!
MA"`)2!92AC0@?<@4LH(<(%?(&PJ$(J!X*`7*@O*@8N@\5`==A=J@.]!#:`1Z
M!LU`B]!GZ`<"B:!!,"*X$,((*80R0AMA@K!!'$9X(T(0L8A41`ZB"%&)N(RX
MB;B#&$",(Z812XAO2(#$(YF1?$A)I#)2%VF.=$1Z(4.1B<A,9`&R$GD%V8Z\
MCQQ#3B.7D1LH#(J$XD5)PGZZ'V6+(J-"4(FH;%0QJA9U$]6'&D/-H%90VV@"
MFA,M@59%&Z$/HKW14>AT=`&Z!GT#?1<]CIY'?\=@,,P8$8P29C_&`>.+B<-D
M8\YA&C'=F!','.8;%HMEPTI@U;'F6#=L.#8=>Q9[&7L;.XJ=QZY3X:EXJ&2I
M#*@<J0*IDJD*J"Y1=5&-4KVCVL31XX1PJCASG`<N!G<25XUKQSW&S>,VJ8G4
M(M3JU#;4OM1'J8NHKU#?I7Y)_06/Q_/C5?"6>`K^"+X(WX1_@)_!;]`PT(C3
MZ-(XT430Y-!<I.FF>4;SA4`@"!.T"(Z$<$(.H8[02Y@BK-.2:/?2&M%ZT";1
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M^,[S#?%M\HOPV_(G\S?ROQ*@%E`6\!+(%^@16!'D$3P@&"]8+_A<"">D+.0C
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M,B(;U1FM&"L9)QCWF="86)L4F\R:BIN&FK8?0!PP/G#ZP$LS(;-`LQ9S8&YD
M?MK\E86(18C%+4N,I85EB>5;*QFK>*O[UB1K%^M+UM]M=&Q.VKRP%;6-L.VQ
MH[-SLJNS6[/7L\^SGSXH=3#AX(`#NP/%H=41ZVCG6./X[9#^H3.'YIT4G-*=
M)@Z+'(X^_-"9W=G?N=.%SL7-Y9HKVM7>]9+KEINY6Z7;-W<C]U+W%;(NN9"\
MY*'ED>^QZ*GNF>?YSDO=*\]KP5O=^[3WHH^F3X'/,D674DQ9]=WO6^Z[YF?N
M=]%OQ]_>OS&`*L`UH"V0(=`OL"^(.R@Z:"18(C@]>#I$->1,R$JH26A-&!1V
M.*PUG!&^'`Y&B$:D1<Q$:D261*Y'V45=BR9&!T8/QHC'9,2\BS6(O1"'BB/'
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MVU>G5%=WB?/2R7I$?43]XF6GR\,->@VM5R2OG&]D;LQJ`DT13>^ONEZ=:#9I
M[KFF?.W*=:'KI3=(-S)O0C=C;JZT^+1,MSJTCK09M_6TJ[7?N+7WUL4.OHZ2
M3J;.DUW47:E=.[=C;W_K#NY>ON-]9Z['I>=%[\'>)WV6?4-W3>X^N&=PK_>^
M]OW;#]0?=#Q4?=C6K]S?,J`X<'-08?#&(X5'-X84AVX^5GK<.JPRW#ZR;Z1K
M5'/TSIC>V+TG1D\&QLW&1R9L)YY..DU./_5XNO#,_]GJ\\CGFR^.O$2_S'Q%
M_ZI@BG.J\K78Z\9IQ>G.&;V9P5GKV1=SY+FE-V%OMN93WQ+>%KSC>5>W(+O0
ML6BP./S^T/OYI>"ES>7T#\0/I1]%/U[_I/5I<.7@ROQJZ.K.Y^PO;%\N?I7_
MVO/-XMO4]X#OFVN9ZVSKM1O*&_=_V/]XMQFUA=TJ^BGVLWW;9/OE3L#.3K!;
MJ-NOJP`2+@@O+P`^7X3O"0YP[C`,`#7M[YSB#R'ARP<"?MM!>Z$EQ#FD,TH(
M]1[=C2G"!E-9X?2I%?%2-'L)$K3*=";TKL0(AC.D-L899AH6;=90M@;V)4XQ
M+E_N)IYU/CW^4P*S0C+"QT1>B2F(GY)8EM3?6R6U+>,DVR[/KA"M.*XLIY*C
MNKS/4+U"XX>6E?8%G0T]$_UB@X7]\D9QQEVFT`$MLUCS)HLY*Z*UNHV';9I=
MA?VU@[<=>AV[#[4Y-1ZN<2YU.>6:[!;B[DPV]5#RY/<B>*UYS_CT4YI]B_V2
M_2D!%H$*02Q!:\%C(?6A26'FX3SAGR*Z(G.BG*(EHG_$],<6QU'BE1,P"6.)
MY4G^1W2."B8SIM"ETJ<1T^F/$8[C,E`9.YD;69^SET[,YCP_.7IJ(+<GK^WT
ME?RJ,V<+<@I3BN+.QA0GEQ25WC@W7#9;OERQ<GZE<J7J4_7'"Q]JEBXNU+ZI
MF[DT5[_:0+RBVYC8U'+U=?/Z=>P-TDV>%O%6A3;-=J-;UAWNG=%=1;?O="_T
MH'I)?>QW>>^)WU=ZH/-0IU^T_]-`YB#;X/E'FH^6AQH>APZKC$`CCT;+QD*>
MZ(^SC7^<Z)TL?.KS3/'9SO/N%[$OY5XNOVJ8"GN];QHS/3I3.NLU)S.W^>;>
M?/Y;SW>J"PP+[Q>[WF<OV2_S+2]^N/HQ]I/."GYE?+7A<]F7ZU_7OGNM/=_0
M^I&_.?U3;CM_9^>7_06@)H0#D@'Y`)6.-L$P85YAKU%EX_RI;?%Z-'($,5HA
M.E%Z*:("@P')CC&0*96YBJ6/=8F=R*'!2>$JYA[DV>%3Y@\7N"+X7EA"Q$>T
M5FQ)0G)/J.2-O1O2FC)'9>_+XQ5,%7.41E1(JA9J.?OZ-3":FEJ1VK4Z+_3P
M^JH&[H89^^N-!HP731$'6,Q$S.4L5"U5K>2L!6UH;;[9/K?KMJ\^F.D0Z&A]
M2,F)PVGG\*QSGTN-:[J;A[L6F9.\YC'B6>^5YNWLHT2AIRSXWO8K]`\,T`]D
M#_P0=#LX)\0QE#]T,:PI/"I"->)G9%=44K16#"KF0>R).(MX4OQX0F'B(3BR
MKASI/5J>G)(2F.J89I@N?XSO.,WQM8S9S,&LF]D5)X[GA)X\?,HT5S-/X?3>
M?-$S_`6<A2Q%Q+/4Q:CBK9*OI4OGILLFRT<JAL^/5[ZN6JI>KT%>I*UEJQ.\
M)%V_[[)!@_D5AT;/ILBKV<VUU_JN3]U8;8%:Z=OXVN5N&70<Z@SN2K]=TEUW
MIZ&GNO=47_A=FWNR]XGW5Q\\@6-3^4#:H-\CRR'EQWS#^.'UD;G11V/-3PK'
M$R;(DR9/Y9]Q/4<_7W[QY.6M5U53)U['3P?/^,T&S(6_29A/?YO[KF3APF+3
M^_:EWN5''UY\7%]16:W^HO,-__WK^L*/T:W*;8<_]N>$3B!$$0/(`!0':@"=
MC-'`K&,[J8[A'*CE\+3X!9J'A&NT970GZ%.(L0R1I!C&&*8$YG26DZSGV!K9
M^SB><G[D)O`(\NKPN?*G"%0)WA5:%*$5E1&S%8^3*-_3)[DH1916DG&4C9,K
MD[^M,*6XK<RAHJ)JI4;9EZB>JU&E>56K0_NN3K_NH-Z`_GV#VX;7]E<:91H'
MFIB8\II^/7#/K-"<8J%BB;6<L+I@'6:C94MC.VE7;1]\4,T!XS#L6'S(TVFO
MT_?#7<[I+F:N)-=)MV(X3O"0ISTJ/%V]>+Q>>U?XN%)X*%.^Y_P<_$G^0P$9
M@?I!4-"MX/`0D9"GH<?#E,+>A1=$Z$5\CJR(,HO:C*Z+L8M%Q#;&'8I'QS<E
M'$I$)S8E.1]A/#)RM"#9,T4YE39U/JTS/?^8WW'M#):,#YEWLO*SO4XHY5#G
M3)]L/967&YIG?5HAGRU_^\R;@O["QJ+39R.+'4I42]GATW*\[$9Y2<6)\^F5
MJ55IU<<N'*M)NYA0&U!W\))^O=IE]0:3*VZ-\4U%5Z\W/[HV?WWS)K%%N'5?
