Re: build feedback [message #1052241 is a reply to message #1052218] |
Mon, 29 April 2013 21:09 |
On 4/29/2013 2:47 PM, Michael Soulier wrote:
> Hello,
> I'm a relatively new Eclipse developer, mainly using it for Java and
> Android development. I'm surprised at how little feedback it provides
> when I tell it to build the project, and if there are errors, I'm not
> simply taken directly to those errors as I would expect.
> Is there a way to enable such behaviour?
> Mike
How doesn't the Problems and/or Markers view work for you?
Re: build feedback [message #1052769 is a reply to message #1052390] |
Tue, 30 April 2013 14:01 |
On 4/29/2013 8:50 PM, Michael Soulier wrote:
> Russell Bateman wrote on Mon, 29 April 2013 17:09
>> On 4/29/2013 2:47 PM, How doesn't the Problems and/or Markers view
>> work for you?
> I suppose because Eclipse doesn't bother to take me there when there is
> a problem?
> As a new user, "Markers" means nothing to me. Problems does, but I don't
> see that in any of the tabs at the bottom.
> You'd think that user-interface design 101 would be to show the take the
> user to the problems.
> Mike
No, this is Usage 101.
Go to Window -> Show View -> Problems. Then grab the tab of the newly
appearing view and drop it into whichever pane most suits you (for most
of us, and this is probably where it will appear anyway, that would be
the bottom pane).
As for user interface, you should probably contemplate the sheer scope
of developer solutions hosted by Eclipse before making too many hard and
fast assumptions. For example, Android development isn't specifically
planned for by Eclipse. It's a set of plug-ins and behaviors implemented
atop Eclipse by an entirely separate community. (And supported by that
community, if you must know: please read the sticky posts at the top of
this forum.)
You may have accidentally dismissed that view (or the Markers view) by
closing it. Of course, this depends a lot on the package you chose to
download, which you did not name in your question.
Best of luck.
FUDForum. Page generated in 0.11949 seconds
