Home » Newcomers » Newcomers » Jetty on MAC OS X(FAILED SelectChannelConnector@0.0.0.0:8080: java.net.BindException: Address already in use)
Jetty on MAC OS X [message #1052874] Tue, 30 April 2013 16:48 Go to next message
I have a project which is done with jetty 8
and it works fine when run on Windows.
But when I run it on MAC OS X 10.8.3 I get the following error:
869 [main] WARN org.eclipse.jetty.util.component.AbstractLifeCycle - FAILED SelectChannelConnector@0.0.0.0:8080: java.net.BindException: Address already in use
This is not the problem of permissions, as I have tried to run it with "sudo" and it gives the same result.
Here is the code:
Server server = new Server(port);
SelectChannelConnector connector = new SelectChannelConnector();
connector.setPort(port);
connector.setThreadPool(new QueuedThreadPool(200));
server.addConnector(connector);
ServletContextHandler context = new ServletContextHandler(ServletContextHandler.SESSIONS);
context.setContextPath("/");
context.addServlet(new ServletHolder(new ImageServlet()), "/img/*");
context.addServlet(new ServletHolder(new OtherServlet()), "/other/*");
context.addServlet(new ServletHolder(new webConfigMainMenuHandler(0,0)), web_rootFolder + "");
context.addServlet(new ServletHolder(new webConfigMainMenuHandler(0,0)), web_rootFolder + "/main.html");
context.setErrorHandler(createErrorHandler());
server.setHandler(context);
server.start();
the exception comes on the server.start();
Please let me know how to fix this.
Many thanks,
Re: Jetty on MAC OS X [message #1052931 is a reply to message #1052874] Wed, 01 May 2013 09:14 Go to previous message
> FAILED mailto:SelectChannelConnector@0.0.0.0:8080:
> Here is the code:
> "/img/*");
> "/other/*");
> server.start();
> Many thanks,
No, it's not a permissions problem. You simply already have a process
running on your host using port 8080. You can a) find and shut down that
service or b) modify Jetty to use a different port.
In my case, for instance, I double-click the Tomcat server in my Servers
view which gives me access to (Tomcat's) settings. I change my port to
[admin:8005, HTTP:8000, AJP:8009]. I'm sure Jetty gives you analogous
control over it.
Hope this helps.
Previous Topic:Eclipse Freezing on Windows 7/64 bit
Next Topic:Can Eclipse run on the Chromebook (Chrubuntu)?
Current Time: Thu Nov 06 21:10:58 EST 2025
Powered by FUDForum. Page generated in 0.52174 seconds
