Is it RAP still working with Juno 4.2.2 [message #1050019] |
Fri, 26 April 2013 15:30 |
Am I the only one who cannot make RAP work ?
I am developping an Eclipse RCP/RAP (single sourcing) application since 2 years. I add to install a new version of Eclipse platform yesterday. My RAP software run, the Jetty server too, but I constantly get error:
HTTP ERROR: 404
Problem accessing /rapdemo/rap. Reason:
ProxyServlet: /rapdemo/rap
No message in the Console.
I just did the test. I download the last Eclipse, install RAP target platform, add org.eclipse.rap.demo plugin, and launch it through RAP Workbench Demo launch configuration (so basically I perform the RAP Quick tour) ... and 404 ...
The worst is that I get the same problem on my Windows 7 computer and the Mac Book Pro (Mountain Lion). So my question: Does new RAP build actually works ?
Thanks for your help!
Re: Is it RAP still working with Juno 4.2.2 [message #1052034 is a reply to message #1051755] |
Mon, 29 April 2013 14:37 |
Ok perfect! As soon as I put the RAP tools it works! I thought I was already in RAP 2.0, but I was using old RAP 1.5 tools...
Sadly my problem is not totally solved as now I have a reccurent problem:
I install Eclipse, create a new workspace for RAP only application. Use the RAP tutorial. It runs perfectly. Then when I stop Eclipse. I get a crash if I run it again!
Here is the log:
!SESSION 2013-04-29 16:08:48.647 -----------------------------------------------
eclipse.buildId=M20130204-1200
java.version=1.7.0_05
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=fr_FR
Framework arguments: -product org.eclipse.epp.package.rcp.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.rcp.product
!ENTRY org.eclipse.debug.ui 4 0 2013-04-29 16:08:49.819
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.debug.internal.ui.DebugUIPlugin.start() of bundle org.eclipse.debug.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.lang.IllegalStateException: Workbench has not been created yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
at org.eclipse.debug.internal.ui.contextlaunching.LaunchingResourceManager.startup(LaunchingResourceManager.java:546)
at org.eclipse.debug.internal.ui.DebugUIPlugin.getLaunchingResourceManager(DebugUIPlugin.java:357)
at org.eclipse.debug.internal.ui.DebugUIPlugin.start(DebugUIPlugin.java:569)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 12 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2013-04-29 16:08:50.316
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4361)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Display.error(Display.java:1258)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:764)
at org.eclipse.swt.widgets.Display.addListener(Display.java:626)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.<init>(IDEWorkbenchAdvisor.java:176)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.<init>(IDEWorkbenchAdvisor.java:184)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:125)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.05209 seconds