MFV6[]ZW$CC.=E[HZ;M_O[K_SL.=N[YV^SKNM]Z[=;WAP\6%Y_]F!O,'L1^E#
M*8_3AG-':D<?CJV.<TT8348^K7PV]'SCI>`KZZF3KZ=G*'.L;[Z]0R\F+O>N
MGEX7W+7_[V]+NX11!*!&'W:((P!8PC6UE@`(Y0-`TP:`!0$`&Q6`\$L#".(2
M@$I%_SX_(#CQQ`%Z..,4`%)`'9B`0W`FGPCR0`VX!4;`(IPOLD/RD#GD!QV#
M+D"]T"P"@1!`Z,.97A:B$?$$\0/.Y_8C0Y#%R#[D)]@'#5$1J"K4&!J)EH<S
MLF+T$`:)4<$$8VHQLUA.[$%L/G:4BDAE276::AS'AG/!U>`^4BM3IU`/X[GQ
M@?AN&D8:7YH[!`Y"%&&<5I'V+.T.G3?=*+TV_36B.+&&082AD:1&&F1T8?S*
M=()9G'F`)9B5A;67+82=GWV"XP3G?BX,USWN3!Y+7D[>#WQ]_%4"68*Q0@'"
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M]FZC:%-G:VH[]%?\@``:X`$)<`$QH`0,@#V@@'B0"RZ"+C`!/D'4D!"D`[E`
MB5`9U`5-P[871A@C@A$%B"[$6R0]4A7IB<Q%WD9^0'&B#L`9^E74&S0;V@R=
MANZ$LV]IC#]L][=8(:P7MA:[1"5%%4'5B</@+'#G<.^I5:FSJ%_CY?%9^#<T
MFC3G:'X27`EW:25I"^G0=)%T2_1D^FFB._$]0PR)CG2)T9!Q@2F+68;Y.4LZ
MJSSK6[82=AL.>HY1SB(N=VXI'L`SSMO`E\'O+6`L*"/$(4PEO"GR5?2KV)8$
M88^`I,9>5ZD,Z3:9]W*<\A8*68J#RD05>]6S:F/JD(:PIH&6E_9QG0;=<7V$
M@:RAU_YS1I,FS*9V!PK,QBQH+0VMDJS;;=;L%.VC#W8ZH@]9.)4?_NQB[%KM
M]I-L"<>I]]YR/@F4`3\N_Y"`>T%<P9$A8V'RX8416U$NT5VQK'&!\?<2!9(R
MCZPG^Z:\2K-([SVNE-&0Q9]=G,-RLCQ7->]#?FM!85%R<4BI2YEQA7PE3S7M
MA9V+G^O>UC]M>-#8<;7MVIT;CUM>M2W=VNBB[N;M4>T[>"_F04E_^^#PT(OA
MIZ.#3SHF+C\]]SSWY;&II.F8V:@WT6_C%J+?'UYF_E#SB66%LEKU>?S+VC>6
M[W)K%NMA&V=_/-K"_K3<KOYC?PP@`!9X]\L`'6`#?$`"R`<-X#Z8!3L0%[0/
M.@S;_CQT#[YE,B!4$63$"40K8AY)0FHC0Y%5R`D4#J4![_C+J'DT#_H0N@@]
M@6'&V&.*,5-8`:PO]AIVF\J8JHAJ`:>*.X&;@VV>3[V"-\<WT9!H8FAF"6:$
M3EIIV@MT/'2E]-STU4098A^#"PD!V]N>"<MTBSF<19IEA?4Z6P*[$0<KQS)G
M'U<%=Q(/F=>43X5?7(!/D$>(3UA,1%'42,Q%/$:B<$^[Y*P4@[2Q3+ILKSQ:
MP5*Q09FDDJ2ZNH^BOJ#IK_5=)UV/4[_=T,4(;]QA2C%#FV=9`JL@ZU>V9G8]
M\)G4>DC%J=O9S&7&+9I,YU'E)>_=33'QG?0G!ZP&'0UA"FT,/Q"Q$G4VQC@.
MBF]-)"=M'\U)84VM3)<\UIEAD[F>?24G\)1X[MAIW_PO!1&%W\Y&%6^5II<Q
MEM><5ZL<JPZHH;Y86[?_TN+E["ORC6^NGK_F?T.OA;\-U;[8,=+5V=W04]E7
M?"__06[_R<&30UG#":/.3Z3'OTTV/PMX(?;R[=2%::]9\;G5^8YW:8MZ[U>7
MCW_X_,EH)7NUY?.K+\M?-[[-?7^XEK>^;_WM1NK&QH_`'W.;!S=O;S%N4;:Z
M?C+^I/SLVJ;:MM@NVGZ]([(3M-.R:_\P+SG97\<'1*,#`'IJ9^>+,`#8/`!^
MYN[L;%;N[/RL@I.-EP!T^__^7_'KK*$'H.+7!\N'7'-'_N,WTG\##F>5@=&`
M0L0````)<$A9<P``"Q,```L3`0":G!@``"``241!5'B<[=U[6!-G^C?P>R"!
M0`@1D(-!!10$;2%5*M@J*.AZ0H$J>B&'*MM6K#^MI;:V4D_5KK2NK=6U57EU
M0074BE:P5K2**(I%*KN`6PD5A1:B@(!)A`22,.\?48J`G$PRD^3^7+VNALD<
M;I/ARS///#-#D"0)""%$8T94%X`00KW`G$((T1WF%$*([C"G$$)TASF%$*([
MS"F$$-UA3B&$Z`YS"B%$=YA3""&ZPYQ""-$=YA1"B.XPIQ!"=(<YA1"B.\PI
MA!#=84XAA.@.<PHA1'>84P@ANL.<0@C1'>840HCN,*<00G2'.840HCO,*800
MW6%.(83H#G,*(41WF%,((;K#G$((T1WF%$*([C"G$$)TASF%$*([S"F$$-UA
M3B&$Z`YS"B%$=YA3""&Z8U!=@)HIE4J!0"`4"IN:FJBN18/8;#:/QW-W=S<V
M-J:Z%H0TCB!)DNH:U$:I5.;FYC(8#'=W=RZ7:V2DGZW%MK8VD4@D$`@4"H6?
MGQ]&%=)[>I53O_WV6T-#P\2)$PF"H+H6C2-)\MJU:];6UF/&C*&Z%H0T2Z^.
M^X1"(9_/UZ>0JKIVK>[[1$5C'5G;1-BQ&5:VM@N7#ITX$0`(@G!W=R\J*L*<
M0GI/KXZ,FIJ:N%PNU56H3=6U:\(M\=82Y4@W7Z_(J)%NOM82I7!+?-6U:ZH9
MN%RN?G?#(:2B5SD%`'K3)Z4**:_`&4[_3C$#("N$9@!._T[Q"IS1'E5Z\X]%
MJ&>XH_>%K+'QL98WV9)ZTHXUI.W18\C),5N_D92VF*W?"#DY;8\>V[&&M*2>
MU'(]"%'($'-*5ID;'\HG^'P^083&9\IZ7>!QP63KKQNU4%D'3?\IL1C.@Z:6
MYE.G`<!\ZU;(R6GZX4=H:K$8SFOZ3XEVRT&(2GK5C]X+B5`(=CRX.=O9?\+Q
M8FG8:'E=Y7]+F_NP)-/%DPL`"DE=(]/6EJ7I0@$`I'?_-//P4-RK!GAR6D"\
M:;?JA9D+3WKW3VT4@1`]&$9[2B;,VA5+6#KF5"M*3R1<BLK8&N;)`@;'=J2?
MGR<+H+$D/90@^`01&)=6IP"0E<;Q^7P^P8]-KNNP&D7USW9F1'QR=IU"XR6;
MC1@F;9(0%BS+32M44P@+4]5_TB:)V8AA&J\`(=K0\YQ22(39R?%\LUD%@Z,:
MY&2$!TO>(O8:/_39N>K^Z;5@X1UI$2E_OSGR@U.5P')-N%E45%0=E'BH5/+7
M?"R/"%):.ZWEM!TS<$M:;EWO1XP#QQ[K*:ZKYWSX#DR9(HYX&W)R.#^FDI9F
MI*69N*Z>/=93@]M&B&;T.Z?J4CYTG!J3$'?SPOH(/RL&`(!<5%\LDJO>EI3L
M(_B[))*[9R#`PY$%P'!Y*2#E[@-%7?$_8T*C8S\[`Y8FG5;)L@V,W5%]<>:&
M2/]IF],UUVEE'CA55/T`IDR1_/U=@L64'#H&.3F6:?L9+D-%-77F@5,UMF6$
M:$>_<\IVR3Y27/%+[8YI!#\VLU"H`'";M1PV3,BJE`$`$UJ@&!0<AT"X5"L!
M`'CTX%+(T,'%23&7IGYU>-_V,`!@JE;5`@``BO+\M&@^$76,6UPK+=H:9J6Q
MTH>$S7;8NND_HR<\K*UKL3`S'N7\\&3FW:`%@A_..6Q>/R1LML:VC!#MZ'\_
M.L?)=\WAHG>%A7N61]W?D!$[+O9V1NUH9S.OD!";C`R(2F6`T_M7=@;;$1][
M0;'+EW<VC+0L>.N2ORO_4(A70,:&5>G2KX:"C2D`2`H/O+.[9><%J:=6^M)5
M8=2<?5%84"*M/&?FY,@>Z^D0$X,AA0R-7EW?EY&1$104Q&#T(7P5DL9&!8-E
MQN$\31R%3"*%]A\5,HF"Q6&!0B8#%HNF::Y0*,Z<.1,2$D)U(0AI%DU_`S6.
MP;&R[32%Q>$\\Q-#]7^MC$)`"/5`O_NG$$+Z`',*(41WF%,((;K#G$((T1WF
M%$*([C"G$$)TASF%$*([S"F$$-UA3B&$Z`YS"B%$=YA3""&ZPYQ""-$=YA1"
MB.XPIQ!"=(<YA1"B.\PIA!#=84XAA.@.<PHA1'>84P@ANL.<0@C1'>840HCN
M,*<00G2'.840HCO,*800W6%.(83H#G,*(41W^I93;6UM5)>@/0;UCT6&3*]R
MBLUFBT0BJJO0'I%(Q&:SJ:X"(8W3JYSB\7@"@8`D2:H+T0:2)`4"`8_'H[H0
MA#2.T*??:J52F9N;RV`PW-W=N5RND9%>I7"[MK8VD4@D$`@4"H6?GY^QL3'5
M%2&D67J54P"@5"H%`H%0*&QJ:J*Z%@UBL]D\'L_=W1U#"AD"?<LI[3MY\N3"
MA0O+RLI&C!BAQM4:&1FQV>RI4Z>^^>:;LV?/9K%8:EPY0KI%/X^,M.G33S]5
M*I7??ONM>E?KX^/S^/'CC(R,^?/GFYN;.SL[O_WVVWEY>7B.#QD@;$^]D(J*
M"A<7%P`8-&C0_?OWU=CJN7OWKJNK:]=OA\%@>'AX!`<'Q\3$N+JZJFMS"-$9
MMJ=>R*I5JU0O3$Q,TM+2U+CF$2-&S)PYL^MTA4)QZ]:MK5NWNKFY65A8^/GY
M[=Z]N[Z^7HV;1HANL#TU<*VMK6PV6Z%0``"'PW%Q<2DJ*E+C^N_>O>OFYM;K
M@9Z%A85"H9!*I6K<-$*T@NVI@=NR98LJI`!`(I'<O7LW-S=7C>L?,6+$C!DS
M>I['V]N;S69_\\TW:MPN0G2#[:F!L[:V;FQL;/]QR)`A$R=./'[\N!HWT7.3
MRL'!@<?C>7M[)R8FJG&C"-$-MJ<&*#,SLV-(`<#]^_<S,S/__/-/-6ZEAR:5
MB8F)CX^/B8G)[MV[U;A%A&@(<VJ`UJY=VW6BO;W]=]]]I]X-[=Z]N]N!]<'!
MP04%!2=.G#`Q,5'O%A&B&SSN&XCVX0B=,!@,#H<C%`K5.RQS]NS99\^>[3B%
MQ^/=OW\_+2TM/#Q<C1M"B)ZP/340[<,1.E$H%&H?H`!=FE3>WMYM;6TS9\[\
MO__[OTN7+JEW6PC1$.94O[6VMO[TTT_/>U<JE>[<N5.]6^S82^7@X$"2Y-RY
M<W_ZZ:>=.W<&!P?OW[]?O9M#B&XPI_JMXW"$KL1BL=H'*,#3)A63R>S8=QX5
M%965E14?'__11Q_A]31(CV'_5+]U&H[0E;V]O9^?GWH'*`#`[-FS"PL+C8R,
M?OWUUXZWG;IW[]Z<.7-<75W3TM+PMGE(+V%.]1N#P5`JE;W.(Y?+U;O=NW?O
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M#D(#ASFEYS9NW+AGSYYY\^;MW;N7ZEH0&B`\WZ?_PL/#G9V=0T-#!0+!]NW;
M\9%_2.=@>\H@3)@P(3\__^+%B\'!P1*)A.IR$.H?S"E#X>3D=.W:-0"8.''B
M'W_\074Y"/4#YI0!X7`XF9F9`0$!/CX^^?GY5)>#4%]A3AD68V/CG3MW;MRX
M<=JT:4>/'J6Z'(3Z!/O1#=&[[[[KZNJZ<.'"LK*R#1LV4%T.0KW`]I2!^MO?
