Re: Embedded Image not working in BIRT4.2.2 [message #1059075 is a reply to message #1053197] |
Thu, 16 May 2013 14:30 |
William Harrelson Messages: 4 Registered: May 2013 |
I'm having this same issue. I have three images in my report. All are specified by including a full public URL in the URI specification in the designer. All show just fine in Report Designer and in preview in Report Designer. All three show in webviewer html mode using 'preview', but only two of the three show using any pdf output mode, or in webviewer frameset mode.
Can anyone help me solve this? TIA.
Eclipse Juno, Win7, BIRT 4.2.2 release, tomcat 6, complete newbie.
[Updated on: Thu, 16 May 2013 21:25] Report message to a moderator
Re: Embedded Image not working in BIRT4.2.2 [message #1160729 is a reply to message #1052420] |
Tue, 29 October 2013 10:08 |
purnima d Messages: 26 Registered: April 2013 |
Hi Williams
Embedded image is not working for Birt 4.3 also.
Issue 1 : We are using weblogic 11 to deploy the reporting application and once the rptdocument gets generated with Birt 4.2.2 and we are using Birt 4.2.2 viewer to view the report from the application but we are unable to view the embedded images in newly created report (with 4.2.2)
Issue 2 : We are also facing issue with old reports which are generated with BIRT 3.7 and these reports are uploaded to the database as rptdocuments.
So, when we try to view these old reports with birt 4.2.2 viewer , the embedde image is not getting displayed
Note : Even if we use dynamic image we will face the same issue with old reports that are stored in DB with embedded image.
Observations :
1.Looks like it is not issue with Weblogic why because initially we have upgraded Weblogic to 11g without upgrading BIRT and tested all reports everything is fine.We have encountered this issue only after upgrading BIRT to 4.2.2
2.This is happening for any sample report we create using BIRT4.2.2.
3.We also tried birt 4.3 viewer , we are facing similar issue with latest 4.3 version.
Please find the attached sample report created using birt 3.7
Steps to reproduce :
1.Use this sample rptdesign and generate rptdocument using birt 3.7
2.Try to view the rptdocument with birt 4.2.2 and birt 4.3
example :
http://localhost:7001/reportViewer/run?__document = sample_embedded_image.rptdocument
if you use Birt 4.2.2 or Birt 4.3 viewer you will not be able to view the the embedded image
Created Bugzilla entry for this :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=406788
[Updated on: Tue, 29 October 2013 10:15] Report message to a moderator
FUDForum. Page generated in 0.04470 seconds
