Home » Eclipse Projects » Standard Widget Toolkit (SWT) » MouseDown events on composite causing freezing?
Re: MouseDown events on composite causing freezing? [message #1055367 is a reply to message #1053707] |
Wed, 08 May 2013 06:15  |
First of all -is each cell a composite?
why?
why not one canvas and draw the whole thing?
and use the hover and move events to capture the position and redraw the cells as required...
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
Re: MouseDown events on composite causing freezing? [message #1055368 is a reply to message #1053707] |
Wed, 08 May 2013 06:21  |
why?
and use the hover and move events to capture the position and redraw the cells as required......
Vijay
Re: MouseDown events on composite causing freezing? [message #1055432 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055433 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055501 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055503 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055571 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055572 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055643 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055644 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055717 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055718 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055790 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055791 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055868 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055869 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055946 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1055947 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056025 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056026 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056106 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056107 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056191 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056192 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056277 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056278 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056365 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056366 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056454 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056455 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056546 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056547 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056641 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056642 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056737 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056738 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056835 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056836 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056936 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1056937 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057037 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057038 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057142 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057143 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057246 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057247 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057351 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057352 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057457 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057458 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057569 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057570 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057677 is a reply to message #1053707] |
why?
Vijay
Re: MouseDown events on composite causing freezing? [message #1057678 is a reply to message #1053707] |
why?
Vijay
Current Time: Tue Jul 29 02:10:55 EDT 2025
Powered by FUDForum. Page generated in 0.91222 seconds