M_I:7EW?PX,'(R,B6EA:JRT&H)YA3AFOTZ-'Y^?E__/%'0$!`;6TMU>4@]%R8
M4P9M\.#!%R]>='-S\_7U_=___D=U.0AU#W/*T)F8F!P\>/#MM]^>.'%B5E86
MU>4@U`W,J1=RX<*%Z=.GJQ[;1Q"$L;&Q@X/#>^^]]^#!`ZI+ZY]//_UT__[]
M"Q<NQ*<K(QK"^PX/D%@LGC9M6D%!0;?O,IG,C1LWQL?'$P2AY<)>Q*^__AH<
M'#QOWKR=.W?BY36(/C"G!D(H%'IZ>C8T-/0PCZFIZ=RY<X\<.<)@Z-+@CZJJ
MJKESY]K;VW___?>6EI94EX,0`![W#8!2J1PW;ES/(04`+2TM9\^>7;Y\N7:J
M4I>A0X=>O7K5U-3TM==>NW?O'M7E(`2`.34`45%1-34U?9FSJ:DI-37UY,F3
MFBY)O=AL]@\__#!KUBQ?7U_5)8$(40N/^_KGT:-'-C8V?7_XL+FY^9`A0\K*
MRHR,=.]/PO[]^^/BXO;LV1,5%45U+<B@Z5+7"1VL7;NV7T](;VYN%HE$F9F9
MH:&AFJM*0]Y^^^T1(T8L6+!`(!!LWKQ9M\X)T(12J10(!$*AL*FIB>I:^H'-
M9O-X/'=W=YJ<3L'V5/\X.SM75E;V:Q%W=_=)DR;MW[]?0R5I6EE9V9PY<\:.
M'9N<G&QF9D9U.;I$J53FYN8R&`QW=W<NEZLK;>JVMC:12"00"!0*A9^?'QVB
M"G.J?YA,ID*AZ-<B#@X.'`ZGK*Q,0R5I04-#P_SY\YN;FS,R,AP<'*@N1V?\
M]MMO#0T-$R=.U,6F*$F2UZY=L[:V'C-F#-6U8#]Z/_4WI`!`)!)5555IHABM
ML;:V/G_^_,LOO^SCXU-<7$QU.3I#*!2ZN[OK8D@!`$$0[N[N0J&0ZD(`,*>T
M@"`(J51*=14OBLED'CAP8,6*%7Y^?C_^^"/5Y>B&IJ8F+I=+=14#Q^5R:=*M
MACG5/P/XVVAM;:TWW3IKUJPY>/!@1$3$CAT[J*Y%-^A*GU2WZ%,\7>K0%>;F
MYOU=Q-G9>>C0H9HHAA*AH:&7+U_^ZJNO8F-C!W`4C/I+)FF4O/#'_+BV4::.
M8JB".=4_K[SR2G\7L;"P\/?WUT0Q5!D[=NR-&S=NWKPY<^;,1X\>45V.CI.4
M[HH.)`B"X,>7=I<E1=],2;C>^,PD665R7"A!\/E\@A^ZI=NEGM7XG?WD@L<@
M*T\/)/A\/A$:GU:G4W]B,*?Z9_GRY?UJ#'.YW-+2TCESYFBN)$KP>+PK5ZYP
MN=P)$R:4EY=378YND@B%$D5IVO)5@]?)26E%RB*;[H8S,DU=!K$[OM&XR]=Y
MAUE4K?SFS:NU2:NG].4B3-,I+@#`L'L]J3:_J*AZ3$+DD=L2`)#4"76BG84Y
MU3_AX>%65E9]GW_:M&DF)B;!P<&:*XDJYN;FZ>GI;[SQAJ^O[Y4K5Z@N1Z?(
MA%F[8@E+QYQJA1P`BGZO5;"</#UM&2`K3>9')TL`9*7)_-!D"0"PX./-R_D$
M01"QN4*9K/3[5<5+,[>&V3(8#([M.#\_'@L4C25;`OD$GR`"XPOK%`"2]+A`
M@D\0_-C\#@TG!H?G9,L"A1S`R]G2#`"J?_[,C`A,SBZE>>L*<ZI_C(R,]NS9
MT\=;(+SZZJLY.3D)"0GTZ8]4+X(@$A(2MF_?GI65]<477_CZ^G*Y7((@N%RN
MKZ_O%U]\H7/WX=(TA428G1S/-YM5,#BJ04Y&>+`\WTI)<EOFR"1V994#@+Q9
M7)PB?O(B0PP``&(O[YA\DBS>6^-_H$@N;P%XR?K9U5[9[%7V]DFRB*QX7^K]
MP4\*X,Q).$\6D6<G))XO[?A864EF?#3!=$X(63_=B0$`'A'[I+4[6TY_PN1'
MI^66T[9MI9^_/QJU8,&"B(B(7CO4O;R\6EM;P\+"YLV;IYW"*$&29'U]_;??
M?IN7E[=JU:K\_/R'#Q_FY^>O6K4J+R_/W=W]JZ^^PK'$3]6E?.@X-28A[N:%
M]1%^5JH_=@S>DGUD]<WC!V:Y[BIL!.:369E/7X#,,C)H/`O`[?5`N'3[L5P&
M('O2_)$5AA*A^1+)[]G@Z6$'`/8N+I!2*E'4_?C/_PN-CDW]!;CLC@5P@K<>
M)LF&)%BP*O/)914L6\_8'>D7(ZLC_5TWIY=H_#,8$,RI@3APX$!P</#S;L]$
M$$104%!S<S.?S]?OVV,J%(K%BQ<G)B:>/7LV,S,S(B+"P\/#QL;&P\,C(B(B
M,S/S[-FSB8F)BQ<OQC.#``!@NV0?*:[XI7;'-((?FUDH5`#()!(%`&]<V([W
MX7]53\;9,0%^R\L&KR>+/:J5`$!U28%7P.@A8V:%P,?_S*H$`&"`&,0`'*<)
M<+]6U=_T`$)&$,5)"RZ]=NKPOJ5!`;)NKN&U&CD&:AJD``"*QORT+7R">9J[
MIEI*;@WSU,;',``D&I"VMK;MV[>SV6P7%Q='1T=S<W,+"PM75]>9,V?Z^_M;
M6EINW[Z]K:V-ZC(U*S8VUMO;NZZNKH=YZNKJO+V]8V-CM585?9PZ=4HNEW?[
MEKCZYI<A`7MOBHMWA@!XA00`>*TM%I.D_/;[``!>7EX``7O%)%F\-P3`*R#`
M"V#I+[5RDB3%MS-"`,`K)"0``)862TEI]<6H)\M$G;TC)FNOA`"`5T!45`#`
M^[>E#=],";XB(<4W]P($1`4`P-*;#21)DL5[ER[=>;96VGW]<KG\U*E3FOIT
M^@-SZH7<OW\_(2'!Q\='U;:RM+3T\?%)2$BX?_\^U:5IW(D3)P8/'EQ55=7K
MG%5558,'#SYQXH06JJ*5'G*J(ZFXH;9!W&&"7"SML)1<3I*D5"Q^=D7RAH;:
MAH:.$^7BCO/(I6(I29*D5/I,"$G%#;4-#;W7]&3+F%,Z[LZ=.__XQS^HKH(R
M2J5RU*A1AP\?[N/\AP\?'C5JE%*IU&A5V@$`/CX^%R]>['7./N84;=$GI[!_
M:H`^^^RS_M[@19]D9F8J%(I%BQ;U<?Y%BQ8I%(K,S$R-5J4U-V[<F#9MVI`A
M0W;LV"&3T?8LF?[`G!H(@4"0GI[^Z:>?4ET(97[\\<?P\/"^WYG(V-@X/#Q<
MGRY@)DGRP8,'JU>O'C1HT)(E2_[\\T^J*])GF%,#L7'CQK?>>FOX\.%4%T*9
MRY<O!P8&]FN1P,!`_1L.2I)D2TO+P8,'G9R<?'U]L[.SJ:Y(/V%.]=NM6[=.
MGSZ]=NU:J@NA4G5UM8N+2[\6<7%QT?7[</6`)$D\&-0<O#]ZOVW8L&'9LF4\
M'H_J0J@DE4H'#1K4KT4HDE4KE<GE+2XN&JJ*<ZF#P@P\^^.233\+"PO3L
M^G,J4=N-KW,*"PLM+"QJ:FJH+H1B9F9FY>7E_5JDO+S<S,QLTZ9-5._RVF-D
M9(3G^]0"VU/]LW[]^A4K5MC9V5%=",4<'1WOW;LW8L2(IQ,>WRE]X.#A:O%8
M6/J`X>%J]UAXYP'#P=7.HGV1>_?N#1TZ-#X^?O7JU934K"X<#N=Y;]G:VHX?
