Home » Eclipse Projects » Babel » Using NL plug-ins in RCP
Using NL plug-ins in RCP [message #14571] |
Thu, 03 July 2008 13:31 |
Originally posted by: godeau_nosp.m_alma.fr
When I put language plugins from Babel project into my RCP target
(version 3.4), they are not taken in my application build. The platform
part of the application is not localized.
I must copy the language plug-ins by hand after the build, to get the
app translated.
What did I get wrong please?
Thanks in advance.
Patrick
Re: Using NL plug-ins in RCP [message #16514 is a reply to message #14837] |
Thu, 17 July 2008 15:49 |
Le 10/07/2008 09:09, Hendrik Maryns a écrit :
> Patrick Godeau schreef:
>> Hi again,
>> I wonder, does anyone really use babel translations?
> I do, but only as developer (by that I mean: I use Eclipse as developer
> only), and the flashing splash screen pops up from time to time, so it
> isn’t really usable yet.
That's what I feared: Babel translations are not usable for RCP development.
I'd like to help, but how? I already submitted some french translations,
but the problem is in the packaging: if there were usable language
packs, even with incomplete translations, I'm sure that there would be
much more translation contributions.
Patrick
Re: Using NL plug-ins in RCP [message #16531 is a reply to message #16514] |
Thu, 17 July 2008 18:06 |
Eclipse Webmaster Messages: 607343 Registered: July 2009 |
>>> Hi again,
>> developer only), and the flashing splash screen pops up from time to
>> time, so it isn’t really usable yet.
> development.
It's not clear to me what the problem is yet, so I'm at a loss to know
how to fix it.
The code that builds the update site is here. Have a look:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.babel/s erver/classes/export/generate1.php?root=Technology_Project&a mp;view=log
Denis
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: Using NL plug-ins in RCP [message #16548 is a reply to message #16531] |
Mon, 21 July 2008 15:16 |
>> development.
>> translations, but the problem is in the packaging: if there were
>> usable language packs, even with incomplete translations, I'm sure
>> that there would be much more translation contributions.
> how to fix it.
Hi Denis,
The problem is that there are no Babel language packs available for
download, contrary to what is said on the download page.
There are only update sites, for adding translations from an update
manager inside Eclipse IDE. But this is not what we need for building
translated RCP applications. (Incidentally, even these update sites
break the IDE, as noted on previous threads.)
It is possible to download NL plug-ins from the nightly build update
site with some fiddling (this require to bypass robots.txt, I use "wget
-erobots=off") but this is not acceptable for the average developer.
I also had to write a Python script to get NL plug-ins for all wanted
languages.
Will it be possible to have language packs as specified here:
http://wiki.eclipse.org/Babel_/_Server_Tool_Specification#Ou tputs
Thanks in advance.
Patrick
Re: Using NL plug-ins in RCP [message #16565 is a reply to message #16548] |
Mon, 21 July 2008 15:54 |
>>> development.
>> how to fix it.
> Hi Denis,
The 'break the IDE' problem is what I would like to solve. Can someone
open a bug with a set of actions to reproduce the problem?
If you write a script that takes the NL plugins and re-packages them
into 'language packs' I will certainly have a look at it. Simply open a
bug against Babel/Server and attach the script.
Thanks!
Re: Using NL plug-ins in RCP [message #16618 is a reply to message #16565] |
Tue, 22 July 2008 10:16 |
Here it is:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241633
IMO, building language packs for Eclipse platform, or at least RCP
runtime, should be a priority, rather than trying to translate every
Eclipse project.
The fact that language packs are not available is discouraging
developers to build apps on Eclipse versions upper than 3.2.
Patrick
Re: Using NL plug-ins in RCP [message #572289 is a reply to message #14837] |
Patrick Godeau Messages: 64 Registered: July 2009 |
Member |
>> Hi again,
Patrick
Re: Using NL plug-ins in RCP [message #572319 is a reply to message #16514] |
>>> Hi again,
> development.
how to fix it.
Denis
Re: Using NL plug-ins in RCP [message #572394 is a reply to message #16531] |
Member |
>> development.
> how to fix it.
Hi Denis,
languages.
Thanks in advance.
Patrick
Re: Using NL plug-ins in RCP [message #572418 is a reply to message #16548] |
>>> development.
>> how to fix it.
> Hi Denis,
Thanks!
Current Time: Fri Apr 26 04:52:17 GMT 2024
Powered by FUDForum. Page generated in 0.04371 seconds
