Home » Eclipse Projects » Virgo » EMF and Virgo(Problem while using EMF in Virgo)
EMF and Virgo [message #1052723] Tue, 30 April 2013 08:56 Go to next message
I'm trying to use EMF in a Virgo container. In my POM I added the following dependencies:
<dependency>
    <groupId>org.eclipse.emf</groupId>
    <artifactId>org.eclipse.emf.ecore</artifactId>
    <version>2.8.0-v20120911-0500</version>
</dependency>
<dependency>
    <artifactId>org.eclipse.emf.common</artifactId>
</dependency>
<dependency>
    <groupId>org.eclipse.core</groupId>
    <artifactId>org.eclipse.core.runtime</artifactId>
    <version>3.6.0.v20100505</version>
</dependency>
Although when I start my Server I get the following exception:
[2013-04-29 15:29:56.880]  TCP Connection(6)-127.0.0.1 <DE0002E> Installation of bundle 'xxx' version '0.0.1' failed. org.eclipse.virgo.nano.deployer.api.core.DeploymentException: commit failed
    at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.CommitStage.process(CommitStage.java:40)
    at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessGraph(StandardPipeline.java:62)
    at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessGraph(CompensatingPipeline.java:73)
    at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
    at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:359)
    at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:185)
    at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:140)
    at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:253)
    at org.eclipse.virgo.kernel.deployer.management.StandardDeployer.deploy(StandardDeployer.java:52)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
    at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenReturn(ConvertingMethod.java:167)
    at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:96)
    at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:33)
    at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:208)
    at com.sun.jmx.mbeanserver.PerInterface.invoke(PerInterface.java:120)
    at com.sun.jmx.mbeanserver.MBeanSupport.invoke(MBeanSupport.java:264)
    at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:836)
    at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:762)
    at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1454)
    at javax.management.remote.rmi.RMIConnectionImpl.access$300(RMIConnectionImpl.java:74)
    at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1295)
    at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1387)
    at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConnectionImpl.java:818)
    at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:303)
    at sun.rmi.transport.Transport$1.run(Transport.java:159)
    at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
    at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
    at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
    at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
    at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
    at java.lang.Thread.run(Thread.java:680)
Caused by: org.osgi.framework.BundleException: Failed to start bundle 'org.eclipse.emf.ecore' version '2.8.0.v20120606-0717'
    at org.eclipse.virgo.kernel.userregion.internal.quasi.StandardQuasiFramework.startBundle(StandardQuasiFramework.java:386)
    at org.eclipse.virgo.kernel.userregion.internal.quasi.StandardQuasiFramework.startBundles(StandardQuasiFramework.java:376)
    at org.eclipse.virgo.kernel.userregion.internal.quasi.StandardQuasiFramework.commit(StandardQuasiFramework.java:365)
    at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.CommitStage.process(CommitStage.java:38)
    ... 41 common frames omitted
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.emf.ecore.plugin.EcorePlugin$Implementation.start() of bundle org.eclipse.emf.ecore.
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
    at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
    at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
    at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:292)
    at org.eclipse.virgo.kernel.userregion.internal.quasi.StandardQuasiFramework.startBundle(StandardQuasiFramework.java:384)
    ... 44 common frames omitted
Caused by: java.lang.NullPointerException: null
    at org.eclipse.emf.ecore.plugin.RegistryReader.readRegistry(RegistryReader.java:81)
    at org.eclipse.emf.ecore.plugin.EcorePlugin$Implementation.start(EcorePlugin.java:557)
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
    at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
    ... 49 common frames omitted
And I have the feeling the Activator is trying to do something assuming an Eclipse plugin environment while there isn't one. Has anyone used EMF successfully in a Virgo bundle? Thanks!
Re: EMF and Virgo [message #1053568 is a reply to message #1052723] Mon, 06 May 2013 10:45 Go to previous message
We are using EMF in virgo.
If I remember correctly, I had the feeling that EMF supports two deployment scenarios:
  1. as OSGi bundles in Eclipse
  2. as regular JARs in a JavaSE application
Deployment in an OSGi environment other than Eclipse does not work because activators assume that the container is Eclipse.
To use EMF in Virgo we included the EMF JARs as Bundle-Classpath in a bundle of ours which exports the relevant packages for other bundles.
Attention points:
  • Emf uses a global Package Registry: EPackageRegistryImpl.createGlobalRegistry()
  • EPackageRegistry.getEPackage() seems to rely on the ThreadContext Classloader for certain lookup operations. You may have to change the thread context class loader before invoking that method.
GianMaria.
Previous Topic:Fragment fails to resolve if listed after host - Virgo Tools on Linux
Next Topic:Virgo 3.6.1 and SpringFramework 3.2.2
Current Time: Thu Nov 06 07:48:39 EST 2025
Powered by FUDForum. Page generated in 0.02755 seconds