M/_[>O7LU-35+EBP9-6J4-@O38YA3_7#CQHW<W-R#!P]270CU)D^>G)V=/77J
MU"<_/[[E-OJUZQ+RY;*4T=[00*ZYE^+F+;M.;IC0ODAV=K:_OS^3R63^=>F:
M_N#S^<.'#\_+RQ,*A1]^^&%$1`2+Q<K(R*"Z+CV!.=4/Z]:M6[5JE8V-#=6%
M4&_.G#FK5Z_>O'GSDZ$)%A-(U<7&X]:H_F^UYIF+CY5*Y=&C1[_ZZBL*:M4D
M$Q.3R9,G*Y7*O+P\-S>WDR=/8I^4)N#YOKZZ>O5J04'!!Q]\0'4AM!`<',Q@
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MTB9L3_4N*ROKSIT[*U:LH+H0VF$P&`</'OSZZZ]GS9HU>?+D\/#P<>/&V=K:
MUM75%186'CUZ]/+ERQLV;/C@@P]T])G`B"8PIWJW8<.&M6O7#N#)?8:`((C5
MJU='1D8F)R?OW+FSM+14+!9;6EIZ>'B\\<8;B8F)#@X.5->(=![F5"\R,S.K
MJZN7+5M&=2&TYN#@\,DGGWSRR2<]S+-UZ]89,V9X>WMKK2JD-[!_JB<D26[<
MN/'33S]EL5A4UZ+S3$Q,%BU:]/CQ8ZH+0;H'<ZHG)TZ<:&AH>/OMMZDN1!^L
M7KW:V=EYY<J55!>"=`_FU'.UM;5MVK1I_?KU)B8F5->B#PB".'3HT)DS9XX>
M/4IU+4C'8$X]U]&C1Z52Z9(E2Z@N1'\X.#@D)26]^^Z[%1455->B)6UM;527
M,'#T*1YSJGM*I?*SSS[;N'%C'Q]]C/HH*"AH\>+%$1$1AO!$/S:;+1*)J*YB
MX$0B$9O-[GT^S<.<ZM[APX<!(#(RDNI"]-"77W[9W-S\V6>?45V(QO%X/(%`
M0.KFXZ!)DA0(!#2Y'R2AHQ^B1LGE<@\/CW_\XQ_AX>%4UZ*?;M^^[>/C<^;,
M&?V^<%>I5.;FYC(8#'=W=RZ7JRN7-[:UM8E$(H%`H%`H_/S\^OZT#LW!G.I&
M8F+BKEV[BHN+=67'TD6)B8F??_YY45&1E945U;5HD%*I%`@$0J&PJ:F)ZEKZ
M@<UF\W@\=W=W.H048$YUU=K:ZN;F]O777\^?/Y_J6O2<ZA,^<>($U84@NL/V
M0F>)B8G6UM9Z<W$_G>W?O[^@H"`Q,9'J0A#=87OJ&3*9;.3(D7OW[IT[=R[5
MM1B$*U>N!`4%W;AQ8_3HT537@NC+<-M3=75U!$'X^_O?O'FS?>)WWWWGZ.B(
M(:4U_O[^<7%QBQ8MTN.'9:$79[CMJ8*"`A\?'P`@"&+4J%%??OGEM&G31HP8
M<>C0H1DS9E!=G0%1*!3^_O[CQX_?N7,GU;4@FC+<G#IY\F3'GG(C(R,S,S,[
M.[O2TE*\4$;+*BHJQHX=FY*2$A041'4MB(X,][BOTXV]V]K:FIJ:*BHJK*RL
M/OKHHT>/'E%5F`%R=G;>LV=/3$S,@P</J*X%T9'AYE2WOQ(D238W-V_?OMW6
MUC8\//R//_[0?F&&*3P\/"@HZ,TWWS38!C[J@>'F5$U-30_ODB29G9V-)Z&T
MZ5__^E=%1<7V[=NI+@31CN'FU,.'#Y_WUJ!!@]YXXPV2)+.RLK19DH&SL+`X
M<N3(9Y]]UO$,+$)@R#G5T-#0[7175U<^GW_[]NT;-V[@,T6TS-O;>].F37C;
M3]2)X>94MSWE$R=.5#V=[?KUZRXN+MJO"N%M/U%7AIM3$HFDTY30T-#2TM*@
MH*#,S$Q\5!]5GG?;SX:&AE=>><7$Q`1/Q1H@P\VICM>O,QB,R,C("Q<N;-NV
M;?OV[7B;!&IUO>WGD2-'A@P94E149&%A45A82&EUB`*&^PLIE4I5+S@<3FAH
MZ+ESYW[ZZ:>___WOU%:%5%1C%"(B(IJ:FF;-FA41$=':V@H`0X8,^?777ZFN
M#FF;X=Y45[7?6UA8C!LW3M5KCAU2M+)MV[:77GK)VMI:]4VID"2)9P,-D.'F
ME%PN)PC"UM;6PL+B].G3V"%%*R1)KERYLKR\O-/TFIJ:CK&%#(3A7M]'$(2Q
ML?'[[[^_;=LV[)"BE=]__ST@(*#3A4T=-38V#AHT2)LE(6KI9'M*+?=R-3(R
MBHB(\//S.WWZM!IKZXAN-V_5"0D)">O6K>OAB4P.#@Z%A86!@8':K`I12_?:
M4[IR;WP:W@Q?)[!8+*52V<-3L\:,&;-X\>(U:]9HLRI$+=UK3PD$`@:#,7'B
M1((@J*ZE%[:VMH,'#[YV[9I`(!@S9@S5Y>B&PL+"=]YYY]:M6X\?/^ZV585=
MZ0:(IHV1'@B%0G=W=_J'E`I!$.[N[D*AD.I"=,:8,6.N7KVZ<^=.2TM+&QN;
MKC/4U-1@3AD:W<NIIJ8F+I=+=17]P.5R=>N92)0C"&+)DB7EY>6AH:$L%LO<
MW+SCNPT-#>7EY3@JW:#H7DX!`&W[I+JE6]72A[6U]?[]^R]>O.CDY-3I&7^J
MKG2J"D/:9Z"_0C))H^2Y';5]];BV4::.8E`/7G_]]>+BXOCX>#,SL_:TLK2T
MQ$,_@Z*G.24IW14=2!`$P8\O[2Y+BKZ9DG"]\9E)LLKDN%""X//Y!#]T2[=+
M/:OQ._O)!7CW$<UC,!@??OBA0"#P\_,S-S<W,C*JJJHJ*"B@NBZD/7J74Q*A
M4*(H35N^:O`Z.2FM2%EDT]TI3::IRR!VQS<:=_DZ[S"+JI7?O'FU-FGU%,L^
M;,ITB@L`*"1U==BLTKQAPX9E9&0<.W;,P<%!*I5F9V=371'2'MT;E_!<,F%6
MXF>S5B6FWI9Z`D#1[[6*0"=/3P"0E2;[_@.N'E["+$WV_02NGEH"+/AX\_+4
MC)1B6'JE>N=X\?>KBI=6%(79`@#'=IR?+0`H&DL2YD=MJ"\&F[4WCVT>9RM-
MCPM9D'T)8.DO%[[UM7VR647USW:C(]<F78R+"K35HX^SO]0R^+8O=NS8L7?O
MWLN7+V=D9+SXVG`LKD[0AU\LA41XY<3NN)@S8:F[&^3[K!@`KBE)A8Z.S&4[
MS]YY;^9(>;.X.`7@,,B;Q<5/]FVQE_=[^:<._[XOU.M`D3BT!>`EZV=7>V6S
M5]G;=\B(D969<<X?_"0_'#PGX3S)8F3%$N=+OVC/*99'!"G]6_;!K7;,SS>G
M?K9LGI\M2ZO_?#IH'WS+Y_.U,/AVWKQY:EE/^UC<W-Q<'(M+9WJ04W4I'SK&
M)$+2S=HEXYZ&!X.W9!\Y/39]EK<KW&R(83Z9S'SZ`F26D4'C60!NKP?"JMN/
M@V0`\*1C7588:K9YK?CP[]G@&6T'`/8N+I!2*DEZ[>(_UZ64`:<8QL<^6P++
M-C!V1[7;-L>I_NEKC^=L#;,"PZ)#@V\[P;&X.D$/^J=LE^PCQ16_U.Z81O!C
M,PN%"@"91*(`X(T+V_$^_*_JR7VFF`"_Y66#UY/%'M5*`*"ZI,`K8/20,;-"
MX.-_9E4"`#!`#&(`CM,$N%\K`0!)W0,(&4$4)RVX]-JIKU#'M@``(`!)1$%4
MP_N6!@7(GLEW17E^6C2?B#K&+:Z5%AE>2(&N#;[M!,?BTI\>M*<``#A.OFL.
M%[TK+-RS/.K^AHS7KT9[K;H7$E"<4;^V>#./8S;]?1AM1ASP\BH&FUD`P.1"
MPJQ9OP3`I4L3?JGU!A;C\.V,Z-'.A%=(B$W&)5AJS@3^QHNICHY\+Z_B8J^S
M=]8.LOQOR"5_@G\HR@M2O#<$2S>H-BTI//#.[I:=%Z2>!GB\]Y3.#;[M!,?B
MTISN78><D9$1%!3$8/22L#))HT3!L+5JOZN40B(##NOI4@H%,!@RB83!X718
MD:*QL1&`Q;%JGZB02*1F[?,H9!(%B\,"F4S&8O4UE10*Q9DS9T)"0OHXOR[J
MXY="6X;P'>DT7=VQ>L7B6#T;)`Q.QY\9#`!@=;XW'L/*RK;3E&?NG\=@J1*K
M[R&%^DXF:92;67%>;)=\7-O(L+/"KT?/Z$'_%-(16AQ\*ZO,"N7S^001&I\F
M?.$+#Q#E,*>0YFE]\"TP';=D7BTB:P-_B=Q]O0X`)'5"'(VKNS"GD";)A%F[
M8@E+QYQJA1Q4@V]93IZ>M@R0E2;SHY,E`++29'YHL@1`-?B63Q`$$9LKE,E*
MOU]5O#1S:Y@M@\'@V([S\^.Q0-%8LB603_`)(C"^L$X!($F/"R3X!,&/S:_[
MJ^'$XGEZ.G$`;$>Y07VC'`"J?_[,C`A,SB[%UI4NPIQ"&J&0"+.3X_EFLPH&
M1S7(R0@/EN=;*4ENRQR9Q*ZL<@"0-XN+4\1/7F2(`0!`[.4=DT^2Q7MK_`\4
MR>7/&WQ[DBPB*]Z7>G_PDP(X<Q+.DT7DV0F)YTL[/SA64I(\*W'IB@`>`'A$
M[)/6[FPY_0F3'YV66XYM*]V".84TH2[E0\>I,0EQ-R^LC_"S4AW,,7A+]I'5
M-X\?F.6ZJ[`1>AY\>^GV8[D,0/;7X%LB-%\B^3T;/#TZ#+Y5U/WXS_\+C8Y-
M_06X[&<JJ,R,M_0JNRW>Y_GT1`C+UC-V1_K%R.I(?]?-Z24:_@20.F%.(4V@
M>/"MK#3-.>3/8NE6C[_&I33FIVWA$\S3W#754G)KF*>V/@JD!IA32%-4@V_%
M9V-+-T<=*)3\GA3-)/BA@<34[+4K`GB<T=/?AU5F!#_FNPRP,86G@V\#`_FN
MD>:)R[R!Y7GX=L9OLYP)?FCH=.]+X&;.A"D;+SZ<Y<CG\^VF_GGVJQF#AKT6
M<BF&X`<F_@D?>V]H/R'XV_GO`5*B?`F"(/852@"@Y,`G_WXX_H*4W!$[DX?#
M%G2-WH[SI`]#&$.H<X-O.S&$[TBGZ<QO.](#./@6#0P>]R&$Z`YS"B%$=YA3
M""&ZPYQ""-$=YA1"B.XPIQ!"=(<YA1"B.\PIA!#=84XAA.@.<PHA1'<ZF5-M
M;6U4E]`/NE4M0C2D>SG%9K-%(A'55?2#2"1BL]F]SX<0>@[=RRD>CR<0"'3E
M-@\D20H$`AZ/1W4A".DPW;M?@KN[>VYN[K5KU]S=W;E<KI$13:.VK:U-)!()
M!`*%0N'N[DYU.0CI,-W+*6-C8S\_/X%`4%141/-GV++9;!Z/Y^[N;FQL3'4M
M".DPW<LI`#`V-AXS9LR8,6,TM/Z0D)`S9\XH%/AH$H1H02=S2J,6+5J4F9E)
M=14(H;_0M'.'*HL6+3IZ]"C552"$GH$Y]1<,*83H"7/J"0RI%Z33PUEUNGA#
M@#D%@"'UPG1N\&TG.!:7YC"G,*340+<&WW:"8W'I3_>>WZ=>/824@7\R_:)4
M*G-S<QD,!LT'WW;2<2RNGY\?#G.C+8/.J9Y;4H;\R0R`4JD4"`1"H5!K@V]#
M0T,!P,C(R-C8V,3$Q-34E,5BF9N;6UA86%A8<+E<*RLK:VMK:VMK.SL[*RLK
M,S.SKBO!L;@ZP7!SJM?#/8/]9'2%BXM+145%'V<V-C;&@;NZ2S?:YVJ'?5)Z
M(#HZNB^S<3@<$Q.3_?OW:[H>I#D&VIYBL5BJHX!'CQX];Q[#_&1T2$U-C8.#
M0\_S3)TZ-3\_/RTM;>[<N=JI"FF"@;:G[MV[MV[=NN'#A[-8+!<7%Q:+175%
MJ-_L[>V=G9U[F"$\/!Q#2C\8:$X-&3)D]>K5145%-V[<"`L+XW`X`#!LV#""
M(*@N#?5##X=^X>'A/_[X(X:4?C#TZY`]/3VW;=LFE4KOW+EC9V>7GIX^:-`@
MI5)94U-#=6FH)R*1Z-BQ8V?.G.GV70PI?4,:/*E4:FUM??WZ=9(DFYJ:4E)2
M9LR886QL3'5=J!M*I?+"A0N1D9%F9F:OO?9:8F+B\.'#.^W2X>'A%A86F9F9
M5!>+U`9SBDQ-37WII9>HK@+UHKR\?,.&#<.'#^?Q>!]__'%I::EJ^OKUZS&D
M]![F%!D0$/#--]]0707JWN/'CP\>/#AERA06BQ46%J:Z?V''&1X\>(`AI?<,
M/:?NW+G#8K$>/GQ(=2&HL]S<W+?>>LO"PF+LV+&[=NVJKZ]_WIRJLWX84GK,
M0,_WM3MPX$!H:*B-C0W5A:`GJJJJMF[=ZN;F-F_>/`L+BVO7KA46%JY<N=+:
MVOIYBT1'1P\:-`@[SO68@8[S5%$H%,.'#S]\^/#4J5.IKL70R62RC(R,I*2D
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M99SGHT>/OO_^^WXMLF;-&CU^K-N%"Q<F39ID;FY.$`1!$,;&Q@X.#N^]]U['
MRU#Z12*1'#AP8-*D2:^\\DI%14524E)%1<66+5LPI)`:4#H:7GN6+5O6WT]F
M\.#!/_SP`]6%JY]()!H_?OSS_M5,)O/SSS]O:VOKX]K:VMHN7;KTYIMOFIN;
M^_CX[-FSI[&Q4:/U(P-D*/U3SL[.E965_5K$W=U]TJ1)>G9?;36>2:BLK#QX
M\&!R<K)4*HV*BHJ)B1DS9HRZZT4(P'#ZT9E,9G\?-^+@X,#A<,K*RC14DO:I
MY4R"5"H]<>)$4E+2M6O79L^>'1,3,VO6+#PWBC3*4')J`..A5`]ZT*<+,OKU
ME!US<_/#AP]W/)-P_?KUI*2D8\>.N;BX+%FR)"HJ:O#@P9JI%*%G8$X]E[FY
M>7-SL]Y\/H\>/;*QL>G[F0%S<_,A0X:4E975U-0<.G0H*2GIX<.'$1$1,3$Q
M8\>.U6BI"'5B*,UU@NAW(EM;6^M-2`'`VK5K^W7ZLKFY6202969FWKIUZ_KU
MZY]__GEP<+")B8GF*D3H>0PEI\S-S?O[/'%G9^=NG_2MH\Z>/=O?16QL;'[\
M\4<].Y.`=)&AC)]ZY957^KN(A86%/EWA45U=W=]%1"+1E2M7-%$,0OUB*#FU
M?/ER(Z-^_&.Y7&YI:>F<.7,T5Y*6]?=T)P"(1**JJBI-%(-0OQA*/WI;6YN=
MG5U]?7T?YY\_?WY)2<GMV[?[E6YTAF<2D.[2DU_"7AD9&>W9LZ>/PWQ>??75
MG)R<A(0$O0DI&%!.65M;ZU,/'=)=^O-[V*L%"Q9$1$28FYOW/)N7EU=K:VM8
M6)B>783<ZS^\*V=GYZ%#AVJB&(3ZQ8!R"@`.'#@0'!QL:6G9[;L$000%!34W
M-_/Y_-V[=VNY-DW#,PE(=QE63C$8C+2TM`T;-K#9;!<7%T='1W-S<PL+"U=7
MUYDS9_KY^>7FYBY;MNS@P8/Z=R$(GDE`NLL@^M%/GSY]Z]:MM6O7MD]Y\.!!
M<G+R#S_\4%I:*A:++2TM/3P\WGCCC25+ENCK_='Q3`+27?J?4Z=/GXZ(B,`G
M4`+`\>/'(R(B^C)`X=577[UW[UYB8J*>==(A':7G.84AU<GBQ8O3T]-[OKC:
MR\L+`%Y[[;6]>_=JJRZ$>J+/37H,J:X&<";A\\\_GSESYJ%#AR02B18K1>@O
MQILV;:*Z!HW`D.J6D9'1_/GS34Q,KEV[-G3H4#:;K50J34U-AP\?[N/CP^/Q
M;MRXL7KUZFW;MAD;&ZL6&35JE%0JW;]__\<??UQ24F)J:NKBXM+^+D):H)_'
M?1A2O1K`F82RLK*4E)0C1XXT-#0L6+`@,C)RTJ1)^*!#I`5ZF%,84IJ6GY^?
MFIKZ_???FYJ:1D1$1$9&OOSRRU07A?29ON44AI36J)[0EYJ:>NK4*1<7E\C(
MR$6+%@T?/ISJNI`>TJN<PI"B1'-S<V9F9FIJZOGSYR=,F!`9&1D6%F9M;4UU
M74A_Z$].84A1KKZ^_OOOOT]-3?WUUU]GS)@1&1DY=^Y<O)(9O3@]R2D,*5JI
MK*Q,2TM+2TNKK*R<-V]>9&1D8&`@GB)$`Z9+XZ<R,S.93.;ITZ<[3<>0HALG
M)Z>U:]>6E)3DYN;:V=F]]=9;CHZ.[[__?D%!`=6E(9VD2^VIEUYZZ;???F,R
MF2=.G&B/)`PI^B-)\LJ5*ZFIJ>GIZ8,'#XZ,C(R(B'!S<Z.Z+J0[M/OXY8&[
M=^]>>\U,)C,S,Y,DR<S,3`L+"]5K1'\M+2T__/##@@4+S,S,QH\?_\TWW]R_
M?Y_JHI`.T)F<"@X.[ABO3"9SW;IU&%(Z2B02)24E39LVS<3$9/KTZ0</'A2+
MQ507A>A+-W*JI:6EVQM"K5NWCNK2T`NY?__^UU]__>JKKYJ9F2U<N#`C(Z.E
MI:4O"UZX<('!8!PY<D33%2(ZT(V<6K=N7;<'K>T'@$C7"02"#1LVN+JZ6EM;
MQ\;&7KY\N:VMK8?Y)T^>K-H!=NS8H;4B$55THQ_=VMJZL;&QV[<Z=:LC79>?
MGY^6EG;LV#%34]-%BQ9%1D9Z>GIVFJ>MK<W4U%1U(RT3$Y.XN+@OOOB"BF*1
MME`=E+W+R,CH^9^`K2K]HU`HLK*RHJ.C+2PL7G[YY2^^^**RLK+]W4XWQC(U
M-8V.CE8H%!06C#1*!]I3JN$(W;YE8F(R>?+D>_?N"87"_CZ6'>D$J53:?E&.
MCX]/9&3D@@4+_/S\.NT2IJ:FDR=/SLC(8+%85)6*-(?N.5514>'BXM)UNKV]
MO:^O;WEY^8,'#]YYYYWERY</&S9,^^4AK:FOKS]^_'AJ:FI^?KY<+N\Z@ZFI
MJ:>GYX4+%[A<KO;+0QI%]YP*"0G)S,SL.(7/YP\?/CPO+V_8L&$K5ZZ,B(C`
M/Z$&Y=UWWWW>#9&93.;PX<-S<W.'#!FBY:J01M$ZIUI;6]ELMJJ[E,%@!`0$
M*)7*O+R\.7/FK%RY$A\M9YAX/-[]^_>?]ZZQL;&-C<W5JU=QO+L^H?7U?5NV
M;%&%E(^/C[N[>V%AH8^/3UE9V?'CQS&D#%-Y>7D/(04`2J6RKJ[.V]O[YLV;
M6JL*:1JMVU.JOYRJYX#B(1X"@(B(B"-'CO1E3@:#D9J:NG#A0DV7A+1`G3E5
M75U=7EXN$HG:VMHZ3G=W=_?P\`"`BHJ*HJ*B;I<U-36=.7.FZG7[0(1Y\^:-
M&C4J.CKZI9=>4DWQ]?55W;W[O__];V5E9;>KLK>WGS!A`@`\>O3H\N7+SZMV
M^O3IJELCY>3DB$2B;N<96.4,!H/+Y;JZNNKK(TN?IZJJJKR\?,*$"::FIM#A
M.^KZ,7;]CKK=`;I^1]'1T6UM;?;V]JK[LC,8##:;S6:S29)L:FH2B41RN;RU
MM?7QX\=-34U&1D8G3Y[L^\J[[ETO7OGUZ]=;6UO=W-QX/)Z&/G9#H+:GDQ<7
M%W>\5%@M5#N9SE$H%/7U]?7U]2-'CC2<&X<+!(+2TE(`>/3HD;V]O8:VHDH?
ML5AL;FYN:FIJ;FX^9,@0)R<G*RLKDB3%8K&%A<6P8<,F3IQH965%$$1A8:&&
M*NFCUM;61X\>%104>'AXN+N[4UN,[E)/3C4V-JH]I'1"2$A(UQ_;_ZB6EY</
M'CS8$%I5(I%((!"H7FLTIZJKJ_O2Y.'S^:I*-%3&\W3:'P!`-82"(`@C(R.2
M)/'Q/`.CMN,^B41R^_9MF4S&Y_/9;';'MXR,C(R,C`"@K:VMTR%A1^U7&O?P
M8'%C8V/5-ZU4*I]7.4$0JEM'DB2I5"I[754/F^NY<@:#477M6MWWB8K&.K*V
MB;!C,ZQL;1<N'3IQ8FYN;D-#`P#8V-A,FC3I>>O7)ZH=H*6E9=RX<:H=H/T[
MZOHQ=OL===T!NGY'77<`^JS\>3O#K[_^.G+D2"LK*W5^W`9&S?WH!O47H^K:
M->&6>'O>,(Z+F[DSK[E"*+GW>XWP3][ZK4,G3FSOJPH*"J*Z4NTQJ!V@HYYW
M!JJKTWEJ'I=@./NH:K_T"ISA].\4,P"R0F@&X/3O%*_`&<(M\577KJD.`7IH
MK.DEP]D!.NIU9P``F4PFD\FHKE17J2>G_OM4#\=9>J8E]:0=:TC;H\>0DV.V
M?B,I;3%;OQ%R<MH>/;9C#6E)/0D`7"[70*[A,,`=H*.^[`SGSIT[=^X<U97J
M*O7D5.53=!Z-I5Y-_RFQ&,Z#II;F4Z<!P'SK5LC):?KA1VAJL1C.:_I/"0!,
MF3)ERI0I%!>J%0:X`W34EYT!O0BMCD=/Z'(C(=TEO?NGF42A**I0_/?),"[Q
MIMW*H@I%4:691"&]^R>UY=%327R?AFCJ'-P9-$U[.:4:%-?#P,OGD55FQ45'
M1T='AX8&QJ>5:J"TSDJ2X_>6/.YY'K,1PZ1-$L*"9;EIA6H*86&J^D_:)#$;
M,0P,J4O"_2G5V;%NO>@.$!H:';<MOW)`GZ>L,"XVN9=O]`7T96<(#@[N=(]_
MU'?:RZF\%2M:P\+R5JSHQS(2H5"BD->7?9,R[-.OO_[NNY2X6<XO6(:L9%_T
MKN[&_LD*8T/W20``8.B$L&E#>[E`ASW64UQ7S_GP'9@R11SQ-N3D<'Y,)2W-
M2$LS<5T]>ZPG&%*7A,=3/>24]3GA2=,RZW/"?JRWXP[P_W8NL$Z=L.KD0(**
M,30Z=I)F+KF20=]V!H(@#/,D@UIH*:>NAX6UAH5-+REI#0N['A;6^P(R8=:N
M6,+2,:=:`4P`+R=G6UL>CV=KQ1)F;2%"]S4"0&5Z8."N.H"2Y+C`Z&@^01!$
M;*Y0!E"7'A]*$`0_>I]0`0"2K"VA!$$01&QA7>GFJ&4IJ[P#8],DLM(X/I_/
M)_BQR74@2U_[86+&LDG\N!()5/V2?J&J?3U\@@A,*ZP#@)+DN-"XN$""``#S
MP*FBZ@<P98KD[^\2+*;DT#'(R;%,V\]P&2JJJ3,/G*K9#U37U.<)3IJ6K?A;
M^$G3LOH\0>\+=-P!`,#+R=76:790)&0\E`,H&@OC`_D$0<3NRU>H?N03!#\P
M-)0?FUP"($F+#MQ7(@&0/7FAJ#J\[ZKLR:X22A#1A1)%25H\01`$/S97J`"0
MI,6&QL9%$P01O2T];4LH01"AVW(57;8E*4D.#8V+#20((C"]5%*>OAEP9]`\
MC>?4Y<N7$SP]SWMZ3B\I:5VY<GI)R7E/SP1/S^>U_Q42879R/-]L5L'@J`8Y
M&>'!`C"%XF6S0P/Y_+@2"?!F?G3<?MG\;<GQP5O>_FZI+8!<7%0_*C*?)(OW
MUO@?**K+WKK@MR@I*=]BOFSW]<:Z[(19&[RKY21)?NMEZ_%1XI<!FZ]D[XO@
ML%P3;A85%54')1XJE;#"-G\6XO7EA:(=GAR0U_ZOMDE>E[UCP9]14K)(7O%^
MI/>Z2@`0%V4\')]!2M.CB2%ALQVV;OK/Z`D/:^M:+,R,1SD_/)EY-VB!X(=S
M#IO7#PF;W>OMDO5)Q5-=1\->OGRY)/[([I^/KOA;^"WY@Q5_"]_]\]&2^"/]
MV`&8IE!\;,.6.&_OK-3B:`[`E<W>?[Y]DB0KS)<MO2Z!*__T_G/]';(H^XN%
M$WZO;0:`A\671'(`D#\LOB22*T#1>O=ZK1Q`+BZZ-/CO8O+P.-D%K\CZVW*R
M8@OX[[X.`))?,LP#-I'BF]4?+RB?^!TIOB).O2[ILBT`<4;&PQ499,5QMRW'
M?QL9]M&NP-!>=X9S3VGV:]!?:KN^KUNJCO,G+:F5*P&@=>7*Z?_ZU_FPL+P5
M*_(`UI9T.A52E_*A8TPB)-VL73+.]NG$%H`OCYU:8Z50,!@`P`K;?F6!I?^E
MM5=(#Q8`@,PR,F@B"\#M]4!8=;N46P09W[P3'26ICEIHR[A[_(S7SA0>`P`8
M#``&$P!,`$!15_S/#S:7F=L7@V4(J":R.GX<?_YZQFM\&`L`[(<&P"]_2(`M
ML_PR;BX'6",\0[;D-ZX/FPT`S=D7A04ETLIS9DZ.[+&>#C$Q0\)F&]JPJ?:+
MM(<.'=KQT*\D_H@U@*HE=4O^``#:HVK>.2@Y=\1SZZ)GU_2\'6#"M/&#$@!\
M1UL!2/ZX!RG?O`-G'24A08.8DKPSX!EF!P#.GB]!><>U,4U5!V8``*8``#++
M+Z,#.`"2/\L`$C^):>9(JM<NM`50M-B$A$\?"5`($!#T.@_@3TN`+ML"D,L"
MOHSSY(!DQ$LVMY^L.E<"?CWN#`;23:DYFLVIM24EER]?SENQXGQ8V/1__:MU
MY4J3?_WKO*>G27KZZ[MWJQYM]"S;)?O(^?'Y>]9-(XHG9"1MG#V.!W(`8+'^
MNO1!EO[ABJ4[=]:L6I$9>S/8B0$`CVHE`)SJD@*O@!4>+_,A9'G2X3#5W'43
M@XKC+C6^YVD%H`"`IW>L+4Z*N33U9/82NRV)T<`$D(,89!T_#@>OP.)SM0``
MTD>7P.O_F8$(H$7^3``-"9L-8;/5_;'I#\^MBRY?OCSO'+2WIUYF.NS^^>B\
MEE$-,WC]V0$<_&>^=V4SWS4F37HX8K@+1*7^O\,1(P$`0%;B`J6U$@!.T:53
M8#H)`)[$DZ3H;#$$/EESRY/_R14`P!DV"F#I5X?WC7SR;B,`M,H!F```\J<O
M`#C/;@LD`-"BVH>>1(^L7JQZ@3N#YJCGN,_^J:X]A9,G3UY;4J(ZW%.%U/22
MDK4E)=WMHT]PG'S7'"X2GXTMW1QUH%`"3$N`59/X@7P^P8]-_RUS[0+8LN^]
M]Y*N1(8X?U2I`"87$F8YA@;R72/-$Y=YV_I_E.2RA4D$!A+\?8426_\521,.
M6!-\/D$<*)&8.7C!A@G\N'2KU]ZZ%./*#XPN"\B8L"I=9N80`!];\N-+90``
M+`#>M/?W/OR8X/,)ZZE?GMTTD@'PY(]R^PM)<G3HKJP2_%O9\P[@N761J@VE
M"JD5?POWW+JH/SN`*7B!%,!O?>;:E,BUF97^\;\,_M*5"`SD$[&%$M:L#4G?
MS'(D"/[N['I+%@!PIJU__V-O2_ZDI1D`IDP&`(#-DZ_NR?]LI_V29.Y*$*&!
M_.A]G<ZK6#)5(67#`H!GMP4`8/ET)[`$`.!X!8&_)3^]5"(IW!<8O:NDKO/N
M8&QL[/]4_SY6])3V[I.7X.G9&A9FDI[>Y5CO1>5O";T\/6D-WTS!^NO`32&3
M*,"L?8),(@$SSI.?%#*9@L%B,10RB8+%88%")@,6BP&@D,@4G&=OQ??,@GVF
M4"C.G#FC>MWU&GK#5!)_Y*1IV;R645V.]0:HTW<J`1;S]J[9IWRSU_L^G<#I
MY7M3R"12X'!Z/Q/8\VX@D\@8_=Y'4#]H;US"Z[MWJP[WU+YF[NC7AW(9P'IF
M1V&P.!TGL#@=]B,&2_46@Z7:0QE/YV1PNMPO])D%T0MHF,%3'>ZI:X6=OE,.
M`X#)FSF2VW%"+QBLOH14YVUU\R[N(YJEGO94^XU^N%QN#X-$$CP]U=Z8HB=#
M:T_U<0<HB>_:<:[_E$IE04&!ZK7J7J"HO]234^WGX(."@MIO]&/(2))L_]4U
MA!L/X0[0`T/[HZ4)N$MI!$$0AA!/"&D'YA12`]6#&U"WC(R,5/=!1@.&.:41
MAM8ET?[`%=25D9&1L[,SU57H-LPIC2!)LJ:FANHJ$-(3F%,(:59;6UM969GJ
MM>K1.*B_,*>0&N#YOAZTM;6U/S0,<VI@M'H_3X00&@#\TX>09A$$X>3D1'45
MNDT]XSS;;UMA:FJ*-RT$PQO:ASL`TBCUM*=872Z+0P8%=P"D47C<AY!F=1RD
MXN#@0&TQ.DH].963DZ-Z,6G2)#S=`X;7)8$[0`^42F5^?K[JM2%T`FB">G8I
MD4BDEO7H#6-CXU=>>87J*K0'=P"D4?BG#R&-XW*Y5)>@VS"G-,+0NB1\?7U5
M+XR-C:FMA(88#,:4*5.HKD*WJ2>G&`R&Z@DKS<W-EI:6:EFG3I-()*HN"0:#
M$1041'4Y&F<(68PHI)Z<XG*Y]?7U`%!45,3G\\W-S?_:P-->U1X>%65D9*1Z
MF%);6UO7!\!U6A5)DDJE\GGS&!L;J\;O*)7*YPT-(PA"]6>_+YL;0.7-S<WM
MSXDRJ`9_2TM+65F9DY.3ZF]5QV^JZW?7]>/M^MUU_7C;OSM=6?GCQX^+BXMM
M;&Q<75VQL3E@ZAGG^>#!@_8S&IVTG^#(RLIJ:6GI=IY77GE%=7:LM+2T_4JH
M3@8-&J1Z0HE4*CU__OSS*ID\>?*@08,`X)=??GG>'0N<G)Q4G=SW[]^_<>/&
M\U:EELI]?7T-I*TA$HGR\_.E4BD\_>C:/]YNO[NN'V_7[Z[KQ]OUNZ/YRF_>
MO%E5504`;#;;S\\/;]0U,.JYOL_!P6'DR)&]SV=@1HX<:2`A!0`U-36JD$(=
ML=E5[T(<```!O$E$051LU8OAPX=C2`V8VOK17W[YY<&#!]^Y<T<D$AG:TX`[
M83`87"[7U=75<$(*`$:-&F5I:2D0"'",0D<6%A:#!@T:.7+DT*%#J:Y%AVGO
M^7T((30P>%\7A!#=84XAA.@.<PHA1'>84P@ANL.<0@C1'>840HCN,*<00G2'
M.840HCO,*800W6%.(83H#G,*(41WF%,((;K#G$((T1WF%$*([C"G$$)TASF%
M$*([S"F$$-UA3B&$Z`YS"B%$=YA3""&ZPYQ""-$=YA1"B.XPIQ!"=(<YA1"B
M.\PIA!#=84XAA.@.<PHA1'>84P@ANL.<0@C1'>840HCN,*<00G2'.840HCO,
M*800W6%.(83H#G,*(41WF%,((;K#G$((T1WF%$*([C"G$$)TASF%$*([S"F$
M$-UA3B&$Z`YS"B%$=YA3""&ZPYQ""-$=YA1"B.XPIQ!"=(<YA1"B.\PIA!#=
M84XAA.@.<PHA1'>84P@ANL.<0@C1'>840HCN,*<00G2'.840HCO,*800W6%.
M(83H#G,*(41WF%,((;K#G$((T1WF%$*([C"G$$)TASF%$*([S"F$$-UA3B&$
8Z.[_`XZ*0%JL'V$'`````$E%3D2N0F""
end
MB5!.1PT*&@H````-24A$4@```TD```*7"`(```#86);\```7-FE#0U!)0T,@
M0L0````)<$A9<P``"Q,```L3`0":G!@``"``241!5'B<[+U[G!3%U3[^G*J>
MGAEV5A%0=P4514T@@-]X0?-ZB;>`P2MB)`F(BC%&T("R7J("+Q+QPH)70(P8
M15`A`1(3,:*\FDA>HY+X0XTW!#&*$E\P)"R[LS-=5;\_JKNG9V9!5-AM=L[S
MB63VG*=J3G?-G#E=5><4&6/`8#`8#`:#P6@7$&UM`(/!8#`8#`9CAX%C.P:#
MP6`P&(SV`Z&44DJUJ&,5JUC%*E:QBE6L8M6NI2+>;\=@,!@,!H/1;L!KL@P&
M@\%@,!CM!QS;,1@,!H/!8+0?%,5VY8NX+&$)2UC"$I:PA"4LV84D/&_'8#`8
M#`:#T7Y`GN<!D%*6ZVP`R"I6L8I5K&(5JUC%JEU%Q7FR#`:#P6`P&.T'O";+
M8#`8#`:#T7[`L1V#P6`P&`Q&^P''=@P&@\%@,!CM!QS;,1@,!H/!8+0?\'FR
MK&(5JUC%*E:QBE7M1R6DE&$R;4F#;2?9<BMNQ:VX%;?B5MR*6W&KN+5RRMLS
M&`P&(SZ8.'$B`"EEN2MG28EDPH0)8#`J'ES?CL%@,&*-B1,G7G[%0-=-$`%`
MX+0),`"(J$02O*"*XN=RWKWW++G@_`N['[C_E[_7#$:[`,_;,1@,1MR13+J)
MA+_@8H,;&_@8X\=`Q9)H`+0M_MR;AF[M'8>-G_?5^V]-/D``UG^\'@"'=XP*
M!\=V#`:#$7\0D1_;V?C&KKH0"6.,,;`OB/RY+@#ABVWP`0P=-Z?\S>9-&@Z(
MK]Y_Z_*Y[`.#X<,)=^>5ZUC%*E:QBE5Q4(5S6)ZGB$A*`3_Z*40W6AMCM..(
M(`Q"&`\II0$C)47Y1*0-*64`2$F(0!L"2&L-P+X7`&I>==69=_P=`."Z^]T\
M[YJ^NTO;?]`A`-+:=MCTX("QN?K;+NM;'=JCE#'&.(Z,\JT]2FD`0B!BMO]"
M:U@+2ZZ7R-X-2"G+-Q?%=BA9Q:I64#DM,BQ8Q2I6L8I5<5`1"1@"D>,X=B\:
MC($-JHP!`2`91$:`(1(P!OZ\EI%2PI_]*O!AC*<@A%MX&^/O8?,48""E4\S'
M1G08-^?6HSOFLUXB4R6#2*M@SUNS;QB3&_[T98<`J=-FW>CLLSN0FSOXIPT3
MIOVD3SH($UNPW[>P)?NE;/EZ88SC.!%^47@:VZ%D%:M:0<5KL@P&@Q%_$$@$
MJ0,"L+->!B#[@D`F"(R*"=OB>T8L>&A&>3Z=9T3P=B7]ISMW<1TGF0&`QL77
MUZ_J<?#:^<^O1M>Q]]<=G__SF/D;@3L&K#IKT;037OS%@[CHZCYO//3(9J#N
MJE6#SVQ:^,9EBZ[IDQ'>^I<NOO;]:0\/Z?S5["_F\YHL@^SL&@\'8)6!#
M&1OC^)-P!#(P@#"%'-)H]NCG\/-:#+GHDO)WFG'C7UKD5V'C`U/G[H?FZG[?
M'7%BI_RZ=<M68-*<R9ONOW[J4VO[7_;M\0.7W-1\[J.CCJR"]]D['^>S:M`9
M@P?.7-G\L^M'?JOC@H5///Z_G_;M7_/6XL>W''U)9]!7M+\E/H/!*#YSK*1<
M$$M8PA*6L"0.$H+0VA`$0`8@"")2RBY;"H`(@B`\3Q,1("R!()0R(1\@`](:
M(3^O!`"[Y:[HW9$*^;9_K4`0``[N_;7#^_7J79/1&OD&#*J_IE]-E_VZ=JZF
MA%*)3M7IZMWWZIQ)$81-?Z#$[IVKL5OGO:O3>PP8W>NU^2OSV/#XXL81Y_0L
MM\=>CU(([;?7JQ5:M,?R[?7:?7XQ&2^6L*1M)3QOQV`P&/$'&1/6?"-C#!D_
M,<)/(["%0B#"XG!A<1`_I=3XF0A!;3@RQN04&9,P1OO/^<%^NYPB%/A!_T`C
M.A]SZK?Z2$,@3S4T`R!-)/(`#`'D%2;1_!C4GT[SM#'H^NV3,C-_/7_!1RMJ
M3[]^;P<P)?908;JA8#]`!JI%>P*^O=Z=/`(,QJZ#HCS9DCUZY2%AR.%6W(I;
M<2MNU7JM2#A.`H#R=)!Y`,<1")8J`6BE0,(8(@B0OT)ILQ>TUC"0C@3@2&%U
M!)-7-/7.A3"P*;$AO%P>$'Z>K)`@2`E``-G&?^6H(VW):2<E`1O2V1P.<IP$
M<MGF?$YKDE(0H$D:0[G-^$^3)I*J0\\1W_RL_H'U)T^X+0/?#&N/4M9"88QQ
M9"*T'P9*:R()"/+-AF^/,4H;8XPC)0CV_L1EO+@5MVK35IPGRRI6L8I5L5<9
MV,Q0Z4@$$U<`"KFEQD@GL@YCY<&_4@;S9Q$^2.2UN/[*,\L-F'CETR"24A;S
MJ3.VC/_A2,L9?O>4)`!*P"#AII`C@`X\^8S<J+N_^]:YBV:>X`)`@JC#\2,/
M&S5Q[-KA-\P<UJ/?&8?AI0UG'K%GB?UADB]%Y<:`;/XO6K2_<)_"+.`O=WM9
MQ:KVI>(U60:#P8@]R$\%);N0Z:]\VD#'3QRUZZD$LFN9@/E<?EZWG%N:U\':
M;I2?ZCGMF5_Z_=O>%CUD>^YU_L\7`H#)'#)@Z5,G;O&<*A+G+WK(VG/PH)\N
M^4ZCETJ#:,.[ZW#LF;U28H?87\QG,!@^.+9C,!B,N(-@,P9LQBB,OZG.2JQ0
M`(8@#`!CB,@4,DRWRO<4&9-`&!H5ZMO9O[]4_TZJRC%!X.7S$YDJ!R#ODX5S
M/KOL%WUWE/U1?DEJ((-1R>#8CL%@,&(/>W8JB`HKCU823*\13&0NRRYH?BY?
M&3%VY&7E[R:%L&D*7['_4KZSSW7/S-R!]A?Q&0Q&`([M&`P&(_8P1+:HFY]/
M2I$";X;\0[J"W%((F*`4W#;Y4V<^`D3S%@SMT/Y;E\_S=@R&#SY/EE6L8A6K
MXJZ:,F6.?6&%GYM&QZK8#B6K6-4*JJ(\6:54]$\I9?EWQG*X%;?B5MR*6[5:
MJ]&CATK'<:3=7@:[+*D\)1WIYQD8`R*EM)]5&E3U]:P$A;13K;20(I)P"J6U
M%(0P9<%`*>4GY`9"^UZ6;_M7VL3*GJ9L[MY['HW)>'$K;M6VK7A-EL%@,.*.
M9#(II*T9Y^\M(T!)+2(Q$`%*:2&"&K\`C!%"VQC(3Y8P1DD_)BM(E'8<Z0=D
M@(W)'"FLUH_)9$0"$)&G=*SL4445^AB,BD91;!<-`%G"$I:PA"6QD9`C99!)
M`!L["2EL!1!_\QF,;16>KFJ('$>$?`-#)*0L\`E$1#*H@1Q6&['U\"S?]N](
M&?)M_S&T)T[CQ1*6M*6$Y^T8#`8C[C!!;3<;T(#(KV;L_V=?D'\LF5\EI++X
MIKAV,8-1R>#$(@:#P8@[R-8N!MF)*Q@R",]:M1-C5B((9&D5R6<P&`#GR;**
M5:QBU2Z@,B`2,$9Y&H"4PE9X`XCLG!9!>QHP4@H[R^43#!%(*06"%!3EDR&;
MI@""%#+*A]W!YBD`TI%1?I@VX7<8X5M[@K-K191O[?$[E#+*M_8HK6#LVJLI
ML5\K#82'K179'[60BDO<Q7<H6<6JG:_B\V19Q2I6L2K^*@$C;(A#?@*!OSAI
M"H?&)ORE2ZL-XBH"I*0@8"KP;7PE'5'.M_U+*<KYMG\I$T`IW]IC4UQ+^+9_
M:T:+]@=Q9POV.XYH\7J!8/>>SR^:NFOK\6(5J]I2Q?OM&`P&(^X@HL**I`D.
M6O6+@O@'JE*8Q%"8PJH@?LF\'8-1R>`]"@P&@Q%_V"@'%-F+!I#-2_5/<3``
MB6#&JQ+Y#`;#HBBV:[%6'DM8PA*6L*2M):25K0!B0QP!D-9VI5*0#7&(M-)A
MQ$,01,)3.N1;FE(FY-L(26D3\FW_6IF0;_M72H=\VW_\[,'GW4.6L*12)+PF
MRV`P&'%'(3/4EGD#[#R6E<"O%2(`&R?YI4."?Q'P@Y(BODH@R$V(].R?W%K,
MM]D+/A]!C9*8V5.YN.666TI^YF79P08LV4[)A`D3L.NC*$^V9(]>>4@8<K@5
MM^)6W(I;M5JKVV^;4=YV&]VR:E<<Y2_=2BEU^14#I72(("79LSH0%)8F(B](
MKXY6DK:!L5+&&",E1?FV!Z4`1%7^GD9CC%(VVP91OJ5%5`6^U2JE`03),04+
M`Q4Y#D7Y5JLU2BP,[=':`!#^`F21_5$+2^PON1NA_;F<-W/&TVO>>__`@P[8
MJ>/5"JTX3Y95K&(5J^*NNO*J2]V$"P),Z6^SL1O0K(0*Z:6!K%+XN>;<'7?,
M:LU!B94JF703"0E@WJ1A6VL[;/P\!)%3&-`D$OYK?P8T3'`NDD0#N%V>[[I;
MXPNEU*?K/Q5"=#]P_Z\^*&VHXC59!H/!B#N2;BJ12,#^1*%P`H.?*!J-A0#X
M0E-1?']EN')!1/Y/^]!Q<\K5\R8--R;(M_8;^"^"$C,VXA'&V#HSPO@-XL_W
MUK[^3N+`KW>M$E^M__9S)C'GR3(8#$;<80J9!`0#`S)^11!AZX*8,'74"BN4
M7[D(Y[#T5F)<;<C>/4OS7V177=5_Y*D#1ITZ8-2`_G53YKV>!1'YV3`M\&$#
MZY!@B\^4\!MG]Q\Y\[7-+?+?FOWS"Q]\S_^S^;W+^O_\]88OVG\Y/_]TW?2%
M[S9M-U]0X]OG]A_[:F,)O_T\'O"\'8/!8,0=%/PF(=PT5)B.L#)_$B*4A7]6
M#/_+W-AV`R(!0R#R%(RQ4[P`"LO7GO+C8"NUQYP`M!$=QLVYY>A,;NVKSXV:
M=-\_$U=//>]`>Y-1N,,!WY\',U8+JS6FF)\^[?X;G=K=6^1[:-Z2\TV&02.:
M\V'.S?;V[]OSUNP;QN0N>/JR0P"XU7!327^Z:BO\HOZK#JB_]YK:JA+^SAZE
MU@/'=@P&@[$+(#(O%:21VB4G?\6R\#-F?\PKF%^9()``C&?$@H=FE$<IGA$H
MW#$!A-%?ND,FY612!QUWUO2+WQXU^_F/AAS4<=7SUXQZ;#6`WOUG3SZG6TJ\
M-W_&M'<ZU:Y^;ODG.'_2555/WW??\L8>@T;>?=FAWKK_O73$G/4`>IPXZX[O
M=T\UOWC_@[CHZD$'8_'U]:MZ'+QV_O.KT77L_77]NZ<!P$T`1""33@#`QM=&
MGO.'RQ9=VR=#WOJ_7'SM^]-F]9MQZ;S=>B67+%N#VB/KIU[4IXO8LNJ/5Q=,
M&MSEPV?'S-\(3!NPZJR%TTYP,WAUZ8*18_X<OI':\.[D2Z<MWXP>`R^Z?<S1
M&?QKP:0ILY=O!`ZL7W1MG\3Z.3]_^GN_N*QG<E,HOV7^5:TQ4*T"/D^65:QB
M%:OBKQ(1%4DI0;;:2&$WFM;:^$>R6G[X^RZT4B`CA8SR[<IF\%Y.E&]G,;32
M@);2B?(#,PR@`PM]/OEIDH43;R-S:0(PX7M%^=8>I101"2&C_,A[03JBY'J)
MR/,48*24Y?N+VGJ\VD1E`)/78LA%EY2K?G'3W^`/(@7WE@`X;@+*WW_6_:C#
M,?M_/MWTP1VC'NL[?N(]1W9XNOZ&BV_?]\GQ_?+Y#:N7K_S.73>?N^978\9-
M^_;(JW[Y_7477?Z']R[Z?]V=FKK[[^S3?<M=_6_XPYNG7W*H^->:#<U9#TCD
MUZU;M@*3YDS>=/_U4Y]:>_*/O^ZD,IL?GC=IPYYH-L"&]4BA<X\CL.97__M)
MKY-KWEH\?\O1EW2!^N23=<M[#7]XP;`EHV^Z_M%^O[FTX_A1C_4=/W'FMS*_
MOWGLQ;=W>W+\\>,&/GE;_GL/_OCP:FBW`]Y8LO:F!V_^SX,WU#_U?O_+#EYT
M[;V;1XQ?>KISTW?&+SBI[P_3?YF]?*]92R9WV;1)I(UJ]E:O_[#)H^9_O#1[
M^5ZSEMS29=-GI@K/2FFV,@,<FU'>+I604H:DDK3;;3?F5MR*6W$K;M5:K6RY
M!R%EPM<:4DJA,%DEA)#PMYV%E8&%'QA)*84#`"2"][);D<AQ$E&^#9*44C`D
MI91.(K`PS&T0@)#2B?*C]@37)8R!4CIJCY2)*#]JCY2)T'Y5J%1LWTM&^5%[
MI'1"^VTYC)UPYW>!5E)*@G`<Z4@GK^P(EMP-RBM!\'<K`H(@M#8$X>7RD((@
MB*A9"P#9-7]]`[V^>^P^3K+CM[]W*I:_OP7":\Y6GU-W3L^]]CN@%A@P^NR>
M7???MP;_;O3(W:O'GDUO+YC]U*N`Z\!Q!`#;8;X!@^JOZ5?39=]N-=64D%(B
MZZ%W[_[?.?:D_L<-..Z;0)9HM_ZC>[TT;Z6BSQY?W'C1H)X&:$3G^KKC]JS>
MY[RQ)^5^_]X_UZRP)GFH.N6'IV/YVBU(==DMG<SLV2F3-$#^4PR:>LU1W?;L
MUK5S)^G"V_#VA[E/__R'.^]8M!S8DM?I/;O7XJVZ\?/?S:8Z2$'^YY"2>^Y?
MB[?JQC_^;F,J!6&?,>(YRE^H585/8C,8#,:N@>!7&86#'T!A#&1_L.%O.Z/*
MY%<VR!@8(*?(F(0Q#I``$C#^OSEE,XY%,/'I\PDV&04PM/&]MX!>W1P`F92?
MH>P!KO\.!@901/!/?O-W/K[\BPD7W/BWKOV^V0/(%???#(`TD<C[?/(H6_V-
M;QYUV*'?ZM>WWW&]:P&`NGW[I.I/_O2K7_]N1>WI)]0ZOCUY"C=;(@^@.NG;
M[P$)@/(&U@`BT0S`:(`\.RGI;?D$^.8Q_4XZ_L1;;[WRK`/2Z-C[@4>O.WO
Re: Epsilon Validation Language [message #1056000 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1056081 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1056163 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1056247 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1056334 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1056423 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1056490 is a reply to message #1053815] |
Wed, 08 May 2013 11:42 |
Member |
Dear Antonio,
Thanks for yesterday, my knowledge and understanding of EVL is increasing, However I am still struggling with getting my Completeness check 1 working.
Completeness Check 1:
All Goals (Subgoals) must be refined until they become leaf Goal (Expectation, Requirement, DomainHypothesis, and DomainInvariant).
Below are the EOL and EVL codes as you suggested to me yesterday:
[1] completekaos.eol
[2] completekaos.evl
context Goal {
The codes seems correct, but the following mistakes arise: Please see Figure 1.
(a) Although the Root Goal (<Goal>) has been refined into subgoals and then into leaf goals an error sign still appears in it, See Figure 1.
(b) There is no error sign on the SubGoal (<SubGoal3>), even though it has not been refined into leaf goal.
As shown in Figure 1, Goals do not go directly to leaf goals, in most cases they go through the AND/OR nodes (small circular hollow or solid figures, in Figure 1) to subgoals, and then to leaf goals ( Requirement, Expectation, DomainHypothesis, and DomainInvariant). I think I need to find a way to define a constraint that can specify that Goal and Subgoals go through the AND/OR nodes. this is very challenging to me. In the Meta-Model I used to generate the Graphic Editor (See attached as EuGENiaModel), all nodes including Goal, SubGoal, Requirement, Expectation, DomainInvariant, and DomainHypothesis inherit from one super-class called Node.
Please I really need your help on this. I can upload the workspace in our shared dropbox folder, for you to have a closer look on the project.
Joshua
Re: Epsilon Validation Language [message #1056500 is a reply to message #1053815] |
Wed, 08 May 2013 11:45 |
Member |
Dear Antonio,
context Goal {
Joshua
Re: Epsilon Validation Language [message #1056515 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1056584 is a reply to message #1053815] |
Wed, 08 May 2013 11:47 |
Member |
Dear Antonio,
context Goal {
Joshua
Re: Epsilon Validation Language [message #1056608 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1056615 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1056616 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1056703 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1056710 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1056711 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1056712 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1056800 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1056807 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1056808 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1056810 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1056900 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1056907 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1056908 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1056909 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057000 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1057007 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057008 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057009 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057102 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1057109 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057110 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057111 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057207 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1057214 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057215 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057216 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057311 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1057318 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057319 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057320 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057416 is a reply to message #1053815] |
Member |
Dear Antonio,
Joshua
completekaos.EOL
completekaos.evl
context Goal {
end
Re: Epsilon Validation Language [message #1057423 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
end
MY[RQ)^5
Re: Epsilon Validation Language [message #1057424 is a reply to message #1053815] |
Member |
Dear Antonio,
context Goal {
Joshua
M5"AT
